Question about Maytag Washing Machines
Spin cycle bounce around Maytag waher machine Model A412
Spin cycle bounce around. tub vibrate with or without clothes in washer
  • 11 Answers
SOURCE: Waher will not go into spin cycle. It makes a buzzing noise and will not spin.
it's most likely your timer....u can get the machine to spin out your clothes by pushing the timer in and pulling it back out. this resets the motor and makes it turn backwards. it's a pain to do this because you have to keep an eye on the time. this will get you through until you change the timer.
Posted on May 29, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
  • 12 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Posted on Nov 17, 2009
miket756
  • 2702 Answers
SOURCE: clothes washer vibration during spin cycles
the vibration and noise is most likely from the drum bearings wearing out to test the bearings try this out,,,
open the door, hold the top of the drum and lift it up, if it has any free lift in it the bearings are going, now spin the drum by hand and you should here the rumble off the bearings
Posted on Dec 29, 2009
Testimonial: "Thanks so much. There isn't a lot of lift, but there is a noise when it spins."
blueextc3221
  • 15935 Answers
SOURCE: EXTREME SHAKING DURING SPIN CYCLE
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Need to have a list of Maytag Front Load Waher Model #s that do not require shipping bolts.
all washers ever made regardless of front or top load need shipping support when shipped be it shipping bolts or other means of synching the tub down so it doesnt become damaged by bouncing around in the back of a truck
Jul 21, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Near the end of the rinse cycle there was a load noise accompanied with a lot of vibration. I stopped it and took out the wet clothes and fininshed manually. To test i put the machne on spin cycle and...
if the clothes bunch up on one side the tub doesn't spin evenly and goes off balance,the tub will start banging all around,if this happens,open the lid and move the clothes around to even them out so all the wieght isn't on one side,it's a common thing mostly with a few items in the washer but can happen with any size load.if it keeps happening send the brand name and the model number.you should be fine.
Apr 17, 2011 | Washing Machines
Tub on a Maytag washer bounces out of control on spin cycle
Sounds like your tub has a broken spring under it. They are difficult to replace. Buy a washer from somebody moving for 150 to 200 bucks and call it a day.
Nov 03, 2017 | Maytag Washing Machines
I have a Maytag (Model MTW5770TQ0) washer. It
yes it sounds like it try this when running open lid if it
does what you say its doing then the transmission needs to be replaced this contains the clutch and it may be cheaper to replace the washer call a repairman
Nov 24, 2009 | Washing Machines
Maytag Top Loader Thumps When In Spin Cycle
My guess is that one of the three counterweights have separated from their support. Probably rusted away.
36 years is quite a feat. Today's machines would be lucky to 1/3 of that life.
Sounds like its time to go shopping.
Do you have an anniversary coming up?
Ladies love washers for an anniversary gift.
May 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag neptune frot load will not reach full spin speed.
It will not spin while washing, it's more of a rocking back and forth. As far as the spin cycle. If it's not reaching full speed I bet you'll notice that it's not doing the full cycle because the load is bouncing around and cause the washer to shut off. take some of the clothes out and watch it spin the water out.
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Abnormal shaking during spin cycle
THIS IS CALLED A BEARING JOB THE INNER TUB AND THE OUTER TUB HAS TO BE REPLACED THESE PART ARE USALLY UNDER THE MAN. WARRANT BUT THE LABOR IS PRETTY EXPENSIVE ON THIS JOB BECAUSE THE WHOLE WAHER HAS TO BE TAKEN APART
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
245 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
