Question about Pioneer DEH-1700 CD Player
How do you remove a Pioneer DEH-1700 out of the dash to repair. do I need a special tool .Problem I'm having radio go's out when I hit a bump in highway But display remains lighted
shadow5599
  • 51 Answers
SOURCE: Pioneer Super Tuner 3 Removal
If it's been installed with the original DIN mount, there are 2 small flat clips that slide in a small slot on each side of the radio. The 2 pieces of metal are pushed in to release the clips holding the radio in the bracket. Then the radio pulls out
Those clips come with the Pioneer stereo but should be available from a place that sells/installs car audio
Posted on Oct 16, 2007
shawnsz
  • 64 Answers
SOURCE: pioneer DEH-P500UB set the clock
1 Press SRC and hold until the unit turns
off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select clock set.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Posted on Feb 18, 2009
  • 232 Answers
SOURCE: setting the time please
Page 13 in the owners manual.
Posted on May 14, 2009
  • 7 Answers
SOURCE: Car Radio just stoped working.
My same model did this too. The wiring harness may have gone bad. Try direct wiring the stereo or replacing the wiring harness if you can get one. This fixed the problem for me.
Posted on Jun 28, 2009
  • 85 Answers
SOURCE: how do i install a pioneer supertuner deh-1700
Black ground Red accessory (keyed) Yellow memory constant power,Blue is remote,Orange is for the dimmer,green with black is Left Lear negative.and green is positive,violet black is Right Rear negative and Violet is positive,white is Left Front positive as for white with black is negative,gray black is Right Front negative and gray is positive
Posted on Sep 14, 2009
Installation wiring diagram for pioneer deh 1700
here is the link for the installation manual and user manual:
http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/CD-Players/ci.DEH-1700.Support
see the installation manual page 1 far right side for wiring diagram is listed as other manual
Cheers!
Nov 17, 2009 | Pioneer DEH-1700 CD Player
Pioneer DEH - 1700
The wires that you are looking for on the back of the radio is the yellow, red, and black. The yellow is for constant power, the red is for power only when the key is turned on, and the black is ground. You need all three in order for it to work.
Oct 23, 2009 | Pioneer DEH-1700 CD Player
Deh 1700 will not eject cd
There should be a small reset button you can push with the point of a pen, that will reset the radio, if you can't find this, simply disconnect power for a few seconds, and reconnect. If reseting it does not get the disk out, you may want to buy a new head unit, the repair for this is usualy at least $80 just to take the lid off, and tell you what is wrong.
Aug 18, 2009 | Pioneer DEH-1700 CD Player
Pioneer DEH-P3300 and 94 Mazda
Hello ryan_jaime,
It's good that you have an aftermarket Mazda wiring harness. It will allow you to make all of the connections in a well-lighted and comfortable location rather than fumbling around behind the dash.
If you are somewhat skilled at soldering, the most secure, electrically conductive, and positively insulated splices are made with solder and heat-shrink tubing. You can get the needed equipment from any Radio Shack, Lowe's or even WalMart. Be sure to put the heat-shrink tubing on the wires BEFORE you solder them together. I had to say that! Because I've forgotten many times! But if the soldering route is not for you, get properly sized insulated inline crimp splices and the appropriate crimping tool. Match up each wire by function on the Pioneer harness with the corresponding wire on your aftermarket harness. Most of the time, the wires will be color-for-color matched. But make sure, sometimes wires for things like "illumination", "dimmer", "mute", etc may not be the same colors.
Disconnect the negative battery terminal while you are working behind the dash. After you have the harnesses spliced together, plug the radio end into your Pioneer, remove the old radio from the dash opening, unplug the antenna and wiring harness plug and plug the other end of your spliced harnesses into the vehicle plug and the antenna plug into your Pioneer's antenna connector. Slide the Pioneer loosely into the opening, but don't secure it yet. Reconnect the negative battery cable and test the receiver. If everything works, slide it into the dash opening and secure it. Use the rear support stud and rubber bumper if needed. Install the trim ring or separately purchased dash kit as required. Put the "face-fixing" screws in to prevent removal of the faceplate if desired. Reinstall any dash trim removed and you're finished.
Hope this helps.
Jul 08, 2009 | Pioneer DEH-P3000 CD Player
I Have a pioneer radio, DEH-1900MP in my 2000 ford focus. I need to know how to remove it so that I can repair an air conditioning malfunction.
Removal
Vehicles with high output amplifier and subwoofer
  1. Using a common radio remover, detach the audio unit.
    1. Insert the common radio remover into the locating holes. Pull the tools gently to the left and right of the audio unit to release the locking tangs.
    1. Slide the audio unit out of the instrument panel.
  1. Remove the audio unit.
    • Disconnect the audio unit electrical connectors.
All except vehicles with high output amplifier and subwoofer
  1. Using the special tools, detach the audio unit.
    1. Insert the special tools into the locating holes. Pull the tools gently to the left and right of the audio unit to release the locking tangs.
please rate, thanks
Jul 03, 2009 | 2000 Ford Focus
Preset memory not working on pioneer DEH 1700 radio
You must connect the constant hot wire (or there is a fuse blown somewhere).... it should either be orange or yellow at the rear of the pioneer radio ... it should be connected to a wire that recieves power even when the key is off ... that wire will depend on the car itself ... if you used a connector to plug into the factory wires (a good idea) that connecter should have a yellow wire that would supply a constant "hot" for your pioneer, if it doesn't there should be a fuse blown in the car fuse box.
Apr 06, 2009 | Pioneer DEH-1700 CD Player
Deh-1700 goes dead on bumps
Loose or striped wire, pull the radio out and check your connections thoroughly.
Mar 19, 2009 | Pioneer DEH-1700 CD Player
Pioneer Premier DEH-P670MP Keeps shutting off
This is an Internal Fault and needs to be Sent in for Repair or Replacement
Jan 03, 2009 | Pioneer Premier DEH-P670MP CD Player
Remove Pioneer radio from dash
slide them down the two enads of radio you will have to pop off the narrow trim bezel around radio to do this
Aug 19, 2008 | Pioneer DEH-P2000 CD Player
How do I get it out of the dash
the radios come with 2 removal tools. you remove the trim plate then slade the tools in one per side... what kind of car? i may be able to tell you a different way of removing it..
Sep 05, 2007 | Pioneer DEH-P44 CD Player
Pioneer DEH-1700 CD Player Logo
75 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
