Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I have a gas oven that was working fine. Now the
I have a gas oven that was working fine. Now the oven won't work at all, I don't think the gas is even coming on. What should I do to fix it?
  • 283 Answers
See if the ignitor glows. If not check for power to the range then out of the control where the wires lead to the ignitor. If it does glow check the current. If less than 3 amps or the ignitor glows dimly replace the ignitor.
Posted on Sep 28, 2009
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
My tappan oven won't work. stove and broiler work fine. ignighter glows but it seems like there is no gas.
I would check with your manufacturer and see if a professional can diagnose the regulator and even the gas valve itself.
Jul 17, 2012 | Tappan Ovens
Gas oven won't turn on, stove top works fine.
check if the igniter is getting a 110 volt power if yes replace the igniter
Sep 05, 2011 | Kitchen Ranges
My gas oven won't work - it worked yesterday. The burners work fine. No clicking sound, no gas coming through. Checked plug in - fine; re-set all breakers; all electronics around it are working.
Which oven do you have? I need a model number to help you. There is a model that has a electronic ignition system that if the regulator in open (blown internal fuse) the oven will not work. So I need a model number to verify.
Get back to me when possible
Aug 28, 2011 | Kitchen Ranges
Oven sometimes doesn't stay up to temp
The temp is controlled by electronics that monitor the oven sensor.
The sensor should ohm out at 1100 ohms.
If it is shirted to frame or open the open temp would not do right and the
oven control would not know what the temp was and would probably declare an F-3 error.
In your case I don't think that is the problem. What i think it is going to be is the ignitor. If it is getting weak it sometimes won't draw enough amps to open the safety bimetal inside the gas valve.
Probably the ignitor is on it's way out.
Jul 30, 2011 | Maytag CWG3100A Gas Single Oven
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 03, 2011 | Microwave Ovens
My GE xl44 gas range broiler won't work,
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Ovens won,t function, no spark or gas but gas hobs work fine
heatman101
Dec 30, 2010 | Rangemaster 110 (Gas) Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
116 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
