Question about Brother MFC-7220 All-In-One Laser Printer
It had an error and it stated that it needed to take 10 minutes to warm up. After some time the message says RECEIVING DATA. When I attempt to put an evelope in to print it then says "fails to warm it."
3 Suggested Answers
SOURCE: Brother MFC 8860DN: Send Problems
Update the firmware and it does support SMTP-AUTH
Posted on Apr 15, 2008
SOURCE: "Document Failed to Print" - printer is "receiving data" but nothing ever comes out
Have you tried restoring to a previously known date that all worked well?
Go into System Restore and try there.
Posted on Oct 05, 2008
I've received a mms message and my screen say MMS retrieval failed, how can read this message?
This often has to do with a network error, or your phone its self. The best solutions are as follows.
  1. Turn your phone off and turn it back on and attempt to retrieve the message again.
  2. If that fails, ask the sender to resend the message.
If the above solutions do not work you might need to consult with your wireless provider.
Jun 03, 2011 | Cell Phones
I had to purchase a new battery for the car. After installation, the COdE message for the radio would not allow me to play the radio. I attempted to put in the 5 digit code but was unsuccessful. What do...
After two tries, the radio assumes tampering, and stops receiving the unlocking code. Disconnect the battery for 10 minutes or so, and attempt again to introduce the code.
Aug 25, 2010 | 1996 Honda Accord
Ntldr cd boot fault
Computer is booting from a non-bootable source
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again
Mar 31, 2010 | Computers & Internet
I get the message Uncaught exception: DSSMA: invalid state (5):10060 everytime I try to get my messages
Hi, When the BlackBerry smartphone user attempts to access or open the messages folder from the Home screen, the Uncaught Exception: DSSMA Invalid state error message is displayed. To resolve this error, you need to perform a hard reset of the BlackBerry smartphone. If you face the same error even after performing a hard reset of the BlackBerry smartphone, you need to complete the following steps: 1. Back up the BlackBerry smartphone using BlackBerry Desktop Manager. Erase all data and applications from the BlackBerry smartphone. Restore the backup of the BlackBerry smartphone using BlackBerry Desktop Manager. Hope I helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 18, 2009 | RIM BlackBerry 8800
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to ti-cares@ti.com.
Oct 22, 2009 | Texas Instruments TI-83 Plus Calculator
Error message while attempting to swipe a credit card
ok only plug it with the keybord pluuged in and restart your machine that will work go to posspecialist.com if need any assistance
Aug 24, 2009 | ID Tech Computers & Internet
Error 6a00 message
Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Note: If resetting the printer does not work, please attempt any other solutions that appeared in your search results.If this is a hardware error on the printer, the printer may need to be repaired.
Jan 03, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Ps2 error message
not sure but check the memory card or the inside to the left see what you can fix
Dec 07, 2007 | Sony PlayStation 2 (PS2) Console
Error 6000
Nov 13, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Brother MFC-7220 All-In-One Laser Printer Logo
18 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
