Home | Rancilio | Silvia Espresso Machine | Leaking between base sta...
Rancilio Silvia Espresso Machine
Problem for Rancilio Silvia Espresso Machine
Leaking between base stand and body
By webam2 on Sep 28, 2009
I have a Rancilio Silvia about 2 years old. About 10 days ago I did a descale and backflush process, (very little came out) but now it is leaking from the right hand side when facing machine (but only when turned on) from the gap between the base and the body.
I suspect it is the 3 way solenoid valve, but would like some advice before we attempt a repair.
Is this a symptom of solenoid breakdown and is it a self repair job for a handyman husband?
Best Solution
posted on Sep 29, 2009
Helpful)
EsWorld
Rank: Guru  Kitchen Appliances  Expert
Rating: 86%, 318 votes
You are correct. There might be something keeping the solenoid from closing. Yes you husband should be able to fix it. Have him clean out the solenoid.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" we took it apart,cleaned it all out, put it back and no leaks! Thanks very much " - webam2
Popular Solutions for Rancilio Silvia Espresso
Questions and Unsolved Problems for Rancilio Silvia Espresso
Do you recommend Rancilio Silvia Espresso Machine?
Answer
Answer
Can you supply a thermostat for a Rancilio Silvia? the one required is T3 in the wiring diagram, and... (More)
Answer
Hi, last week I purchased the Rancilio Silvia Espresso Machine. For most of this time I have been... (More)
Answer
bad check valve in rancillio silvia? pressure loss thru group head while steaming
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Rancilio Silvia Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
