Question about Philips gemini TT-02 Turntable
The plate speed changes in relation to the speed set with the pitch when i lightnessly touch to beatmatch... that makes me been constantly touching the plate, because if i give a little forward touch it goes faster everytime and not for a while and then back to original speed (set with the pitch)... is this frecuent? Thanks a lot. Sorry for my english.
2010 endeavor making whining noise from rear end at any speed. It is a front wheel drive. Put on new tires, still doing it.
If the sound gets higher pitched with higher speed, you may have a bad wheel bearings. If the whining stays constant, there may be something rubbing like the brake backing plate (especially on drum brakes). Try putting your hand near the backing plate after you drive it a bit. The friction from rubbing will make it hot.
Mar 19, 2017 | Cars & Trucks
I use my Sl1200 with Serato and the other day one of the decks was starting slow. I solved the problem by spinning the record first and then placing the stylus down. But I want it to go back to the way...
p { margin-bottom: 0.21cm; }
HI,
After long years of use the electrolytic capacitors in the circuitry will get slightly change its value. If so it can affect the speed of the turntable. Its better to replace all the electrolytic capacitors in the turntable's electronic circuit board. It will not coast a lot for all the capacitors. Will only come around $3 or $4. .
OK
Oct 28, 2011 | Technics SL-1200MK2 Turntable
I have a 1985 s10 with the2.8 5 speed trans when i let the cluch pedal up it makes a constant rubbing noise and a high pitched squeel and its all qieut when i shove the pedal down any sugestions?
Hi and welcome to FixYa, I am Kelly,
Your clutch release bearing (throw out bearing) has failed. The transmission has to be unmounted from the engine to change this bearing. (Just like a clutch job!) Being this is a 1985 vehicle you should inspect the clutch plate and the pressure plate for wear. The fingers on the pressure plate should be quite worn if the throw out bearing is doing as you stated in your post. I.e rubbing sound and high pitched squeel. Inspection of the clutch plate consists of making sure the rivets are still not even with the friction pad surfaces. Don't forget to also inspect the engine flywheel for abnormal wear while your working in this area.
Things you might need.... U joints
Transmission rear seal
Clutch Plate
Pressure Plate
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Chevrolet S 10 Cars & Trucks
I cant get my speed touch password
The default password setting for a speed touch is to leave it blank, but if you have changed this previously it will be no help and you'll have to do a hard reset.
May 31, 2009 | Alcatel Speed Touch Home Modem
The turntable loses its speed
Perhaps you should retrace your own lamp repair steps. Did you tamper with anything electrical? It seems likely you touched something inadvertently.
Apr 24, 2009 | Technics SL-1200 Turntable
My palm makes a constant high pitched sound when it is powered on
Is your speaker making this high pitched sound or is it something else. If it's "something else" then there is no problem to worry about. It's just an audible frequency given off from the touch screen.
Jun 06, 2008 | Palm Tungsten E2 Handheld
Canon LaserCLASS 710 Fax Owner's Manual
Set Speed Dial / One-Touch Feature
  1. Open One-Touch Speed Dialing Panel and press “Data Registration.”
  2. Under “Additional Functions” scroll to find “4. ADD. Registration” and then press “Set.”
  3. Scroll to find “1. 1-One-Touch Speed Dial” and then press “Set.”
  4. Under “Tel # Registration” scroll until the desired “One-Touch” number is displayed. Press “Set.”
  5. Under “Tel # Registration” scroll to find “1. Tel Number Entry” and then press “Set.”
  6. Under “Tel Number Entry” enter fax number (with “9” and the area code – ex. 913104454200) and then press “Set.” Screen will display “Data Entry OK.”
  7. Under “Tel # Registration” scroll to find “2. Name” and then press “Set.”
  8. Under “Name” enter the company name and press “Set.” Screen will display “Data Entry OK.”
  9. Press the red “Stop” key on the main control panel.
  10. The “One-Touch” feature is now set.
Label corresponding “One-Touch” button with company name.
Jan 30, 2008 | Canon LaserCLASS Fax 710 Printer
Philips gemini  TT-02 Turntable Logo
35 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
