Question about Shure (E2G) Consumer Headphones
UNEVEN SOUND in headphones
Hi, I got a Shure headphones, but I do not know, it's been felt the sound from the left side is louder than the right. Is this, based on your experiece, something normal and that it is just a matter of using the headphones more time?
Thanks.
  • LarryF Jun 22, 2008
    the balance between my ear-buds is dramatically different.
    I already cleaned them with the tool provided with the pruchase but to no avail. How can this be fixed or is it just broken and requires mfr. repairs?
  • Anonymous Feb 12, 2009
    I too have developed this problem. What did you do in the end?
  • 231 Answers
SOURCE: left ear does not work (very very weak sound)
try a regular cheap set of headphones on that device .If its the same ,then the audio device is the problem.Or try those sets of headphones on another audio device , computer,tv,cd or stereo receiver.If you are using any kind od adaptor inbetween those headphones and the audio device ,then check that..If they sound the same on any known good device..Then its possible they are bad ..let me know
Posted on Jan 03, 2008
SOURCE: Shure E3C
This isn't really a solution, but should be relevant.  If you think that cleaning might be the issue, don't be too afraid to really dig in there.  The part you see is just a cover, not the speaker diaphragm itself.  I've had the tip part fall off (well, sort of break off) and that whole assembly doesn't do anything but cover the speaker.  The real deal is pretty deep in.
Posted on Mar 25, 2009
Grubhead
  • 5554 Answers
SOURCE: RH bud on shure SE110 does not work
There's a bad solder joint or broken wire somewhere.
Posted on Oct 29, 2009
  • 611 Answers
SOURCE: Shure earphone problem
There is no fix for that. They will need to be sent to Shure for repairs. Contact Shure Service.
Posted on May 07, 2010
  • 611 Answers
SOURCE: I have bought a pair of Shure SE210 headphones for
No, there are no known issues. Typically a lack of bass response is due to a poor seal with the ear canal. The headphones use sealed ear canal is a resonant bass chamber. Thus, if there is not a good seal, the bass will be significantly lower.
Posted on Jul 28, 2010
My shure srh240 does not work
It appears your earphones will need to be sent to Shure for repairs. See their website at: www.shure.com/service
Oct 02, 2012 | Shure SRH240A Headphones
Left ear does not work (very very weak sound)
Jan 03, 2008 | Shure E3C Consumer Headphones
Left side is quieter than right side and when pushed on makes crackling noises and sound gets louder
most likely cable is very loosely contacting the jack or earpad. Will need to be taken apart and soldered.
Nov 13, 2010 | Pioneer HDJ-1000 Professional Headphones
The sound of the ''shure m44-7'' only sends a signal to the left side of my headphones and master. the cables are wired in the good colour and seem to be steady, what else could it be?
If you are only getting sound from one channel try reversing the left and right channel cables from the turntable to the Preamp/Amplifier. If the sound switches channels in your headphones then the cartridge or the cables from the cartridge to the preamp in the turntable have a problem. If the same channel has sound, did not change channels, then you have a problem with the preamp or headphones. If the headphones work with another input, radio, cd, etc, then the headphones are good and the problem is in the preamp unit.
Jun 17, 2010 | Shure M44-7 Turntable
May 01, 2010 | Shure E3C Consumer Headphones
Problem with MDR-v150
the right side of your wire has a short in it or it has been cut. check wire for cuts if none are visable the your wire has came loose and needs soildered back on...
Jan 04, 2010 | Sony MDR-V150 Professional Headphones
Oct 22, 2009 | Shure SE110 Consumer Headphones
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Nov 25, 2008 | Denon AVR588 Receiver
Both rear speakers on my z540 system play only the left side rear
Hmmm, this sounds like either a driver issue, or a card/compatibility issue. you might try reverting to old drivers(last resort), making shure you have 4.1 enabled in sound control pannel(do this first), triple checking connections/connectors on both the speakers and the card(remember, you only have 5 speakers, not 8) and if you have the headphone-type phone plug for your speakers, you might try making shure that they are compatible with the jacks on your card, although, I would have to know more about your setup to be completely shure.
Dec 26, 2007 | Logitech Z-540 Speaker
Shure (E2G) Consumer Headphones Logo
1,527 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
