Cub Cadet CUB CADET -Street Sign- tractor lawn riding mower parts
Problem for Cub Cadet CUB CADET -Street Sign- tractor lawn riding...
Cub Cadet 2008 1042 Series
By makarska1997 on Sep 28, 2009
I was mowing the lawn and my mower just died. I looked at the fuse and the 20 amp was blown. I replaced the fuse twice and after 10 minutes it blew again. The tractor has 18 hours on it and is pretty much in pristine condition. How would I identify a short? I have removed and replaced the cutting deck. Could that effect the wiring in any way? Thanks!
Comments:
Sep 29, 2009
- I think I have found the pinched wire. The outlet of the solenoid cable runs into a casing over the belt drive. It seems to be pinched in that area. What can I do to stop this from grounding?
Sep 30, 2009
- Thanks, that did it! Found the pinched wire, wrapped it and slung it up. Just spent 1 1/2 hours and no trouble.
Best Solution
posted on Sep 28, 2009
Very Helpful)
RonPark
Rank: Guru
Rating: 88%, 215 votes
If the problem occured after the deck work check everywhere you worked on the deck. You are lookining for a pinched wire. What is occuring is with the vibration of the mower running the pinched wire will rub and touch ground causing the fuse to blow and shut off the engine. Even if not concerning the deck that is what you have to look for. It can be time consuming but this is what you have to do. The short if not about the deck try checking the seat area this is a common area of problems with shorts in riding mowers.
Comments:
Sep 29, 2009
- Reroute the wire, wrap it in electrical tape, and tie it up out away from deck. Then you should be fine.
Sep 30, 2009
- I'm glad the problem is fixed. It may of taken awhile, but just think of the money you saved. A shop would of charged a small fortune knowing you would not know how long it took them to find short and repair. Good Job!!!!
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks. I was wondering, I used to check the distributor caps in my old cars in the dark with a mist of water. Could this work in a similar manner? " - makarska1997
Popular Solutions for Cub Cadet CUB CADET -Street
Questions and Unsolved Problems for Cub Cadet CUB CADET -Street
Do you recommend Cub Cadet CUB CADET -Street Sign- tractor lawn riding mower parts?
Answer
Answer
cub cadet 1042 wuth 42" ower does not cut even. This is my 3rd cud cadet and theu all have cut... (More)
Answer
when you press your bars @ the same time the left pump seems lazy. the left bar doesn't return to... (More)
Answer
the spring on the plastic flap is wrong somehow, never hit anything with it but the rod has worked... (More)
Describe your Power Lawn Mowers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Power Lawn Mower Experts
Top Garden & Power Tool Repairmen
in , AK
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
