Question about Sony Playstation 3 (PS3) Console
Where would I find my WEP key so I can set up my wireless internet on my playstation3
It should be on the back of your router
Posted on Sep 28, 2009
I am trying to connect a playstation3 to my wireless internet, but i can't find my WEP Key.
Depending on your internet provider, this number may be listed on a sticker or printer directly on your wireless router. Try any numbers you find on your wireless router and see if they work. It is often under or near a barcode.
May 05, 2011 | RCA Thomson Digital Cable Modem (DCM305R)
Wep key how do i find it
The WEP encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the WEP key. Then go to your computer/laptop's wireless card and configure it with the router's SSID and WEP key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 19, 2010 | D-Link DI 514 Wireless Router (DI-514)
I need to find my wep key from my desktop so i can link my laptop to the internet
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security.
Dec 18, 2010 | Computers & Internet
I just need my WEP Key for my Playstation3 to connect to my wireless internet.
The WEP key should be on your router configuration, but moist likely it will be displayed as dots or astericks. If you can't remember it, then most likely you would have to reset your router and reconfigure from scratch. Also most routers you can backup the configuration file so you can restore at a later time if you screw it up
Sep 09, 2010 | Computers & Internet
Where can i find my wep key
Your WEP key is the password on your wireless internet connection.
Whomever set up your wireless internet connection (wifi) should be able to provide the WEP key for you.
Aug 06, 2010 | Microsoft Xbox Live One Month Gold...
Dlink accesspoint doestnot connect with playstation3
The Dlink wireless modem is configured correctly and the computer/laptop can access the Internet wirelessly.
The PS3 needs to be configured with the Dlink modem's wireless settings so it can communicate with the wireless modem.
To configure the PS3 please follow these steps :-
1. Power up the PS3 and login then Select Network Settings and
press X
2. Select Easy then press > button
3. Select Wireless then press > button
4. Select Scan then press > button
5. Select the wireless modem you want to use, then press X button
6. Confirm the SSID for the wireless modem then press > button
7. Select the security settings (ie WAP, WPA - this is the in the wireless modem settings) then press > button
If there is no encryption I suggest you enable the encryption on the wireless modem, use passphrase to generate the encryption key.
Write down this encryption key, you will need this key for your computers and PS3.
8. Enter the WEP or WPA encryption key (from the wireless modem) then press > button
9. Check the settings then press X button
Dec 23, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
How do I get my WEP Key for my LINKSYS ROUTER
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address, 192.168.1.1, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your chang
Nov 12, 2009 | Linksys Wireless-G WRT54G Router
Every time i try to set up wifi, it asks for a wep key.
The WEP key is a security key used by your wireless internet device (usually a router). Do you know who set up your wireless internet? If so they should be able to provide you with the WEP key.
Jun 24, 2009 | Nintendo Pokemon Diamond for DS
Wep key for ps3
you will need to obtain your wep key no matter what...you can get it from whoever your router company is (if it is a linksys then call the linksys support number and obtain the key) in most cases thought the wep key is located on the router itself near the bar code. It will be a long number, When you get it and enter it in to the network settings then it should pick up the signal
Feb 09, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
160 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
