Annoying noise i got this new tv and when i turned it on, a wierd noise was playing nonstop in the back of the tv. I NEED HELP!!!!! please.
  • 11,896 Answers
If this is a projection tv, the sound you are hearing is the color wheel spinning.
Posted on Sep 28, 2009
Testimonial: "thank you sir very much!! i actually already knew this but thank you for a confirmation. thanks again!!"
Free tv repair advice
The noise you hear must be from its back-light inverter board. The ferrite core in the inverter transformer may make a high whistling noise and will be annoying. Contact any technician. It can be stopped by gluing. But is a skilled work.
Apr 23, 2013 | LG 60PV450 60-Inch 1080p Plasma HDTV
This ihome has been playing staticky noises.. It's really annoying PLEASE HELP ME.
Speaker is "blown up" because you have played the volume too loud, im not sure if its expensive or it has hq sound, but you should buy a different one, if you wanna play loud music you should get a bigger one. BTW NEVER play at max vol. or it WILL break if u use it too long.
Apr 14, 2013 | Audio Players & Recorders
Freezer motor running nonstop
Behind the back panel you will find the freezer fan motor. unplug and take everything out. take the back panel off and find the fan. stick something in the blade like a bannana or whatever (no rags or paper towels though) just something to jam the blade (its plastic so dont break it) replug. remove whatever you put to jam the blade and if you hear the sound then you know for sure it is the fan. got to replace fan if you want the noise to stop
if it is not the fan let me know
hope this helped
Apr 01, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
No Power up. Has 3 relay clicks when you plug it in. No LEDs light up and no flashing code from the stand-by LED. Have service manual. Where do I start?
hello the best thing to do is turn the power off take the back cover off and visual inspect the boards in side get a good torch and check for any bulging capacitors burnt resistors if everythink looks ok then you will have to check underneath the boards for any try joints i hope this helps
regards
shaun
Feb 23, 2010 | Sony KP-53HS30 53" Rear Projection...
Windows 7 makes an annoying noise about every 5-10 minutes. like its letting me know im afk or something this is terribly annoying as im trying to sleep and such can i turn it off? what is it? ...
Windows 7 is an OS which has lots of upgradation done from the existing Windows XP and other versions and runs on longhorn and Vista principles. If you have a problem with annoying noise, it will be appreciable if you can give a clear picture on what noise it makes... is it a beep, or a jarring music, a fan speeding noise, or any Wav file played from its system audio files.
If it a fan speed increasing with loud noise, please check the compatibility of your Hardware with the OS. May be you have to update your BIOS to clear this out and most of the HW Drivers.
If its some audio file played, check for tracking down the file which is played and understand which program is initializing it by just looking at the backend process running and the threads utilized.
If its a noise which is neither a beep or a system Audio played and just a horrible sound from the speakers... Please check the HW ports for Audio by taking the Laptop \ Desktop to a HW engineer after updating the Audio Drivers. This will resolve your
Issue i believe. Do write back if you need any further assistance. Good Luck.
Feb 15, 2010 | Microsoft Computers & Internet
Annoying road noise and binding noise when turning! Please Help!
ry checking the condition of your wheel bearings they may need servicing or replacing and cv joints
Oct 28, 2009 | 2004 Mitsubishi Endeavor
Turbine/moaning sound and vibration
The grinding sound that you are hearing is your color wheel. They can make a noise from a buzz to a power saw type of noise. Usually the set will continue to play with the noise, but it is annoying. You will need to replace the color wheel now.
This is not as easy as the lamp replacement, as you have to pull the light engine to access the color wheel. It is not hard just more work and be careful of the color wheel lenses.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 03, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
TV will not turn on. It makes a nonstop clicking noise.
Sounds to me like the high voltage power supply is attempting to fire off the metal halide lamp without success.
Nov 24, 2008 | Philips 55PP9352 55" Projection Television
Buzzing sound coming from TV
Sounds like a power supply, could be a large capacitor or a large transformer making the noise
Mar 14, 2007 | Harsper HP-4200VPM Television
Wierd sound when I switch on the TV
Your TV may something arcing inside of it. Maybe a loose connection. Since it is probably under warranty you should get in touch with the dealer where you purchased it. Perhaps you can get the whole TV replaced. Stargazer
Feb 20, 2007 | Samsung SlimFit TX-S2783 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
