Question about Kenwood KNB-15AM, ,TK260,TK-270,TK-360,TK-370, 7.5v 1700mAh NiMH 2-Way Radio
Kenwood tk272g tone and flashing red light
I have a tk-272g that give a tone and flashing red light a couple seconds after
you key up... The battery checks fine and works well on another radio.. Any
ideals???
Thanks
Benimur
  • 6966 Answers
SOURCE: Yaesu Ft-60R with Kenwood TK-3107
Initially and the simplest probably would be to use the units without enabling the CTCSS or any form of encoding (turn this feature OFF). In the meantime, will check the specs and post if anything concrete comes up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 31, 2008
Benimur
  • 6966 Answers
SOURCE: can you give me any
At the onset, basic tools and equipment would include (but not be limited to):
  • basic electronic tools & equipment (side cutter, screwdrivers, soldering station, DVM);
  • a dummy load wattmeter;
  • frequency counter;
  • RF Voltmeter;
  • SWR meter;
  • variable regulated power supply;
  • AF/RF signal generator;
  • Spectrum Analyzer (would be nice but not a necessity).
A copy of the service manual or at least a schematic diagram with voltage readings would be very helpful. Repairs would involve sectoring the handheld into:
  • logic/controller circuitry;
  • RX section;
  • TX section;
  • built-in power supply/regulator circuitry.
vrc_tech
  • 109 Answers
SOURCE: changing a radio case
The TK272G is just like any other handheld it is just a matter of taking the radio apart and remembering or make notes of what you did. Start with removing the knobs on the top of the radio and then remove any screws that are under the battery compartment the radio should easily slide out of the case by using a screw driver at the bottom of the radio. Slide the scewdriver between the radio chasis and the case and the radio chasis should lift out. be careful not to bust the rubber seal O-Ring that may be between the radio chasis and the case. the rest should be easy for you to do. the key thing for you to do is take your time and remember the steps you have taken and reverse them when putting the radio back together.
Have a great day!
Patrick Patterson
Posted on Dec 16, 2008
SOURCE: i have a kenwood tk-272g and the keys are locked
One of the keys has been programmed as the lock button. you will have to experiment by holding each button for a couple of seconds until you hear a tone that tells you the radio is unlocked.
On the one I have for our fire and rescue it is the < button but it could be any of the four on the front or the two on the side below the talk button.
Posted on Jun 19, 2009
ALLEN CLARKE
  • 47 Answers
SOURCE: Kenwood TK-3200L (K3) radio has (dial) tone only on all channels.
are the batterys charged?
Are the battery contacts cleaned
Posted on Nov 11, 2009
MY kenwood tk 272 g will not play audio while recieving. But i know the speaker works but i only hear it squelch on one channel
1 try to check the volume button is not fouled.
2 try to do reset by the manufacturer. (With station stopped ,pressing the two buttons on the side station . Starts station for 2 sec. Releases the side buttons.
3 try to do the firmware update.
Apr 21, 2015 | Kenwood Tk272g Tk-272g Vhf 150-174
How do i progam a new channel or find out what chanel it has programed already
Hi Robin,
I take it the you require programming software for your radio, May I suggest: join yahoo group specific to your radio Make/Model, they will be able to give you all the info plus you can download manuals, schematics and other goodies.
I hope I have been of help.
Cheers,
Peter
Feb 03, 2013 | Kenwood Tk272g Tk-272g Vhf 150-174
Kenwood tk-272g radio wont transmit
This is commonly a sign of a bad or poorly charged battery. Check your charger, battery and battery contacts. Clean contacts with a pencil eraser. Try recharging the battery, making certain the radio is turned off while on the charger. If this does not solve the problem, try swapping batteries with a known good unit. If the swapped battery solves the problem, you know you need to replace your battery and/or charger.
If the problem remains with the swapped battery, you know you have a radio problem. In this case, you will need to look at the battery contacts on the radio, where the battery meets the radio and see if you see a problem there. OR a problem with how the battery fits to or in the radio.
If it is a radio problem, you may need to see your local Kenwood dealer for assistance.
Best regards.
Jul 14, 2012 | Kenwood Radio Communications
I have a TK-280 and when i put it on the charger the red charging light comes on the starts flashing red after about a min. I am on the fire dept. where i live and kinda need it charged up. I wanted to...
  • Couple things this could be.
  1. First thing is to make sure the radio is seated properly in the charger and that all the contacts are making contact and not dirty.
  2. The other thing this could be is that the battery is bad. Or in the least the capacity for the battery is extremely bad and not reliable.
  3. If the contacts look good and it's sitting on the charger proper than you will need to get another battery pack. Sorry.
  • Hope this helps and thank you for using FixYa.
Regards, Tonyu
Jul 14, 2011 | Kenwood KNB-17AM, TK-280, TK-290, TK-380,...
Can i leave my handheld on while charging its a TK-272g
It depends on the charger. If you hear a hum on receive when it's charging turn it off.
Sep 25, 2010 | Kenwood KNB-15AM,...
I have a kenwood tk-272g and the keys are locked and i cant figure out how to unlock them, the owners manuals ii found online aren't helping me at all
Jun 12, 2009 | Kenwood KNB-15AM,...
Need manual for kenwood tk-270 transceiver does any one no were i
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor KeyOff = off1 = Monitor momentary2 = Monitor Lock3 = Squelch off momentary 2. Scan KeyOff = offCo = carrier operateTo = Time operate 3. Dial KeyOff = offOn = enable 4. TA keyTA = talkaroundRV = ReverseOff 5. Lo KeyOnOff 6. PriorityNone1 = fixed2 = selected 7. Fixed Priority ChannelTurn selector to channel 8. Look back time ATurn selector to time in seconds 9. Look back time BTurn selector to time in seconds 10. Revert Channel1 = Selected2 = Last Call3 = Last used4 = Selected + Talkback5 = Priority6 = Priority + Talkback 11. Tx Dwell timeTurn selector to time in seconds 12. Drop out delayTurn selector to time in seconds 13. Time out timerTurn selector to time in seconds 14. Tot Pre-alertTurn selector to time in seconds 15. Tot Rekey timeTurn selector to time in seconds 16. Tot reset timeTurn selector to time in seconds
Apr 27, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
Changing a radio case
Have a great day!
Patrick Patterson
Dec 11, 2008 | Kenwood Radio Communications
Flashing light
the problem may be the batteries. When the batteries get old and won't charge or if a battery needs recharging the kenwood radios TX/RX LED will flash untill the problem is resolved.
Oct 20, 2008 | Kenwood Radio TK 260 360 270 370 2100 3100...
Radio Communications Logo
213 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
