Question about Kohler K-3422 - Wellworth Elongated Toilet - Two-Piece Toilets
Actuator/lever is broken
I have a eljer toilet with flushmaster system and i cant find the flush lever/actuator? can anybody help me?
    Top Expert:
  • Kohler Master
  • 14,459 Answers
Lift off the top of tank ur handle is also part of ur flush lever at the end of the lever is either a chain or thin length of rubber that runs down to bottom of tank and is connected to flapper----
Posted on Nov 04, 2009
  • 31 Answers
Well there is a ring just 2 inch up from butim of tank on the fluhmater ....you can twist it up and adjust your water
Posted on Oct 03, 2009
What does a toilet actuator do?
Older American standard toilet have an actuator in place of a flapper. it looks like a big black thing with a round tube on top that the chain attaches to, when you flush this toilet the actuator seams to lay on it's back for a few seconds and then drops back down, and the tank refills.
Nov 04, 2010 | Eljer Aqua-Saver Toilet Actuator -...
Low water level in bowl after flushing
The small black tube that goes into the overflow is used to fill the bowl after flushing. Would check to make sure that water is coming out of that tube at full force or if its coming out at all.
May 11, 2010 | Eljer & Elongated Toilet Bowl
I have to hold the lever of my Eljer one-piece toilet to flush it. How to adjust it?
lift off cover and shorten flapper to handle chain/rubber connection flapper not opening all the way
Apr 11, 2010 | Eljer Toilet Onepiece Canterbury ...
Flush lever wobbles
lift cover and tighten plastic nut on inside of handle
Oct 02, 2009 | Eljer Toilet Onepiece Canterbury ...
Always have to hold handle to get it to flush
lift the lid,and look, flush, the rubber valve that opens when lever is is pulled should float, so either its very loose or broken and needs to be replaced.plz rate-bozcro
Sep 10, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Power flush will not flush when handle is pressed down......
pull the lid off the toilet, disassemble the toilet handle mech and take the cartridge out of the big black tank under there. the cartridge should be available at any local plumbing parts house. let me know if you have problems
Jul 02, 2009 | Eljer Aqua-Saver Toilet Actuator -...
I havve two Eljer non-wateraver toilet (Patriot?)
I've never had a problem with Eljer toilets. Try adjusting the fill valve so that it allows more water to enter the tank (if you're over the flush valve, install a coupler made from PVC around the neck of the flush valve- inside diameter of the coupler needs to be the same as the outside diameter of the flush valve filler neck).
Jul 02, 2009 | Eljer Home
Kohler K-3422 - Wellworth  Elongated Toilet - Two-Piece Toilets Logo
184 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
