Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Trying to fing out if compressor oil can be changed , its a Craftsman Industrial 1.5 hp 4.0 gal horiz: twin tank portable compressor..max psi 125 4.7scfm@40 3,3scfm@90 black in color and can't find any #'s for model or serial
    President:
  • 1,167 Answers
Yes buddy simple to do unscrew bolt on pump unit underneith or on front at bottom let it drain replace plug and fill till it is 1/2w way on sight glass or upto line on dipstick some on ebay
http://cgi.ebay.co.uk/Sealey-CPO1S-Compressor-Oil-1ltr_W0QQitemZ140344576982QQcmdZViewItemQQptZUK_Air_Tools_and_Compressors?hash=item20ad304bd6&_trksid=p3286.c0.m14
Posted on Sep 29, 2009
Why won't my compressor start?
If it's new I would return it. However that model number 16638 is for a Huffy Bicycle.
Sep 06, 2014 | Craftsman 1 hp Air Compressor, 4 gal. -...
What kind of oil do i need for a craftman 1 hp 3 gal 125 psi compressor m/ n 921 153101?..
For warm climate, use 30wt non detergent oil (lowest price $3). Med priced oil ($5), use compessor oil sold at Lowes or any major center store including Wal Mart. Compressor oil is special blend for higher temperature range (continuous use). High price oil, synthetic compressor oil works for heavy duty use under severe conditions (also sold at major lumber centers, cost about $8~18).
For lite duty, any oil that you have handy will work fine (check oil before every use). Good luck
Oct 03, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How to get more hp out of a honda 5.5hp engine
Your compressor was designed to produce 11.8 acfm at 90 psi turning neer max rpm (depending on pully combination between 800 ~1100 rpm ) with max pressure of 135psi. At 3600rpm the engine is producing max hp of 5 to 5.5. More power would not really produce more air without potentially destroying the compressor pump by over-reving. If your compressor is not functioning properly you will not get good air flow. Check instruction manual for time period to fill tank from empty. Could be 2 ~3 min. It is takes longer then problems. You can tell how your pump is doing by periodocally checking the length of time to fill tank. The next size range of gas compressor is about 8~9 hp with four cylinder pump and will deliver about 17 cfm.
Mar 15, 2011 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
My Craftsman air compressor has wored fine till now. It does not want to build up pressure beyond 50 psi.yes I did check the drain valve and no leaks. Motor seems to be putting out the rpm's and the oil...
Check for a leak between you compressor head (pump) and your tank. Your pump output may be good but as your tank pressure gets higher the leak will not allow the tank to build up.
Feb 04, 2011 | Craftsman 1 hp Air Compressor, 4 gal. -...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Not pumping up to capacity, motor and compressor working fine,
If your pump is shutting off before it reaches it's max psi. then you need to adjust you switch. Under the black case there are two adjustment screws. One is the high\low adjustment, the other is high pressure cut off.
The first will change when the pump turns on and off for your low psi setting and the high setting simultaneously.
The second will allow you to raise or lower just the high setting. There should be a diagram under the black cap to show which is which. Adjust the high side only and just a 1\4 turn then run the compressor and see if that takes care of the high setting.
May 29, 2009 | Northern Industrial 2 Hp Twin Tank...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
284 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
