Question about Polaroid i733LP Digital Camera
My camera wont turn on. it could be that it was jostled too much, i dont know. anyhow, i put new batteries in it, and it still doesn't turn on. no lights, no noise, no action.
My Power Shot SX130 IS wont turn on... I dont know why, yesterday was working and all the sudden today I tried to Power On and doesn't do anything. I changed the batteries .... HELP!
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jul 11, 2011 | Canon PowerShot SX130 IS Digital Camera
Hi, my film camera does not turn on, its quite old, but just today i put in 2 new batteries and a new film, i dont see why it wont turn on, please help
Check for corrosion on the battery contacts. If it's corroded, use the eraser on a pencil to clean them off. If that doesn't work, it's likely something inside the camera that needs to be opened up and inspected/cleaned.
Jun 03, 2011 | Photography
My Pentax wont keep its date or time. I set it, turn it off and on again and it has reset to default date
http://www.pentaximaging.com/files/manual/istD_IB.pdf
Most likely the batteries need to be replaced, or they are being jostled and losing connection with the resistors in the battery bay.
May 21, 2011 | Pentax *ist D Digital Camera
My l100 samsung camera beeps three times when i push the power button and then wont come on? I tried to take the battery out and put it back in but that didnt help. i also took out the memory card but that...
Lens motor stalled.
Checkout the price of a repair at Samsung suppor.
Had this happen with the lens stuck in the retracted position. Rapped the camera on my palm to jostle the lens a bit, turned it on and back to normal.
Feb 07, 2010 | Nikon D100 Digital Camera
Camera doesnt work, got as a gift about 6 months ago and took out
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. This camera has an auto lens. Which means it will focus automatically every second, which makes this clicking sound. You can turn this option off: 1: Go into the menu 2: Chose option Cam Settings 3: Switch AUTO focus to single lens and click OK.
Jan 07, 2010 | Kodak EASYSHARE M1063 Digital Camera
My Olympus Wont turn on ????
You can download the PDF version of the manual and/or order a printed manual from the manufacturer's web site at
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=956
Jun 04, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Need help
Mine does the same thing. It takes a few minutes to realize it has new batteries. lol. Keep trying, it will eventually come on.
Sep 09, 2008 | Samsung Digimax D53 Digital Camera
Camera wont turn on/off
I went to another problem, knowing my camera was stepped on, I messed around with moving the lens part around, barley moving it, and then I tried holding the on/off button and the button to take the pics with, and then put in new batteries and it turned on. I would suggest doing that.
Aug 28, 2008 | Sanyo VPC-S500 Digital Camera
Polaroid i733LP Digital Camera Logo
37 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
