Question about Cameras
Camera won't turn on
I can't get the camera to turn on, even with fresh batteries. I think it's the switch. It's an EasyShare CX6330. I would just buy another camera, but I also have the compatible 4x6 printer/charger dock. Thanks!
The lens is sticking out about 1" so I think it shut down in the middle of opening or closing.
SOURCE: Digital camera switches on and then off very quickly
I too am experiencing the same problem with this model. Have you found a solution? I think it could be a firmware problem, but I can not find a update download.
Posted on May 15, 2007
SOURCE: Turn on the camera, cover lens is closed even though i already pull it down
if you open up your casing you will find that almost dead center on the front PCB, just to the right of the battery at the top of the empty battery area there is a box. possibly with some plastic fragment that is broken off. if you touch inside this box w/ something conductive it will think the lens is open. You can either fix this area or permanently solder it so it thinks it is always open. You can still turn it off using the button on the side of the camera
Posted on May 25, 2007
  • 374 Answers
SOURCE: camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Posted on Mar 30, 2008
  • 1632 Answers
SOURCE: Won't turn on after charging; lens just sticks out
Charge it again with a new batery and the 5 volt charger.
3 hours.
Vitally
Posted on May 15, 2009
SOURCE: Sony Cybershot camera will no longer take
I had the same problem. I looked at FixYa some months back and found the solution. Give the camera a jolt against something hard. . . has worked for me several times.
Posted on May 24, 2009
Won't turn on
possible battery problem. look at battery contacts. clean w/ pencil ereraser or small scraping devise.GENTLY, on battery and camera.
possible dead battery even if new.even if you buy a new battery, clean ththe contacts an battery and camera.
Sep 25, 2012 | Kodak EasyShare DX6490 Digital Camera
I just bought new 4gb sandisk. I have a kodak easyshare cx6330 camera. It won't format. Any suggestions
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Jul 31, 2011 | Kodak EasyShare M1093 IS Digital Camera
I tried using a 4GB SDHC card on my Kodak Easyshare CX6330 and it went into a state of perpetual formatting. The card now does not work on any reader i have. Is there a way i can reset the card or manually...
The CX6330 is designed to work with SD and MMC cards. It will not work with SDHC cards. You need to use SD cards 2GB and smaller.
You cannot use the card on the camera. If you have a card reader or other device compatible with SDHC cards, you should be able to format the card there.
Sep 02, 2010 | Kodak EasyShare CX6330 Digital Camera
I zoom, shuts off!
Before you arrange a repair try these steps: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 28, 2010 | Kodak EASYSHARE M1063 Digital Camera
Why won't camera switch on and red light flashing all the time i have bought a new battery but still won;t switch on and light still flashing many thanks
hi, what type of batterys have you brought as most normal batterys you buy wont even switch the camera on you need hi power batterys such as lithium or even better go into a camera shop and they will have special high power bats, normal bats wont even switch mine on so give different batts a try
let me know how you get on or if you need fyrther assistance ok
Nov 10, 2009 | Kodak EasyShare Z730 Digital Camera
I have a kodak easyshare cx6330. It won't do anything. I've put new batteries in it and tried numerous things to no avail. If I set it on charger base I only get one light on the bar and it stays that way....
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Oct 23, 2009 | Kodak EasyShare CX6330 Digital Camera
Why isn't my Kodak CX6330 responding?
For this problem try the following:
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Oct 02, 2009 | Kodak EasyShare CX6330 Digital Camera
Kodak CX6330 dogital camera
I have this camera and it sparked on me back in April and no longer works. I have taken it apart several times in attempts to fix it. If you are still in need I can send you my toggle switch as I'm preparing to trash it.
Jun 27, 2008 | Kodak EasyShare CX6330 Digital Camera
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
