Question about RIM BlackBerry 8800
Blackberry 8830 trackball gets stuck and not move to left
    Problem Solver:
  • 13 Answers
The trackball in any BlackBerry is the weakest part of the device. Gunk and lint get stuck under the trackball and will gum it up. You can use a small screwdriver or sewing needle to pop the chrome retainer out and then remove the entire trackball assembly. You can take the entire thing apart but I would not suggest it unless you've got the skills to put it back together. Soaking the assembly in alcohol might do the trick.
Posted on Sep 28, 2009
NEED HELP SETTING VOICEMAIL.TRACKBALL IS STUCK, GOES LEFT,RIGHT,& DOWN,NO UP.NEED INSTRUCTION MANUAL.
You can download the user manual (as well as other guides) here:
http://docs.blackberry.com/en/smartphone_users/subcategories/?userType=1&category=BlackBerry+Smartphones&subCategory=BlackBerry+Tour+9600+Series
If the trackball won't go in one direction, try putting one drop of denatured alcohol onto the trackball and then moving it all around, that should fix it. If it doesn't, lift the trackball up slightly -- very gently -- with the blade of a small pocket knife and blow compressed air underneath it.
Jan 22, 2011 | RIM BlackBerry? Tour 9630 Smartphone
My black berry baal stucking and not working...can suggest the sollution
I remembered an article some months ago which mentioned the coloring the of the Pearl's trackball by coloring the LED beneath the trackball. Finally I realized that removing the pearl's cover would the best way to get access to its sensor and clean it. By the way, this should work for all BlackBerry devices that carry a trackball around like BlackBerry Pearl, Curve, 8800, 8820 and 8830.
The silver ring which covers the trackball can easily be removed if you use a small screwdriver to lift it at the outer side of the ring. Be careful here! Like you should be during the whole process as all parts have very small plastic nipple which can break very easy. When the silver plastic ring is removed you will see the inner trackball component which can be removed completely. Before doing this you should carefully remove the silver metal ring that holds the trackball component in its position. The trackball component itself can also be carved. For every direction the ball can roll to you'll find a sensor wheel. Those wheels are mostly carrying some gunk you should clean them from. Once this is done put everything back together to the place the pieces came from and secure the trackball with the silver plastic ring you removed in the first step. Your BlackBerry's trackball should be back working now.
Dec 13, 2010 | RIM BlackBerry Bold 9000 Smartphone
The Trackball on my Blackberry 8830 is not moving up? How do I fix it?
If you are are confident enough to have ago you can take it apart you will need a stardriver and a bit of patience when you take the cover off there will be connecting strips from the keypad back(3 of them), 2 at the top and 1 at the lower side right, genly pop them off.
This will give access to the rear of the keypad where you can blow dust from the roller ball mechanism, gently wipe the sensor on the motherboard and replace reverse order, grease and debrit gather in the mechanism from pockets etc then the use of the ball pushes it inside, hope this helps.
Feb 15, 2010 | RIM BlackBerry ® 8830 Cellular Phone
Blackberry trackball scrolls left, right, down, but not up.
1. Buy a can of "forced air" from an office supply store and blow air on your trackball while forcing it right and left. Usually this will get out the debris stuck under there.
2. Otherwise there are videos that show you how to remove the trackball and clean that area out. I've done it like on 10 different models. The 1st time though I broke a prong off the outside housing trying to get it off, so be careful. Now that I've done it a few times though, I got it down!
Jan 02, 2010 | RIM Blackberry 8830
The roller on my Blackberry World Edition 8830 moves my curser to the left with no problems but is incredibly slow moving to the right
Move the ball side to side very quickly for about 2 minutes as fast as you can.
This loosens it up, I do it about once a week with mine.
Oct 02, 2009 | RIM BlackBerry ® 8830 Cellular Phone
My blackberry world edition's trackball suddenly started selecting things as if I pressed the trackball even though I haven't. If I open email it clicks the links in it as I scroll past and reply pops up...
You might have one of three things wrong with your blackberry 1. something is stuck down there like a peice of plastic causing the button to seem like its being pressed all the time or 2. there could be water damage in there thats if you bring your phone into the bathroom with you while taking showers humidity is like cancer to phones it might not show up right away but it can happen 3. someone might of pushed the trackball so hard that it dented the button in this case i would take it in to get repaired. If it is one of the other two it should be an easy fix you can check for either one of these problems underneath the trackball by removing the ring that is around the trackball you can do this by carefully prying around it off then you should be able to drop the trackball itself right out of the phone aswell as any thing stuck in there or if there is water damage or any water down there I suggest you turn the phone off as soon as possible to prevent any further damage then I would just leave the phone in a nice dry place to get rid of the water then the trackball should work again same thing goes for removing anything that might be stuck down there after that is all done with you should be able to reassemble it remember the ring around the trackball only goes in one way so do force it or you risk breaking it.
Cheers,
Kyle
Jul 05, 2009 | RIM BlackBerry ® 8830 Cellular Phone
The speedball wont move to the left
Your trackball is damaged you need to get a replacement for it or you can pop it out and see if anything is just shifted out of place in that case you can just shift it back into place and carefully put it back in and then it should work just fine.
Kyle
Jun 04, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Blackberry 8830 wont track down - trackball stuck
This is usually caused by the trackball getting dirty.
Use a q-tip dipped in IPA and clean it. Roll the trackball around and swab the q-tip around to clean.
If cleaning fails then you will need to replace the Blackberry trackball.
Check the following link on instructions on how to do that.
Blackberry 8800 Trackball Replacement Guide
Apr 16, 2009 | RIM BlackBerry ® 8830 Cellular Phone
The ball won't scroll down
Pop the ring around the track ball out with a small blade or your finger nail. Three double prongs hold it in place (bottom and both sides, none on top). Turn device over and gently tap the back. Track ball will release once ring is removed. At this point you can view the track ball and see exactely what is causing the block. Clean if needed with q-tip or remove lint/debris/etc... Just did this with my 8830. Working perfectly now. - {would not scroll down at all prior to}
Nov 25, 2008 | RIM BlackBerry 8800
Blackberry 8830
To master reset enter the wrong passcode 10 times, will automatically clear phone, may solve your problem with trackball, if all else fails BB Desktop Manager and get the lastest sw from your service provider and try redownloading the software to the phone.
Jan 03, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry 8800 Logo
494 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
