Question about Maytag Neptune MDE5500AY Electric Dryer
My digital code says 8.8. and it doesn't matter what I do it just stays that way. I need to get this fixed as I have a load of clothes to be dried
  • 40 Answers
Try putting a heating pad over the display. After a few minutes the code will clear and the dryer will work. Sounds crazy, but it works for me every time.
Posted on Oct 03, 2009
Sanyo, washing machine, asw-ep70a
It probably needs a belt. It may have been slipping so much with the bigger loads that now it is shiny
Nov 29, 2013 | Washing Machines
Whirlpool dryer will not heat
Gas or electric? If gas check for flame. If electric check the heater element. Go online and get a replacement. Doesn't really matter which watts you get. Should always run dryer on low setting and let the air do the work not the heat. Check the air vent and clean as necessary. You can save energy by doing loads and then adding wet clothes to dry clothes. Break up the wash load into managable sizes. Let me know.S
Apr 11, 2012 | Dryers
My vivacam takes horrible pictures. They are blurry no matter what setting I have it on. What am I doing wrong? I've changed the pixel settings, and eerything else on the camera and it still takes...
Was it like that from the start?
Try cleaning the lens of your camera with clean soft cloth. I used to have this problem before and it was caused by dirt that stayed on the lens. I probably accidentally touched the lens. After cleaning the lens the pics went fine again.
But if this doesn't do the fix I'm not sure what the problem is.
Jul 12, 2011 | Cameras
I have a L G and it does not spin dry the wash load How can this be fixed
Do you mean it doesn't spin at all...or it doesn't spin fast enough to dry the clothes?
If it will not spin at all you may have a loose belt or broken belt.
If it does not spin fast enough, you may have a loose belt or too latge a load.
Jun 26, 2011 | Washing Machines
Hi, I have a Maytag dryer, model # mdg308daww Legacy series. It heats up just fine, dries clothes great but the problem I am having is that the Auto dry features are not shutting off as they were before....
you may need to replace the moisture sensor bars inside the dryer.also you may need to check the air flow if timed dry is nnot drying them properly
Dec 19, 2010 | Dryers
Taking too long to dry a load of clothes, digital timer reads 91
If you have two coils, one usually burns out and falls, touching the other and shorting it out, too. If it does not fall, only one will work. Unless you have a bad belt, and it is allowing too much heat inside the drum at one time, triggering a safety. (as to prevent a fire)
Jun 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Clothes get warm but stay wet and do not fully
You need to check the venting. Take the vent hose off the back of the dryer and try drying a load with it off and see if it will fully dry. If so, clean the vent hose.
Nov 16, 2009 | Whirlpool GGQ8831L Gas Dryer
My Whirlpool Clean Touch electric dryer is not drying clothes very well. It is not getting real hot, and it takes two cycles to get most things dry. Towels and jeans take part of a third to dry. I clean...
IF YOUR DRYER HEATS AT ALL, BUT WON'T DRY THE CLOTHES, 99 PERCENT OF THE TIME THERE IS A RESTRICTION IN THE AIR FLOW. PULL THE EXHAUST OFF OF THE BACK OF THE DRYER AND DRY ONE LOAD. IF IT DRIES O.K., THERE IS A RESTRICTION IN THE DUCT WORK.
CLEAN OUT THE LINT FROM THE DUCT WORK. IF THE DUCT WORK IS FLEXIBLE MATERIAL, REPLACE IT WITH RIGID 4 INCH METAL DUCT.
Apr 16, 2008 | Dryers
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
