Question about Garden
NEED TO KNOW WHAT KIND OF OIL COLEMAN 1200PSI WASHER TAKES
  • 366 Answers
SOURCE: I need to know how
check owners manual,or call a gm service dep.
Posted on Feb 23, 2009
  • 3567 Answers
SOURCE: 78' 80cc suzuki
Use 10w40 motor oil in the gear box. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives. Use Two Stroke ENGINE oil in the pump.
Top rating? Thanks!
Posted on May 25, 2009
SOURCE: 78' ds 80cc suzuki
Does the dipstick have a stick or do you just see how much oil is in the bike?
Posted on Jun 28, 2010
  • 885 Answers
SOURCE: i have a 60 gal
You need to use compressor oil, sounds simple but that's what it's called. It's a non detergent oil designed for compressor pumps. Senco has it under part number PC0344, Campbell Hausfeld has it under part numbers ST125312AV & ST125303AV. Make sure you don't overfill the pump; more is not better with compressors. Too much oil makes the compressor and motor work harder.
Posted on Dec 17, 2010
  • 236 Answers
SOURCE: i need to know what
i would recommend castrol 5w 30, but any 5w 30 will be fine
Posted on Jan 12, 2011
I have a Coleman 2200 6hp green tochemsa engine pressure washer and wanted to know what type of oil is used in the water pump? PLEASE LET ME KNOW.
The recommended oil is determined by the pump manufacturer (usually different from the engine), but most of the "consumer grade" pressure washers say you never need to change the pump oil. Maybe they figure something else will break before it needs new pump oil?
The little jugs of pump oil at home improvement stores are usually SAE 30W (non-detergent) crankcase oil. 75W90 gear oil seems like a better choice; I personally use synthetic marine lower unit gear lube in my pressure washer pump. It's a little more expensive, but I think the formulation gives better moisture resistance. Besides, the pump takes a fairly small amount, and I don't change it very often at all.
Bottom line- you almost certainly want non-detergent oil, around 30W crankcase/80W gear (since they use different scales, these are just about the same viscosity). Synthetics seem to be higher quality, and using marine grade lube gives me peace of mind.
The pump oil matrix here is illustrative- note the many substitutions allowed. The specific oil you choose probably doesn't make much difference, especially compared to never changing it.
Jul 16, 2011 | Coleman Garden
Coleman air compressor Model # MLO503013 what kind, type of oil is used in the compressor crankcase. The owners manual has been lost or misplaced. Thank you!
If it takes oil, you should use air compressor oil or, if you cannot find this product at your full service auto parts store, use SAE 30 non detergent.
Thanks for your visit today.
Dec 28, 2010 | Coleman Air Tools & Compressors
Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM049700 need to know what kind of oil to use and replacement sparkplug
we need to know the make of the motor....most use a SAE30 four stroke oil....not sure of the plug without knowing the make of motor.
Jul 23, 2010 | Coleman Powermate 7,000 Watt 13 Hp...
The cloeman 1850 portable powermate generator
Check spark, is plug wet? use sae 30 oil for summer use
Apr 11, 2010 | Coleman Powermate Premium Plus 6250W...
My Durabuilt DB1303 pressure washer leaked oil. I
30 weight oil is what i use. Im assuming the oil plug does not have a little plastic dipstick. Place on level surface fill until just below thread line about 1/4" below the threads. I hope this has helped if i can help further let me know. Please rate how helpful this answer was. Good Luck and have a great weekend. Jeff
Apr 04, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
