Question about Royal Office Equipment & Supplies
Teflon gear driven by the motor gear stripped on our VF1012MX crosscut -paper shredder
    Genius:
  • 1,218 Answers
Give Royal a call at 1-800-524-0799;... they will help regarding parts availability and prices.
Posted on Aug 22, 2010
Blades do not rotate, motor runs
Something is stripped. Most shredders are gear driven from the motor to the driver shaft and onto the driven shaft. Check that the motor has not come loose from its mountings, the drive gear has not come off the motor or the gear has stripped. You will have to split the shredder housings to do this.
Feb 22, 2011 | Fellowes Office Equipment & Supplies
MY ROYAL CROSS CUT SHREDDER VF1012MX WILL NOT ALLOW ME TO FED MORE INTO SHRED. THE MOTOR RUNS BUT THE BLADES DO NOT TURN. THIS HAPPENED AFTER IT JAMMED AND I REMOVED ALL PAPER.
Most likely broken plastic gear inside...open it up to see which one then contact Royal at 1-800-524-0799 for parts assistance.
Jan 16, 2011 | Royal VF1012mx Shredder
Machine is turned on- constantly running- but will not shred.
You say it is constantly running.....you can hear the motor running all the time???? Clean the "eyes" if there is something dust/tape etc, stuck on or covering the eyes that could account for it running all the time...but you say it will not shred....look into the cutting shafts where you insert the paper and see if the shafts are turning....if they are not; but the motor is running, then you also have likely stripped a gear or teeth inside off a gear. You will have to open the unit up to see what is broken...then contact Royal at 1-800-524-0799 for parts assistance.
Oct 29, 2010 | Royal VF1012mx Shredder
Thanks! I have a 7x Crosscut Paper Shredder, Model # PCUA:29053U. The teeth are jammed due to I believe a build up of paper. I have run it on reverse & tried to pick out the paper. The motor runs but...
If the motor runs but the cutting teeth dont turn then you have stripped or broken a gear in the drive train. You can get replacement parts from Royal at 1-800-524-0799.
Oct 19, 2010 | Royal Office Equipment & Supplies
A Royal crosscut shredder that usually only runs in reverse
in the middle of the paper enterance clean sensor
May 22, 2010 | Royal CIA 12X Shredder
Motor runs, but will not accept paper to shred
You say the motor runs...but can you see if the cutting shafts are turning???? if they are not then you have probably stripped a gear...open it up to determine which gear ( after unplugging machine of course.) then give Royal a call at 1-800-524-0799 for parts availability and prices.
Jan 17, 2010 | Royal VF1012mx Shredder
Lost Manual for Shredder
Not on-line that I know of but give them a call at 1-800-524-0799 maybe they can fax or e-mail something to you.
Jan 01, 2010 | Royal VF1012mx Shredder
Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
Aug 02, 2009 | Royal VF1012mx Shredder
VF810 unable to reset
You may have blown the pcb...give Royal a call at 1-800-524-0799 for parts assistance.
Jul 04, 2009 | Royal VF1012mx Shredder
Shredder motor runs but gears are not engaging and will not take up paper to be shredded. Model is Royal VF1012mx
I have the same problem and upon removing the gears I found one that is plastic and worn pretty bad. Replacement parts can be purchased at 1-800-222-2310. Part # VF1012MX-08 Gear #2
I advise purchasing the metal one.
Jun 30, 2009 | Royal VF1012mx Shredder
102 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
