Question about Lanier Office Equipment & Supplies
Need a technicians manual to activate copier code functions and other things for a Lanier 6735. Do you know where to find one?
  • 68 Answers
Here the link to the website where you can download technician service manual in .pdf format for this model:
http://www.smpcshop.com/3550-p-1389.html
Posted on Oct 04, 2009
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Hello there i have a lanier color copier everthing work and functional fine acceipt when i want making color copy, i press full color button the display panel show TO USE THE FOLLOWING FUNCTION [ S ] SET...
Hi, whoever administrates that copier has set it up for key counter management, which means that unless you supply the correct key (which is typically a card that you swipe or a code you enter) you can't make color copies. If this is your copier, you can disable key counter management:
- Press the User Tools/Counter button. - Go to System Settings. - Go to Admin Tools. - Find the option for Key Counter Management and turn it off. - Exit out of User Tools.
Now you should be able to make copies normally.
Dec 02, 2010 | Lanier UNKNOWN
Got a function code SC322 on lanier 5622 copier. Power cleared the unit several times but status remains unchanged.
Most of the time the motor in the laser unit has gone bad.
The laser could also simply need cleaned.
Sep 15, 2010 | Lanier Office Equipment & Supplies
Have a lanier 6735 with an ''A1''Code
Hello sir; A-1 code means discharge corona cleaner problem, check it up may be the cleaner not function right.
Oct 16, 2009 | Lanier Office Equipment & Supplies
Lanier 5645 has a sc542 error code
this is a problem with the thermistors and will need a technician to come out and fix it for you, the part #'s are aw100052 and aw100053 for the thermistors but you have to enter service mode to clear and reset the code.
if this answers your query please rate my answer accordingly
Regards
Sep 14, 2009 | Lanier Office Equipment & Supplies
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Jun 06, 2009 | Office Equipment & Supplies
Lanier 6725 need pm code or manual
A2 means something is wrong in the duplexer. Check all parts of the duplexer for jammed paper.
May 28, 2009 | Lanier Office Equipment & Supplies
Lanier 6735 Copier
Sounds like you need a new cleaning blade. It is located inside the process assy behind the drum.
Aug 10, 2007 | Lanier 1205 Copier
118 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
