Lexmark X75 will not print in color. Just replaced the color cartridge and will not print in color.
    President:
  • 787 Answers
May be you have problem in carriage unit on your printer.Sorry u need to call on specialist.
Posted on Sep 29, 2009
Printer has stopped printing blue
Make sure that you are inserting only genuine Lexmark cartridges in your printer. Removing then re-inserting the color cartridge into the printer is a quick to minor cartridge communication issues.
Make sure that your color cartridge still has substantial ink level for printing using the Lexmark Solution Center software on your computer.
Click Start > Programs > Lexmark X74-X75 > Lexmark X74-X75 Solution Center. Check the ink levels.
If color ink level is still good, then it probably just needs some cleaning. Print quality issues can be due to dirty or clogged print cartridge nozzles. From the Maintenance tab in the Lexmark X74-X75 Solution Center, click Clean print nozzles to fix horizontal streaks. Your printer will then print a test page. Try to print a color page again to verify that the problem with the blue color is fixed.
If the problem continues, try to insert a different known working color cartridge to identify if it's a faulty cartridge issue.
Oct 26, 2011 | Lexmark X75 All-In-One InkJet Printer
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 won't print in colour anymore
When you print a color document do you get any color output ?. You may want to try to print a test color document, consisting of say Red, Green and Blue color blocks. If any of the blocks is missing you may want to replace your color cartridge.
Jun 01, 2009 | Lexmark X75 All-In-One InkJet Printer
Ink cartridge
you may check your ink cartridge
long time less using cause 3 color ink chanel(holes) a little dryer, could not print well even refilled.you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Jan 20, 2009 | Lexmark X75 All-In-One InkJet Printer
Print Problem
free needed software for lexmark x75
Aug 03, 2008 | Lexmark X75 All-In-One InkJet Printer
My lexmark x75 only print black and white
Please check color cartridge is ok or not
if it is ok then check your printer configuration in Your pc it should be a gray scale printing ....
May 23, 2008 | Lexmark X75 All-In-One InkJet Printer
Ink in printer
did you do a test page? maybe you need to clean and calibrate them?
Apr 28, 2008 | Lexmark X75 All-In-One InkJet Printer
Color problems with Lexmark X75 printer
hi ..
please get new color cartridge tested with other Ok printer
then from your printer get cartridge alignment with clean cartridge utility
Apr 08, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75
check your Printing properties.
Oct 31, 2007 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 no color
even though you have ink coming out of the cartridge, if it's more than a few months since it's pumped any ink, it can be clogged internally, blotting with paper doesnt always work. Try a new cartridge, or buy a new printer, it's usually cheaper now to get a whole new printer than it is to replace a set of cartridges. consider it's a few years old now
Aug 16, 2007 | Lexmark X75 All-In-One InkJet Printer
37 people viewed this question
k24674
jasbo
jasbo
