Question about Samsung ML-2510 Laser Printer
When printing, it does a buzz and doesn;t print
Printer Buzzing and not printing
Hello. It sounds like the printer head needs to be changed.
Apr 18, 2014 | Polaroid PoGo Digital Photo Printer
HP 5150 Deskjet -- black printing abruptly stopped. Prints appear with color but no black. Switching black cartridges doesn't help. Clean print heads operation doesn't help. Switching computers...
There are very few things you can do, other than what you have aleady done.
I would recommend a decision on how much the unit cost and how long you have used the
printer vrs. what HP or a local authorized service center would charge to repair it.
If you have refilled ink cartridges, this is problem that can arise due to ink drying on the
print head as the black cartridge is use the most.
Aug 06, 2011 | HP DeskJet 5150 InkJet Printer
The printer is recognising that the Yellow is full but when I print out a test page the yellow doesn't print. Is this a printer or cartridge issue?
try to do deep head cleaning, few times. If this doesn't helps you need to remove the ink's and print head and bottom of print head ( where are ink nozzles ) few times press on wet cloath.
Then repeat the deep cleaning.
Aug 04, 2011 | Canon PIXMA iP4000R InkJet Printer
My printer doesn't print word documents (it doesn't print in black, but it does in colour), it prints everything else. I already checked the port (it's USB), changed the cartridge, uninstalled...
try the following
1.power on your peinter
2.while press and hold the power button ,open and close the top cover times.
printer pick the paper and print the test page and alignment pattern for black and color.
if any of the black or color alignment pattern is not print ,then u have to change the cartridge accordingly.
Aug 01, 2011 | HP Deskjet D2360 InkJet Printer
My printer won't print. my computer is hooked up to it, and it doesn't give any error messages. it just doesn't do anything.
Go to Control Panel/Printers. Right click on your printer's name, and hit Print Test Page. If printer prints a page out, then the problem is likely with the software you're using to print - make sure you have selected the right printer in the dropdown. If the printer's name doesn't show in the Printers folder of Control Panel, the driver for it has not been installed. Do so and try again.
Jun 18, 2011 | Lexmark X2670 All-In-One Printer
When machine is turned on , it keeps starting & stopping by itself. The load paper roller first turns one way & then when it restarts ( by itself ) it the rollers reverse. The "stop" or...
It sounds like you need to "prime" the printer. Look for the Utility that came with the printer. It may even be where you found the "test print" page. If that fails, check the documentation that came with your printer, and see if the print cartridges also contain the printer head... like the HP Inkjet printers do. If not, I'd say there might be something wrong with your print head and it needs replacing.
If you no longer have the manual that came with you printer, log onto the Lexmarkwebsite, support, and find your printer manual. If all else fails, call Lexmark's support line.
I hope that helps. Good luck!
May 16, 2011 | Provo Craft Cricut Expression Personal...
Epson stylus photo r300 removed print head, flushed out all nozzels with water, dried everything, reasembled everything, including the flat ribbons, two different times. After dozens of times trying to...
If an inkjet printer has not been used for some time and several print head cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 24, 2011 | Epson Stylus Photo R300 InkJet Printer
Mx310 makes a buzzing sound
a shorting out on a Print IC :
  • unplugg/ plug usb cord
  • uninstall/install soft
Feb 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Samsung ML-2510 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
