Question about Motorola FV200AA GMRS/FRS 2-Way Radio Walkie Talkie with 5 mile Range
Hello I just bought a Motorola 53725 SLK Headset with Swivel Boom Mic (Black) for my Motorola FV200AA 5-Mile and I have a problem to hear. They can hear me but I cant
  • mmessuti Sep 29, 2009
    Thank U very much for the information. one more thing
    how can i turn off the VOX mode??
  • Motorola Master
  • 1,654 Answers
Two things to check. Make certain you are plugging in the headset with the radio shut OFF. Also be certain the headset is plugged in all the way. You should feel a slight click when it is seated properly.
If the headset has an in-line PTT, don't alternate between it and the one on the radio. If there is no in-line PTT, use the PTT on the radio unless you have your radio set for VOX.
If using VOX mode, do not touch the PTT at all once you turn the radio on. One thing to keep in mind if using VOX, the receiver will pick up any ambient noise around you and think it is voice and keep your radio locked into transmit. Vox only works well in a somewhat quiet environment.
I've probably given you more info than needed, but wanted to cover all the bases.
Posted on Sep 29, 2009
  • eradiostore
    eradiostore Sep 30, 2009
    After turning the radio on (with the headset attached) simply press the PTT button on the radio to shut off the VOX feature. By pressing the PTT, the radio will then change to needing you to press the PTT to talk.
Sound
If it's in warranty, you should contact Motorola for replacement. or depending on where you bought it, you may be able to return it to the retailer/wholesaler for an exchange dependent on the laws in your state/country? It's more than likely a lemon/defective unit.
Mar 29, 2008 | Motorola Mobility H700 Wireless Headset
Plantronics Noise Cancelling headset H261N hearing others problem
where is the other end of your amplifier connected? To a computer, to a phone?
Did you connect correctly the mircophone to your amplifier and from your amplifier to the correct plug?
Oct 20, 2007 | Plantronics (43-1960) Headphones
When someone calls me, they can't hear me if I have my bluetooth in, but I can hear them...I have the Motorola H700C wireless headset.
I have, no-had, two of these H700C. The microphone in both of them failed about when yours did. I had previously split the boom and removed the foam covering the mic due to callers complaining they could not hear me. No solution here as far as I can see, except replacement. I don't understand it, either.
Jun 30, 2010 | Motorola Mobility H700 Wireless Headset
I cannot get my phone to locate my motorola hs850 what do i need to do?
close the boom mic , press the button and hold until blue light is solid and with your spare hand flip the boom mic back open and the light should remain on. "0000" is the default passkey
Jul 05, 2009 | Motorola Mobility HS850 Consumer Headset
Motorola H710 mic not working
i pinched the flats sides of the boom together tightly and used my ps3 to measure the clarity and went from mic not working to semi to full clarity
Jul 02, 2009 | Motorola Mobility H710 Bluetooth Headset
Can not pair with my new phone
sure can
with the boom mic closed Push and hold the call button until the light around turns purple or stays a blue, then open the boom mic the color should stay on now go in to the phone settings and find the bluetooth settings and search for device once it finds it connecct to it, Remember the Passcode is 0000, and then you should be all set up.
Jun 28, 2009 | Motorola Mobility Bluetooth...
What kind a charger i need for it
The FV200AA, as indicated by the AA, is the AA battery version of the radio, and does have a charger. If you are using rechargeable AA batteries you will need to charge them separate from the radio in the appropriate charger.
Jul 18, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Motorola H700 not connecting to nokia 6300
The factory code is 0000
Is there an error?
Enasure you are doing the pairing correctly
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator ight becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the headset boom, repeat steps 1 through 3
Jul 03, 2008 | Motorola Mobility H700 Wireless Headset
Motorola h700
Ok here is the answer. There H700 have a small foam windscreen inside over the microphone that over time block the sound. The answer is to carefully open the unit and remove the obstruction and clean residue from the microphone and it will work like new. here is a link to pictures and instructions. http://www.geocities.com/jconkwright/H700fix.html
Apr 07, 2008 | Motorola Mobility H700 Wireless Headset
Motorola FV200AA GMRS/FRS 2-Way Radio Walkie Talkie with 5 mile Range Logo
128 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
