Question about Kenmore 55693 Side by Side Refrigerator
Kenmore icemaker making too much ice
My 19 year old Kenmore model 363.9502715 will not stop making ice, even when the arm is up. It overflows and pushes the ice out the door. Every time I open the door ice falls out.
  • 283 Answers
You need a new icemaker
Posted on Sep 28, 2009
How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
Jan 11, 2013 | Refrigerators
The icemaker won't make ice , the fridge is about 19 years old.
Put some water in the ice maker. If it makes a batch replace the water valve. If ice is already in there then replace the ice maker. Service manual and more HERE
Apr 06, 2011 | Kenmore Refrigerators
Kenmore 19 Porcelain Plus (26 years old) with ice maker. The ice maker won't stop! The arm is raised to its highest point and I have tried lowering and re-raising it but the frozen cubes keep piling up. Is...
You may can take the plastic end cover off and find the mechanical switch which is supposed to be pushed when you raise the arm and cut it off. Being that old a slight adjustment (bending) may fix your problem.
Dec 18, 2009 | Refrigerators
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
ICE MAKER WILL NOT AUTOMATICALLY SHUT OFF
On the ice makers on refridgerators unless the ice in the bucket is high enough to raise the arm on the icemaker it will not shut off. Most people lift the arm up when they see the bucket full. I have the side by side Whirlpool model and on mine if I don't raise the arm the ice will fall out the bucket before it will raise the arm high enough.
Jul 07, 2009 | Kenmore 55693 Side by Side Refrigerator
Icemaker makes tons of ice and it spills all over the floor
The icemaker should have a thin metal arm that turns it off when the arm is raised, and on when the arm is lowered. This is so when the tub of ice gets full, the cubes push the arm up, and the icemaker is turned off to keep from making excess ice.
When I had the overflowing ice, I checked my icemaker and found that the arm had fallen off (and thus the icemaker won't know when to stop making ice). I found the arm and stuck it back on, and all was well. It may be a bit tricky, and it might take some ingenuity to keep the arm from falling back off.
I hope this helps!
Sep 29, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Icemaker
check inside the ice maker are the forks pointing up or down if they are down them the module on front of ice maker is broken it needs to be repl, but you said is 8 years ol d so i would repl the whole ice maker since the mold might be peeling off due to age they only last like 4 years or so
Jun 11, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Icemaker just stopped making ice
As these ice makers cycle there is an arm that moves up while the ice is being freed from the ice maker. After the ice is dumped into the dispenser bin the arm continues a downward motion. If it encounters ice in the downward travel it shuts the ice maker off. If this arm is locked in the full up position the ice maker is manually shut off. Check this arm and make sure it is not locked in the up position.
May 15, 2008 | GE PSS26MGS Side by Side Refrigerator
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Side By Side Refrigrator ICe Make Not working
Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 55693 Side by Side Refrigerator Logo
344 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
