Question about Canon PIXMA MP830 All-In-One InkJet Printer
I have a MP830 and I added a MX860 at my other house. Now I can't scan with 830 because the scanner selector keeps showing MX860 and I can't change this to MP830.
2 Suggested Answers
  • 71 Answers
SOURCE: Scanner not working
You need to check the operator's manual. For the messages it gives, there is usually a solution for it.
Posted on Nov 05, 2009
CANON MP830 is giving me an error code 5010. What does this mean and how do you fix it?
This error refers to the following possible problems:
1) Unlock the scanning unit: Before turning on the power, open the scanner cover, slide the release button to the "unlock" position and close the cover. Turn off the power for approx. 5 seconds. Power back on.
2) Reset the device: Press and hold the <On/Off> button until the display on the machine goes blank. (If this is unsuccessful, unplug the power cord). Wait approx. 10 seconds and power back on. Wait until the printer completes its startup routine before trying another print job.
3) Your MP 830 requires repair service.
Dec 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I added a printer (MX860) at my other house and now I can't scan on my MP830 it has scanner selector set on MX860 and I can't change it.
Ok. I guess you should try unplugging the usb to the 860 and only have the 830 plugged. Click on start, control panel, printers and faxes, then select the 830, then a window should come up, click the word PRINTER, then select default. try restarting pc and doing a scan. I hope this works. I cannot be certain as other factors may be involved.
Sep 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Scanning error on mp 830 - code 5010. What is
Hi, did some research for you and this is what I found:
Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
In response to your query, please be advised that the error code "5010" indicates there is a scanner error and the printer will require service.
If the printer was bought recently you can contact the dealer and check the replacement program.
If you are outside the replacement policy, please find below a list of authorized service centers for your device and some packaging instructions:
The following office peripheral products: A3 and portable printers which are still under warranty, Laser Beam Printers, PC/FC Copiers, Multifunctional Devices and Fax machines benefit from on-site service.
On-site service can be arranged by dialing 0870 400 2080, or by contacting
Canon Ireland Ltd (Fax, Multifunctional and PCFC Copiers)
Arena Road
Sandyford Industrial Estate
Dublin 18
Tel: 01 205 2400
Fax: 01 295 8141
Web: http://www.canon.ie
Sep 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
It keeps saying that the scanning device is Out of memory/exceeds limits? is this a paperport problem or my scanner? and why all of a sudden? My scanner is a Canon MX860 and has been working great -...
"...till now"
So... what changed? did you install some new software that consumes a lot of resources?
Some update?
Changed something in the resolution? (higher = more memory needed)
check the disk space too, maybe the pagefile is larger than usual.
or, re-install the scanner driver, and PaperPort just to clear things out.
Sep 17, 2009 | ScanSoft PaperPort Deluxe 9...
Feed switch & alrm light on
The MP 830 usually will give you an error code in the display. If these lights just come on and you don't hear anything moving inside and no error codes, the main logic board could be bad. A rather expensive repair. Have you tried unplugging the printer and plugging in again?
Jun 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp 830 will not scan but will print
Uninstall the software and reinstall. Use an ethernet cable and try scanning. If that does not work then your scanner feature has a problem. Probably very expensive so I suggest you go to the Epson site and look under Clearance. New/Refurbished have a 1 year warranty, replacements are quick and free shipping both ways. A All-In-One is $45 shipped, the ink costs more than that. Check this website for CISS system which saves lots of money.
http://www.inkproducts.com/ink-store/
May 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp-830 error code 5010
That code is a scanner error. The scanner unit can not detect the home position or the scanner unit warming up is not done properly at power on. Most of the time the Scanner unit needs to be replaced.
Nov 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp 830 getting error 5000
Canon site if the link does not work just go to canon.com -> support-> select Multifinction --> Inkjet --> Pixma MP830
Then type in - error code 5000 - (Leave off the " - "
Select #3 - ERROR LCD: Error code (5xxx through 9xxx) appears on the display -
1. Press ON/OFF switch to reset the multifunction device
2. Press Stop/Reset and ON/OFF to reset the printer
3. Removing paper jams MP800R / MP830 / MP530
4. The MP830 may require repair
5. Unlock the scanner lock switch (MP800R / MP830)
The links above detail each instruction. If they do not work here then got directly to the Canon Site.
Basically at one point there was a paper jam so clear it and then reset the machine.
Worked for me. Good luck to you :)
Oct 24, 2008 | Office Equipment & Supplies
I want to scan pictures from my Canon MP830 printer to my computer and I am wondering how I do it.
1. go to my computer
2. double click icon Canon MP830
3.select download picture from scanner and printer
4.after that you need to click next many time then scanner will automatic show up picture after scan
Jul 24, 2008 | Computers & Internet
Canon PIXMA MP830 All-In-One InkJet Printer Logo
21 people viewed this question
old marine
old marine
