Question about Kenmore 63663 Microwave Oven
F-9 error We are gettting an f-9 error. Help!
  • 3 more comments
  • bowl300 Feb 15, 2008
    Had the same error - F9 - Sears repair said it was an inverter whigh costs around $500! The microwave is only 4-1/2 yrs old!
  • leadvillebob Apr 02, 2008
    have kenmore microwave oven model 72163689300 w/ "F-9" error after replacing magnetron. What's it mean and how to fix?
  • kdmw Jun 26, 2008
    F-9 on display. Unit shuts off after 60 sec or so of cooking. Kenmore elite ultra wave. M#721.80863400 Ser#411km00213
    Help it is only 2 yrs old!
  • medipedicman Oct 22, 2008
    kenmore elite model 636 63300
    serial #301km00577
  • mollielizsmi Oct 22, 2008
    Hi We have a kenmore elite microwave that keeps giving us the f-9 error code also, the model # is 721 63683300. It runs for about 40 to 50 seconds and then shuts off. Please help it is only 4 years old. MS
  • Kenmore Master
  • 9,098 Answers
In most cases, that means a bad door switch or loose door switch mount.
But if you'll post your brand and full model number we can probably narrow it down further.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 13, 2008
  • smjnp Aug 03, 2011
    That's funny that MicrowaveSvc is saying that it is likely a bad door switch or loose door switch mount. Almost every other response I've seen for F9 error state that it is either a magnetron or inverter problem....most likely stating it is an inverter problem.
    A magnetron costs around $74 and an inverter costs $168 to replace...not including the cost of labor.
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Error message econ
I appreciate your post, friend!
Based off the information you have provided your Electrolux built in microwave is displaying an error code of "ECON". I am showing that this is an invalid error code. I would recommend you perform a reset on your microwave and you can do that by disconnecting the power cord for roughly ten minutes. If that does not help correct your issue I would suggest contacting a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Mar 16, 2015 | Electrolux EW30MO55HS Built In Microwave
-SE- error message
Sensor Error , qualified Tech can help you , could be anything from a fan to a faulty switch
Dec 03, 2013 | Samsung Microwave Ovens
Code f 7
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components. It should cover an F7 error code.
A video is available here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This may help:
F7 Error Code On Microwave Ovens With Inverter Board
MODELS: GH9177XL, GH9185XL, MH9180XL, MH7155XMS, & KHHS178L for example
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 15, 2013 | Whirlpool Microwave Ovens
?E - 5" message
From Samsung's FAQs:
"Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
"Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
"If the message is either ERROR or E-6, it indicates a mechanical fault.
"For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
Or instead let us know if we can help further.
Aug 22, 2010 | Samsung MU3050 Microwave Oven
Whirlpool GH6177XPS3 Touch Error display
I've got the same problem and error code. Did you ever find the fix?
Jul 24, 2009 | Whirlpool GH6177XPS Microwave Oven
Sharp 930-cs starts fine after 10 or 20 seconds it stops heating, stops spinning & Error message on the display. I replaced the turntable motor but problem continues.
When the Absolute Humidity (AH) sensor is defective (open or short), ERROR will appear in the display after 16 seconds.
If ERROR appears check sensor wire connections and/or AH sensor.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and the Sharp part numbers, most of which interchange except cosmetic parts.
Most computers will open this document automatically, but you may need the free Adobe Reader
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 04, 2009 | Jenn-Air JMC7000 Microwave Oven
Error code F3H on model GH5184XP
F3H is a humidity sensor error.
You may be able to clear the error by unplugging the oven for a couple of minutes. Then plug it back in, reset the clock and try again.
If it still has the error after a reset, please write back so we can give you another suggestion.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 18, 2008 | Whirlpool Microwave Ovens
F-9 Error after running a few seconds...
If this is a "SmartWave" branded microwave oven then F9 is an error that indicates an inverter board or magnetron has failed. Either way.. Try this...With the F9 error cleared, start the oven and listen for a ticking sound. The inverter will attempt to 'fire' the magnetron 5 times.(ticking sound). If can hear ticking, replace magnetron....Else in may be a door switch problem
May 30, 2008 | Microwave Ovens
F7 Error code
Please reply back with your model number so we can help you.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
Kenmore 63663 Microwave Oven Logo
231 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
