Question about Sony Cyber-shot DSC-W55 Digital Camera
Shutter keeps going in and out. can not take a picture
When I take pictures a red hand icon keeps appearing on my polaroid ix828 camera
This is probably covered in the manual, but one possible cause is that the camera thinks that the shutter speed is to low to take shake-free pictures. Try increasing the ISO to give a faster shutter speed.
Oct 29, 2017 | Polaroid Cameras
When we take picture it show picture blurry
The most common causes of blurry pictures are not holding the camera still and correctly pressing the shutter release button or using a slow shutter speed.
Let\'s talk about properly holding your camera first. Always hold your camera with both hands. With an SLR such as yours, grip the left side of the camera with your left hand and cradle the camera from underneath with your right hand using you thumb and index fingers to zoom. Hold your arms so that both elbows rest on either side of your chest and brace the top of the camera against your forehead. This forms a rigid triangle of support.
The second thing you must do is properly press the shutter release button. Do not poke the button because you will jerk the camera and that can cause blur. Instead, start to press the button gradually increasing the pressure until the shutter trips. It should trip almost by surprise. This is very similar to how a marksman pulls the trigger on a gun.
Assuming that you are holding your camera correctly, not "punching" your shutter button and your camera is not defective, here are two easy ways to solve your problem. First, you could use the manual exposure mode and keep your shutter speed at 1/500 second or faster. Second, go to the "S" shutter priority mode and set the shutter speed above 1/500 second. Your camera will automatically adjust the f-stop (lens diaphragm opening) and "film speed" for proper exposure. Please let me know if this resolved your problem.
Aug 02, 2014 | Nikon D3000 Digital Camera
We keep getting vertical lines appearing on the photographs we take using the canon powershot a470 one day it was fine the next the lines started appearing no settings were adjusted it hasn't been knocked...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 26, 2010 | Canon PowerShot A470 Digital Camera
The view finder or screen are black. The lens moves out when the camera is powered on, I can hear the shutter click when pushed; the telephoto is moving; I have all the settings show on the screen when...
I know it may sound like the shutter is moving, but you're going to have to actually look down the lens barrel to confirm it's actually moving, and not just producing a sound effect from the camera. Also keep in mind Canon's SX IS series cameras are notorious for the following problem (fantastic cameras otherwise).
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 31, 2010 | Canon PowerShot S3 IS Digital Camera
How do you take a picture of a fast movement?
It depends on the effect you want.
  • To freeze motion, you need either a fast shutter speed, or a fast flash in a dark environment. In less than bright light you may not be able to get a fast enough shutter speed to stop the action. Increasing the camera's sensitivity to light by increasing the ISO will help some.
  • You can blur the motion by using a slower shutter speed and a stable camera. Set a slow shutter speed and put the camera on a tripod or other stable surface, and you can get things like streaking car taillights and star trails. How slow a shutter speed depends on the speed of the subject.
  • You can pan with the subject. Move the camera with the subject, and keep it moving even while the display blanks out while taking the picture. This will keep the subject sharper while blurring the background to lend a sense of motion to the picture.
  • It's either to freeze motion if the subject is moving straight toward or away from you than if it's moving across your field of vision.
Sep 10, 2010 | Canon PowerShot S2 IS Digital Camera
No image on lcd for taking pictures. Lcd works fine to go through also to view old pictures. just black in camera mode. Tried shooting anyway and no picture. This happened once before and went away an hour...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Nov 05, 2009 | Canon PowerShot A620 Digital Camera
Cannot take picture, no film advance, new battery
The shutter could be stuck or the mirror could be stuck. (Guessing you have an SLR.)
The film advancing is normal; means it is cocked and ready to go but something is stuck.
Take off the lens and see if anything is keeping the mirrors/shutters from returning.
Oct 23, 2009 | Canon EOS-AE-1 35mm SLR Camera
My Kodak Easyshare LS443 is taking black pictures
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Dec 15, 2008 | Kodak EasyShare LS443 Digital Camera
Shutter Disabled
i was quated £250 to replace a buckled shutter unit can this be done any cheaper
Jul 02, 2008 | Nikon D40x Digital Camera
“Shoot and Select” Modes
e “shoot and select” modes allows you to select an image out of a sequence of still pictures you have taken by depressing the shutter button and storing it. This is best for shooting moving objects. SHOOT & SELECT 1: Shoots a rapid succession of 4 still pictures by keeping the shutter button pressed. SHOOT & SELECT 2: Shoots a succession of still pictures by keeping the shutter button pressed. The Stylus 500 will continue to shoot until you take your finger off the shutter button or until the card is full. After shooting, you will have the option to immediately delete the pictures you do not wish to keep.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
67 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
