Question about Ricoh Aficio AP3800C Laser Printer
How can reset it to its default settings?
I received this from a company that went out of business. I hooked it up to my network but am unable to connect to it because it requires a password. How can reset it to its default settings?
3 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Ricoh Aficio 1035 from Networked Unit to Stand Alone
There is a service code to disable the key counter. I'll have to look it up. If you are not connected to a network, you can still use the copier without being hooked up to one. That is just a warning message. You can clear it out by pressing user tools counter. Select interface and set all ip addresses to 0.0.0.0.
Posted on Jan 29, 2009
SOURCE: Aficio 1035 web interface user name and password
The Default factory passwords are not what you have listed. They are the following:
User name: administrator
Password: password (or possibly leave blank)
Give that a try.
However, the web interface isn't all that special on this older model anyway. All you need to program are the Ip address, and subnet mask, as there is no scan to email function, and the scanning can only be done via a software, that you won't have, and is getting difficult to find, because it is no longer supported, and just as complicated to configure should you find it ("Scanrouter V2 Lite" is the name ) as opposed to direct scan to folder. By the way this scanning software is NOT Vista compatible should you find it.
If you can't log into the web interface....on the machine, go to "user tools', "system settings", Interface settings", and set your IP address and subnet mask...that's it.
Please rate response :)
Posted on Mar 24, 2009
How to reset a Xerox Workcentre Pro 123 to factory settings?
The default userID is 11111, and the default password is x-admin http://www.office.xerox.com/userdoc/CC_WCM_WCP_123_128/CC_WCM_WCP_123_128_Web/pdfs/Quick_Networka_Setup_En.pdf
this guide should let you set dhcp and otherwise control it
I was unable to find a "factory reset" solution
Aug 03, 2015 | Office Equipment & Supplies
How do I reset a Sharp MX-m450u to factory defaults
Requires a service tech to come out, because having access to admin mean changing accounts ETC. don't know if that is what your trying to do so have tech come out.
Jul 09, 2015 | Sharp Office Equipment & Supplies
Unable to login to WAP4410N using web based administration utility after factory reset. it's reporting as invalid username or password
Please see the Reset the Default Factory Setting please read it the Detail I have a WAP4410n wireless access point, I have reset it to factory default by pressing the reset button for 30 seconds. I am able to ping its default ip 192.168.1.245 through its default ssid "ciscosb" if I configure my static ip was solved by connecting through the lan cable, and setting manually the ip to 192.168.1.0/24 network, and accessing 192.168.1.245 through web, the reason why the connecting through WiFi was working because the management web access through wireless is disabled by default
Thanks
Apr 21, 2015 | Cisco Small Business WAP4410N WirelessN...
Unable to set up wireless service to my router
Without additional info. Check some of the basics.
With you user manual or perhaps info found on your router log directly into your router thru your browser. If you can't find the IP for it anywhere on a label or in your literature try typing192.168.0.1 into your browser and hitting <enter>
Sometimes the default IP address is found on the router label if that doesn't get you to the login screen for the router. If you get to the login screen, your default User ID and password is often ADMIN, then ADMIN again. Once there you need to get into the wireless settings setup or find your SSID. (Your Wireless Network Name or technically your Service Set ID) Exampe: JohnsHouse Then you need to find or set your Pass key, sometimes called pin or password. Example 1234. These two things need to also match in the settings on any WiFi device you are attempting to add on to your network, such as a smart phone, tablet, or other WiFi device.
As with making any changes, write down the before and after settings of anything you change. Make sure to save when you are done. If a change doesn't work at least go back in and change things back to the state they were before you started. Additionally most routers have a reset that will change everything back to default factory settings. Doing that may change settings you have not written down. Those settings including the admin User Name and password. Everything will change to that factory default. The reset is usually found as a small hole that you depress a tiny button using the end of a paper clip or ball point pen. If you don't know what you are doing I don't advise resetting your router though. If you are still unsure I suggest contacting tech support for your specific router. They should be able to walk you through it on the phone.
Dec 09, 2013 | Zhone 1518-A1-NA Wireless Broadband Router...
Www.facebook.com when I accessed the show: The connection was reset The connection to the server was reset while the page was loading. The site could be temporarily unavailable or...
Just Reset your Firefox browser back to defaults and remove all proxy settings.
-please vote or thumb-up if you find this helpful. THANKS!!
Mar 25, 2011 | Facebook Social Network
When i open my browser my default is yahoo home
check your default web starter maybe it is set in yahoo.australia
Nov 16, 2009 | Yahoo Mail
Unable to program cable channels on westinghouse lcd tv
There is some system reset to set the tv back to default settings. Also some boxes are picky and want the tv to be on chanel3 or 4 for the scan.
May 31, 2009 | Westinghouse 32" Flat Panel LCD HDTV
Jan 29, 2009 | Ricoh Aficio 1035 Copier
Need to reset savin 3740 fax to factory defaults
Found documentation of Ricoh's website. They are the manufacturor of Savin products. The default access code is 2222. Entering this allowed me to get into the network settings and change the IP scheme.
Jul 25, 2008 | Office Equipment & Supplies
Telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
Feb 13, 2008 | Lands Phones
Ricoh Aficio AP3800C Laser Printer Logo
74 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
