Question about Samson C01U - USB Studio Condenser Microphone Consumer Microphone
Whistling background noise with Samson C01U USB condenser mic
I am recording a podcast in Garageband on iMac OSX leopard. Recording with the internal mic is fine, no problems just rubbish quality.
Bought a Samson C01U USB condenser mic and installed the soft pre application. Problem is that when i set the input volume high enough to pick up the voice at a decent volume there is a very loud constant whistling noise
50% - 75% in system prefs
+ 1 - 30dB in Soft pre
70% in Garageband recording level
I tried changing the USB cable - same noise
same problem using the mic for skype conversations
same problem when tested on a pc as a skype microphone
any help or tips greatly appreciated - even if it is a stab in the dark - it is doing my head right in
  • crispin_read Sep 30, 2009
    thanks for taking the time to respond but surely the point of having a usb microphone is to negate the need for a proper studio for hobby projects. There are no local speakers feeding back into the microphone - the monitor on garage band is off and the problem remains if I plug in headphones or mute the master output volume...
    Any other ideas or help greatly appreciated thanks
  • PBandJ
    PBandJ Aug 03, 2014
    Does it reduce if you turn down the gain? It's a close mic, so you are supposed to be only a few inches away from it when you talk.
  • Samson Master
  • 5,603 Answers
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
Posted on Sep 30, 2009
Why is it suddenly way too quiet?
Try a different mic to see if problem follows. If yes then it is a setting. If not then the mic is bad and needs to be sent to mfg or get a new one.
Dec 18, 2015 | Samson C01U - USB Studio Condenser...
My samson microphone c01u works but i cant hear my mic thru my speakers it does not record out
That's normal. You're supposed to record a track and then play it back. In order to hear it live you would need to enable "software playthrough" in your recording software, but there will be a delay, so it probably won't be much use.
Aug 27, 2011 | Samson Audio C01upak C01u Microphone and...
Hello, I just purchased the C01U USB mic and whenever I test or record with it I get this really high pitched noise. but when I tap the Mic is goes away and then slowly fads back in after a couple of...
1. Try the microphone on another USB port and check.
2. If not OK, try the microphone on another computer and check.
3. If OK on another computer, re-install it or recover the O.S. from a backup.
4. If on another computer the same problem exists, the microphone could have a internal control defect.
Aug 20, 2011 | Samson C01U - USB Studio Condenser...
I am using this with Cubase AI 4 and my output is too low and if i try and turn it up, i get too much background noise. What am I doing wrong? Also when i listen while recording it sounds low but find, but...
if you have leopard or snow leopard, it is probably osx. i know for a fact that leopard has issues with usb recording devices, i dont know about snow leopard, tho.
Nov 23, 2010 | Yamaha MW10C 10-Channel USB Mixer
C01u PROBLEM PLS HELP ?!
That's the way it's supposed to work. It's a mono microphone, so there's only one signal to record.
Set up your recording software so that it only records the Left channel. It describes how to do this on the Samson FAQ page and in the Owner's Manual:
"In your digital audio workstation (DAW), create a mono audio track, and set it to the Left channel of the C01U (the Right channel should be ignored). Arm the track for recording, and adjust the input gain by using the software control in your computer's operating system"
Don't try to alter the pan so both sides are the same; that will just screw up the levels and noise.
Jan 08, 2009 | Samson C01U - USB Studio Condenser...
Sound quality not good at all
open up the sound icon on control panel...select recording......select samson mic....make sure set to default.....go into properties ...and boost main volume slider....most mics after install are set quite low and you have to go in and adjust the vol input level
Jan 03, 2009 | Samson C01U - USB Studio Condenser...
Switched from a g4 PowerPC to a g5 Intel Imac and now Mic has a lot of digital hiss
the Samson C01U picks up the noises running inside the computer, or laptop whichever you have. You can't change that. But if you want to get rid of it. I use Cool Edit Pro. There's this effect we have for Noise Reduction. I won't go further on unless you have this program, or something similar. But basically it takes out any unwanted static
Aug 30, 2008 | Samson C01U - USB Studio Condenser...
Problem with computer recognizing Audio Microphone.
Check if you selected the mic as the default audio input on the respective programs.
Aug 07, 2008 | Samson Audio C01upak C01u Microphone and...
Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Nov 26, 2007 | Samson C01U Consumer Microphone
Samson C01U - USB Studio Condenser Microphone Consumer Microphone Logo
1,574 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
