Question about Celestion 15i Speaker
On my celestion ditton 150's there a gritty creaking when i gently press in the cone of the mid range. why is this, and can i resolve it? maybe remove the cone and clean it? thankyou.
Hi Lewsville,
Assuming after more than 6 months you still have the same problem...
The most likely explanation is that the voice coil is burnt out. This will definitely affect sound quality and will probably deteriorate over time. Cleaning won't fix this problem. You'll probably need to get the speakers re-coned by a speaker technician.
This link might be helpful: http://www.colomar.com/Shavano/recone.html
Cheers, Andreas
Posted on May 21, 2010
Motor runs good but is running to rich. Any suggestions?
Yes, check for any air restrictions that would hinder the engine's ability to breathe, the air filter, a dirty or carboned up throttle body, maybe the idle air passages need cleaning. Running rich means too little air or too much gas.
You have throttle body injection? Observe the cone spray pattern of the gas out the bottom of the injectors. It should spray out in a fine mist cone pattern, landing on the throttle plate below it. You can observe with the engine idling and the air breather off. If you see any drips and not a cone pattern, the injectors need cleaning or replacing. Also observe when the engine is not running ,but just turned to ON: It should not show any drips. If it does, the injectors may be stuck partially open.
Another possibility is a bad MAP sensor, reading out of range.
Mar 08, 2015 | 1988 Ford F 150
What is the wattage breakdown for each speaker on my pair of Pioneer CS-N575 3 way speaker towers (I know the total max power combined output is 150 Watts)?
It's the woofer that will use almost all from this 150 W so if you replace woofer take one of 8 ohm which can handle 150 W and you done
Jul 15, 2014 | Pioneer Audio Players & Recorders
I have 2007 model pulsar 150 bike, i have driven the bike for more the 45000 KM and now say (after 35000+ KM ) there is lot of wobbling in the handle when the bike speed crosses 50 kmph. I am still riding...
First change the fork cone set for banking problem, next check front and back wheel bearings
(sprocket bearing as well) for wobbling and then stay bush next back wheel damper rubber . Sure this will resolve .
Apr 07, 2011 | 2007 Bajaj Pulsar 150
Only bass driver working on the pair. tweeter and mid range cones not working.
hi,
check the tweeter and mid range. its coil may become faulty.
for checking the speakers carefully remove the speakers one by one, remove its connections.
and check the speakers with a AAA cell. is it producing cracking sound. if not the speakers coils are burned.
ok
Feb 01, 2011 | Mission 782 Main / Stereo Speaker
Is the celestion truvox 0818mr a good midrange speaker?
there ok but i like RE AUDIOS USAMPS.There some sweet sounding mids.i have 6x9s and 5x7s
Nov 04, 2009 | Celestion Truvox 0818MR Car Speaker
Celestion g12l
I think that one reason for a speaker to rub is due to over heating of the voice coil. This happens when power is applied to the speaker that is greater than the speaker is capable of handling. A second cause could be that the suspension and or cone is damaged or degraded causing the coil to be tilted or off center. In either case nothing short of rebuilding the speaker can be done to repair the speaker. Rebuilding would involve removing the cone and voice coil and replacing with new items. If you were talented you might be able to repair the existing cone or voice coil but the results could be iffy.
Sep 08, 2008 | Celestion 20i Speaker
Tweeters poked to death
I know this sounds silly, but I had the same problem. Your speakers have a little plastic bulb that has been pushed in, right?
If so, simply put your mouth up to the tweeter, seal with your lips and **** gently (seriously). The tweeter dome should pop back out and in to shape.
It worked for me.
Good luck.
Aug 03, 2008 | Celestion AVF302 Main / Stereo Speaker
ALESIS M1 ACTIVE MK2 CONE VIBRATION!
Hello!
my speaker Alessis M1 Active 620, with a roar is very strong in the speaker, the potentiometer does not attenuate, change the volume. Ja switched capacitor C8, based on my research of other users, but got no result. When you press the power button, the LED lights in blue, and even change the color to red, producing a noise (snoring) very strong.
help!
Please help me!
Mar 17, 2008 | Alesis M1-Active-MK2 Powered Studio...
Celestion 15i Speaker Logo
600 people viewed this question
Top Celestion Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Rankin
Richard Lindsey ...
Are you a Celestion Audio Player and Recorder Expert? Answer questions, earn points and help others
