I HAVE A HUNTER PROGRAMABLE THERMOSTAT AND CAN'T REMEMBER WHERE I CHANGE THE BATTERIES, ITS READING "LOW BATT" PLEASE HELP, THANKS
    President:
  • 3,433 Answers
Pull the unit face straight out and away from yhe wall plate. It plugs into several contact pins so rock genttly if you do. Good Luck, Ned.
Posted on Oct 03, 2009
I have a Hunter Thermostat 44360 7 day Programable and I want to cancel all programs and just use it manually amy help?????
There should be a tiny unmarked hole in the front of the thermostat....if so, the thermostat 'reset' micro-switch should be under that hole. Gently stick a thin toothpick inside to depress the switch and get ready to operate it manually.
If there is no hole, separate the thermostat from its sub-base and look closely at the sub-base for a reset button.
Apr 13, 2015 | Hunter 44360 7-Day Programmable Digital...
Home Thermostat reads low batt
I have ran into this problem before. I have actually had low batteries I thought were good too ha! I have had to actually reset the stat to get the low battery to stop flashing. There are multiple ways to reset the thermostats, depending on model, but removing the batteries and waiting has worked, along with actually having a reset button somewhere on the stat. Hope this helps!
Nov 30, 2013 | Honeywell Programmable Thermostat Heater
How do I change batteries in a Hunter airconditioner thermostat
You should be able to just pull off the front cover. Look around the wall and there should be guides telling you too either pull the bottom out first or somehting like that. The batteries should be just behind the front cover.
Dec 12, 2009 | Hunter 30124 Air Conditioner
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate batteries, turned the correct way. Cleaned off the battery terminals and still have replace battery...
Thermostat problem; Honeywell chronotherm lll ' Low Batt. indicator Keeps blinking after Batteries replace. I chk'd batt. with elect. volt ntr. Was told to pull batt. and change ends with them , letthem stay reversed for 5-10 sec. then put them back in right order,and replace thermostat. No success!
Anyone have any answers
Nov 12, 2009 | Honeywell Power Humidifier: Furnace...
Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Oct 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Trane Air Handler and Trane Thermostat with no power. Please help
First of all put back the jumper wire you remved Rc to Rh and also put the red wire to either one then the white to W, the green to G and the yellow to Y .That is for the thermostat wiring for a not heat pump outdoor unit.Remember this electronic thermostat has a time delay so the unit will take a few minutes to start.All this if the problem is the thermostat.But also when nothing works it could be that the drain line is clogh and some air handlers have a flood switch who shut the unit off if drain is clogh(it could be located in the drain line out of the air handler or inside it on the drain pan.) newer TRANE units have it inside.
Aug 13, 2009 | Heating & Cooling
Hunter Fan Model 44260 eats batteries
you have to replace the thermostat . problems like this are common with latest electronic thermostats from china . most are going bad in less than 4 years . it so bad ,i am telling anyone who asks , to please keep there old regular thermostat , or if you have one of the old electronic ones (made over 10 years ago) hold on to it , it will last forever.... somehow when we moved the factory to china they forgot how to make thermostats that last ........ if you plan to rate this answer , please rate it 3 or 4 stars . this will help me stay in the paid answer department
Apr 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Installing a Programable Thermostat
give me the wire colors from the white rodgers and how they are connect to the white rodgers .. The white rodgers should be marked on the back where the wires connect. I can then tell you where to hook each wire to on the hunter.
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter programable thermostat
google search hunter thermostat and the model number and manual and it should come up, I found mine with "hunter thermostat 44200 manual"
Nov 25, 2007 | Hunter Fan Company 5/1/1 Programmable...
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
Programmable thermostats at discount prices at hunter-thermostats.com.
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
