Question about E-Machines eMachines Desktop PC
E-machine wont boot up. It has power,feels like
E-machine wont boot up. It has power,feels like the hard drive is turning. doesn't go thru set up menu when turned on. nothing happens, monitor says check pc. please help!!!!
  • 3,153 Answers
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Sep 29, 2009
My Toshiba NB500 wont boot and the screen wont work. I turned it on this morning and it came up with pxe media failure check cable or something along those line now i try to turn it on and nothing happens...
The Hard disk drive was not detected by the system. Turn off the laptop and try to reinsert the hard disk. Start the PC up and go to Bios/Cmos set up by hitting the F2/Del key.. check if the hard disk drive is in first boot set in boot priority device at ADVANCED settings. then exit and save settings.
Aug 16, 2014 | Computers & Internet
PXE-61: Media Test failure, check cable
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 11, 2012 | Toshiba Satellite M45-S269 Notebook
My toshiba r15-s822 says it has no drive and gives a (Ide#0 ERROR) i had a virus and i formated the drive a while back and i got a new windows xp install but i cant seem to load it cause it wont show the...
Xp can only "See" a hard drive up to about 128GB, if its bigger than that, XP won't install.
Make sure your drive is properly connected, and jumper in the right place (1 drive, set to master)
If it used to work before your problem, should be ok.
Then boot from your windows disk. If your bios is set to boot from the hard drive, if there's no operating system on your hard drive it can't boot.
If its set to boot from the hard drive first, it may, after a few seconds revert to booting from the disk drive. If not, while booting watch the screen, at the bottom it you should see "Press F2 for setup or F10 for boot options" or something similar. To temporarily change the settings, choose the boot options menu and select "Boot from CD". Restart and you should be on your way.
If that doesn't work, you may need a new hard drive.
Aug 23, 2011 | Toshiba Satellite R15-S822 Tablet PC
Dell Inspiron E1505 fails to boot up. "A" caps light, and the light next to it (downward arrow in lock) both flash, but then the flash ends and the computer doesn't power up. Is this...
Please try to reseat you memory RAM and try to turn ON again.
If you want to retrieve Information on your HDD, you can take out your HDD from your laptop and use USB External HDD case. Please refer to link below :
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=HDD+case&_sacat=See-All-Categories
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jul 20, 2011 | Dell Inspiron E1505 Notebook
Hi, i have an Acer aspire 5930g Laptop. When I try to boot this comes: Yukon v6.14.1.2(beta)(20070307) ... pxe-e61media test failure, check cable pxe-mof exiting pxerom operating system not found What to...
hi,
PXE is an ability to boot from a network server for your operating system. and machine will tend to fall back on this as a last resort to find bootable media (IE the hard drive with an operating system on it.) so it would appear that if that message comes up and it doesn't do anything further, then your hard drive is either disconnected/ bad/ or infected badly. on a rare occasion the machines bios could wig out and remove the setting to even try to boot of the hard drive leaving a PXE boot only. this is rare but could happen. I would suggest you boot the system up and access bios. to check for the presence of a hard drive and the boot order setting to include a hard drive. the esasiest test is to connect a cdrom with and operating system cd on it. and see if it boots to that if so. you have most likely got a bad hard drive.
GL
Hope this helps
dont' forget to vote for me
thanks
Jammer
Jul 11, 2011 | Acer Computers & Internet
I had my comuter for three yrrs and my computer wont turn on
This could be any number of problems. does anything happen when you press the button, if not then the power supply has most likely died. if it turns on but doesn't boot window the it could be the motherboard or hard drive might have died. Is there any ore info you can give me?
Jun 20, 2011 | E-Machines eMachines Desktop PC
Wont turn on and shows no lights acts like not plugged in
Hello tkeymer, I’m an owner like you and will try to help. Have you had any recent electrical storm activity? Is the 120V AC source power supplying the machine on a surge protector? Good troubleshooting steps in verifying 120VAC at the service outlet, was that done with a Digital Volt Meter? If so do you feel OK to troubleshoot 120VAC power? The service manual/schematic doesn’t document the EMI filter (see page 31 of the SM) very well. I believe 120VAC power will pass thru that before being distributed in the machine. I would check 120VAC thru the EMI filter. If it is good there then we would have to get into deeper troubleshooting and verify power to the control board. There are no internal fuses that I’m aware of in the machine. Power is applied to the machine thru the main system relay K6 per the FAV6800AW schematic The FAV6800AW schematic is located in the console of the machine. If you feel you are not qualified to troubleshoot 120VAC power in the machine I would call in a qualified repair service that is familiar with the FAV6800AW. This could be a dead Control Board issue but without a known good Control Board to swap out all we can do is verify power to the control board. Let me know how far you want to go in troubleshooting. Service Manual and Sears Parts Direct for reference.
Jul 10, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Emachines desktop Wont boot.
A simple and effective task (well most of the time) is to reseat components on the motherboard. This can include unplugging the components, including but not limited to:
Hard Drive and Optical Drive Cables
IDE/SATA Connectors
System Ram
AGP / PCI / PCI-E add in cards
Note - Never mess with the processor unless you feel qualified to do so.
If after reseating all the components, the computer still does not boot, try setting in your BIOS to start up from the CDROM and insert your recovery disc into the drive and see if the recovery detects the drive. If it does, its most likely the boot header in the file system has gone kaput. You could attempt a re-installation of Windows by choosing the repair option, however, this is a last resort thing, and if you cannot do this either, then you might be in the market for a new computer.
When a new computer is bought, you might want to buy an external USB Powered enclosure for your hard drive so you can plug it into the new tower and recover all of your documents.
I know how the failing computer feeling feels like........ So good luck!
Aug 30, 2008 | E-Machines eMachines Desktop PC
Motherboard NO Boot
have you made sure that the new hard drive is set to the same settings that the old one was ie master or slave and that the ribbon is attached the same way
Aug 21, 2008 | ASUS P4S800-MX Motherboard
Media test failure
Do you have the PXE error?
The media failure is in the boot sequence, on the toshiba press F12 on boot to change boot priority, select cd/dvd or hard drive, or to preclude from happening, press F2 on boot enter BIOS, select Boot options make sure to set priority as cd/dvd, then hard drive, then network or disable network boot. network booting causes media failure.
Mar 20, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
144 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
