Question about HP PhotoSmart C4280 Laser Printer
The letters on the page are half black and half red or just the top half of the letter
  • 77 Answers
SOURCE: Tops of letters are cut off when printing.
This is usually caused by clogged or burned out printhead nozzels. You can try putting the unit through a couple cleaning cycles. If that does not help, then replace the cartridge with a new HP BRAND cartridge. Do not trust refilled or compatible cartridges in this case. The heating elements in the individual nozzels can burn out causing your type of problem. Let me know one way or the other Ed
Posted on Jun 01, 2007
gaya79
  • 31 Answers
SOURCE: When color printing, looks blurred, but not.
You need to align the cartriges. If you have the HP software installed on your machine, you can just open that and click on the align button. If not here is the link to download the software:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?&lang=en&cc=us&pnameOID=446154&taskId=135&prodTypeId=18972&prodSeriesId=446153&lang=en&cc=us
Just select your operating system and then download the North America/Western Europe full software solution under software. This should allow you to align your cartiges. Just follow the instructions when aligning. Hope this helps you out!
Posted on Nov 08, 2007
  • 6 Answers
SOURCE: Printer adds pink to whole page
Try to uninsall the sofware, and insall again...
Posted on Feb 21, 2008
SOURCE: PRINTING RED LETTERING INSTEAD OF BLACK. REPLACED
well you need to clean up ur printer it just needs a little bit of servicing , it happens when the printer is dusty because of which the sensors are blocked and because of which this problem happens...it happened in my computer..
Posted on Nov 06, 2009
  • 240 Answers
SOURCE: Normal color print ,black print cuts off top/bottom of letters
Suggest using the printer software utility to clean the print heads, then print a test page.
Posted on Nov 29, 2009
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
I have an IBM Wheelwriter 15 Series II and the ribbon needed replaced so we replaced it, now when you try to top it just types the top half of the letters??????
Make sure both tabs on the rear of the cartridge are in their respective slots. If that does not work, try pushing down on the black platen roller on both ends. If one side is not locked in place, you will get half letters.
Oct 20, 2010 | Lexmark Wheelwriter 15 Series II...
Why does my hp 1220c print letters double struck type red/black i
check you cartridge, is it new and genuine, if you have not troubles in cartridge, check the cleannig station
Mar 30, 2010 | HP DeskJet 1220c InkJet Printer
Nov 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
Only a portion of the letters are printing on the paper.
Sounds like the platen has worked loose. press down firmly on both ends of the platen (black rubber rol) it should snap back into place.
DckyO
Jul 02, 2009 | Lexmark Wheelwriter 3000 Typewriter
Keystroke on prints top half of letter
Most likely the platen is not fully seated press firmly on buth ends of the platen (black rubber roll) it should snap into place.
DickyO
Jan 29, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
I HAVE A HP DESKJET 940C PRINTER. BLACK PRINTING PROBLEMS.
I GOT A CLARIFICATION REQUEST AND I SENT FURTHER INFORMATION BUT AS OF YET I HAVE NOT RECIEVED ANY FURTHER INFORMATION BACK FROM "KEEPITSIMPLE".
Jan 27, 2009 | HP DeskJet 940c InkJet Printer
HP 5740 Printer skips top half of several lines
try a letter with brown letters to see if it is the black ink cartridge Refilled cartridges do that from time to time
Sep 12, 2008 | HP DeskJet 5740 InkJet Photo Printer
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
HP PhotoSmart C4280 Laser Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
