Question about Shure ULXP4 Receiver
We have several of these but one drains battery 4 times faster than others. Why?
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Try contacting Shure Tech support.
Posted on Oct 20, 2009
Battery status incorrect
This recalibrate's the battery.
Charge the battery completely. Monitor the battery indicator, which is usually found that the bottom of your computer screen, to check if the battery is already fully charged.
Plug off the power adapter and use the laptop until the battery is completely drained. To drain the battery faster, run several programs at once and keep the contrast of your screen to its highest levels. Turn off all power-saving features as well. Turn off sleep mode.
Make sure that the battery is totally drained by waiting for your laptop to shut off or go into sleep mode automatically because of very low battery charge.
Plug the power adapter again and charge the battery again completely. Once this is done, restore the power-saving features and adjust the contract settings of your screen to normal.
Apr 08, 2013 | Dell Vostro Computers & Internet
What is the life of my satellite l30-101 battery off the ac charger
Toshiba's line of Satellite PC laptops offers a variety of screen s that are customizable when ordered online. The laptops offer built-in webcams and backlit keyboards. Most Toshiba Satellite laptops use six-cell lithium-ion batteries that can last up to six hours. To reach that six-hour mark, you can use several tricks to maximize your battery's capacity.
Charge your battery completely before its first use. Check your user manual for the exact charging time required, which is typically at least 12 hours. Discharge your battery completely every two months. Allow it to drain fully before recharging it. Recharge it completely, for at least 12 hours before using it again. Remove CDs and DVDs from your laptop's drive when not in use. These drives spin when loaded, which can drain your battery unnecessarily. Set your laptop to hibernate mode when you need to take a break. This conserves more power than standby. Store your laptop battery in a cool place. Never let the battery sit in direct sunlight or leave it in your car on a hot day. For even longer battery life, remove the battery from the laptop which can get hot while in use when you are plugged in. Turn off your Wi-Fi connection when not in use. Constantly searching for a Wi-Fi connection can drain your battery faster. Work in only one program at a time. The more programs you have open, the faster your battery will drain. Unplug any USB devices, especially those that charge when plugged in, such as your cellphone. These will drain your battery quickly. Dim your Satellite's screen to conserve battery. Hold down your "Fn" key and tap "F6" several times to dim the screen. The "F6" key should show an open circle with small lines radiating out, to symbolize a dim display.
b>
Feb 12, 2013 | Toshiba Satellite Computers & Internet
Battery keeps draining when car sits for several days.
Try this to see if you can find the drain: Wait until the car has been off for a half hour, so computer is in sleep mode. Open hood and remove underhood light bulb. Take off negative cable from battery and hook up a test light between cable end and battery post. If you have a drain, bulb should be brightly lit. Start removing fuses one by one until light goes off. When a fuse is pulled that turns light off, that is the problem circuit. Check everything on that circuit to find what is staying on.
Jan 23, 2013 | 2002 Lexus RX 300
How many years can I get out of my laptop
That will depend on how much you use it and treat it ?
Hope this helps.
b>
Jan 22, 2013 | Toshiba Satellite L455DS5976 Notebook
Radio shorts out battery
Pull the radio and have it repaired is all you can do here.
Oct 03, 2012 | 2001 Ford Focus
My adapter heats up like a flat iron and the battery drains faster than normal
The problem may lie between your battery and the adapter. The increase in the temperature in your adapter may only mean that yours is somewhat damage. Due to this, your battery may not be charged fully that's why it drains faster than normal. Have your adapter check for correct voltage output. The other way around, your battery may have a leaked, or shorted that cause the increase in the temperature of the adapter. Leak battery is not user-serviceable. Go to your nearest shop for it to be check.
Good luck.
TedMac
Sep 16, 2010 | Toshiba Satellite A100-S8111TD Notebook
LG Viewty battery discharges quickly .....
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Jul 19, 2009 | LG KU990 Viewty
2000 jetta has multiple alternator and battery failures
In my case, the instrument cluster was bad, causing the MFI display and radio to go haywire and putting a contstant drain on the battery. $760 to have the VW shop replace it. No problems related to the battery or alternator have occurred since.
Good luck.
kendaknapp@aol.com
Mar 16, 2009 | 2006 Volkswagen Jetta
1988 Yamaha 4 wheeler slow crank
put jumper cables from battery to starter directly
to see if it turns over faster put red on starter lead and black on gorund(metal housing)
You may want to try this from a car battery to see if it spins faster if it does it indicates a problem with power from new battery check cables and lines for power blead
Jan 04, 2009 | Sport & Outdoor - Others
Battery won't hold a charge
Buying recharable batteries will not solve the problem of the battery draining quickly but will help save $ by not having to purchase so many disposable batteries. Check your user guide to see what kind of batteries your camera will accept. Lithium ion rechargeable is the best if compatible. Lithium ion disposible (CRV3) will last a long time as a secondary choice if compatible. Some cameras drain batteries more quickly than others. Just a tip to help reduce the drain: don't use your LCD screen when unnecessary (such as scrolling through several of your pics in-between snapping pics).
Nov 25, 2008 | Olympus FE-230 Digital Camera
Shure ULXP4 Receiver Logo
76 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
