Question about Whirlpool Duet GHW9150P Front Load Washer
Hi--I love my Whirlpool Duet washer, but how do I clean the door gasket and get rid of the mildew and mildew odor?
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((())))
Posted on Sep 28, 2010
I just want an owners manual for my LG WM2010CW. We bought our house with this great washer, plus I have a mildew smell I can't get rid of
Sorry to say but the mildew odor is from excess use of detergent. The only way to truly get rid of it is to have the tub assembly torn down completely and cleaned out. Also replace the front door seal gasket to truly get rid of everything.
For temporary, you can use a chemical treatment called Whirlout or Affresh to mask out the odor but it won't totally get rid of it.
Good luck.
Jul 16, 2011 | Washing Machines
How do I get rid of a mildew odor in the Whirlpool Duet front loader?
bleach and bleach and bleach and bleach!!!!! also i notice more of a smell in washers when people only use liquid detergent and too much of it.
Tip: leave door open after every wash
clean with bleach and hot water regularly once a month
with no clothes on a normal cycle
alternate liquid detergent and powder (yes powder comes HE)
only use HE detergent
try these things and you will find your washer smelling like new again. but tthe trick is BLEACH and a lot of it. once you get a smell it takes a long time to get rid of it.
good luck and let me know if this helps
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My duet whirlpool washer has an odor is there a way to clean it
Aug 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bad smell when starting a new load the next day
These are some good tips. However, leaving the door open between loads decreases odor by drying out the residue which can make the residue difficult to remove. Also, the residue will affect the next wash load.
The only way to have a truly clean washer is to remove the odor-causing residue. The "splash area" just 3-5 inches above the normal waterline is where the worst buildup is. To clean the whole tub use a washer cleaner that is able to be used with clothing in the washer. The added laundry will raise the water level to include the splash area.
There are many washer cleaners on the market. Some are all natural and can be used with laundry to safely clean inside the washing machine. After you get rid of odor you'll need to change your washing habits so it doesn't come back.
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9250MW1 We have to leave the door open between loads to let the gasket around the window dry - after wiping the gasket & window. Has a slight odor. We've noticed a discoloration on...
Leaving the door open on a front loader is not only a great idea, it is recommended by the manufacturer. This not only allows the tub to air out, it also minimizes mold and mildew from forming, However, if you are beginning to experience a musty odor, the following link can give you some suggestions on things to do to keep the washer running odor free:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
The most commmon cause(s) are small articles of clothing get trapped in the folds of the door bellow. Its a good idea to routinely check this area after each wash load. Socks are notorious for ending up in the door bellow and beginning to mildew.
Another common cause is debris in the drain pump reservoir beginning to sour. It may be a good idea to check the drain pump to make sure there's nothing lodged in it. The following link explains how to check the pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
I personally own a front loader and have never had a problem with odors or mildew in the 9 years I've had it by following this regiment.
As far as the bellow is concerned. Some discoloration can be caused by the water you have. In particular if the water contains iron. Some of these stains may or may not come off. You can try using a 50/50 mix of bleach and water in a spray bottle to spray the bellow. Allow it sit for a few minutes, then srub with a green kitchen scouring pad. DO NOT use steel wool, sandpaper, emery paper, or SOS pads. They can damage the rubber. The green scouring pads are considered safe, but abrasive enough for cleaning.
Read through the links provided and let me know if you have any questions. I hope this helps you.
Feb 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Stale odor within tub
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Dec 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Strong mildew odor in Duet washer
are you useing he detergent? if not this is your problem the washer cannot get ride of the soap so what it does is leave a layer of film in your washer and odor causeing bacteria forms in it. There is a product called AFFRESH you can buy it at SEARS it is made specifically for this. Do you leave the door open ragularly? The reason I am asking is because your washer is like your bathroom if you do not ventilate it properly it will grow mold and it needs to be cleaned. By leaving the door closed all the time it is very easy for the bacteria to grow.
So my advice is to leave the door open, make sure you are useing the correct soap (HE) high efficiancy soap, clean the washer with no clothes hot water and bleach and use the affresh or washer magic. Since you can smell the smell you are going to have to keep cleaning it abouit 2-3 times a month till it goes away. Then once a month. This is not a machanical problem or a whirlpool problem and is very commen in ALL front loader if you do not clean it regularly.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Odor in front loading duet washing machine
The following link explains how to minimize wash tub odor, and what generally can cause it:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
I personally own one of these washers and have followed this same regiment since I purchased it new 9 years ago. I have never had a mildew or odor problem. Consumers that are not in the habit of using hot water very often will also run into odor and mildew problems, because detergent alone does not always kill bacteria. It is recommended that you run a "Clean Cycle" from time to time, to sanitize. Some newer models have a clean cycle added on the control panel.
NOTE: It is normal to have residual water in the drain lines and in the drain pump. If you need to clean, or check the drain pump, please follow the advice in this next link:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Debris caught in the drain pump reservoir can often cause some unwanted odors.
If the rubber door bellow develops mildew and mold, use a non abrasive pad (the little green pads are considered non-abrasive) and scrub the rubber with bleach diluted with water (50/50 mix). This will often kill and remove unwanted mold and mildew. If the door bellow becomes embedded with mold or mildew, it may have to be replaced in order to get rid of it.
If you establish and maintain a diligent routine, these washers will not mold or smell. Often what seems to be a dream appliance that is supposed to make your life easier, may actually require more attention in order to maintain it properly.
If you have questions or comments, please let me know. I hope this helps you.
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mildew smell
Are you useing HE detergent? If not this is your problem! The reason why you need to use HE detergent is because it is made specifically for front load washers. The regular soap is made to be deluted in 20 gallons of water your washer only fills up with about 7. so what it does is it leaves a layor of residue SINKY SINKY. Especially when you leave the door shut all the time. It's like a Bathroom if you do not ventilate it properly it will Sink eventualy. So also please leave the door cracked open.
So to getr ride of the smell Sears sells a product called Afresh or Washer Magic I prefer the Afresh you get 3 tablets and it works great atr removing odors out of your washer. Also if you are on a Well wateer it is safe to use. Or you could use good old bleach with no clothes till the smell goes away
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine odor
www.affresh.com this product has been devoeloped to lessen front loader odors. you NEED to be using an HE detergent. low sudsing ans specifically design for use with front loading washers.
Oct 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
249 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
