Question about Air Tools & Compressors
Won't prime. Won't pick up paint. Works on and off. More off.
  • 3,600 Answers
The spring and pump plunger is not working due to paint build up try running solvent into the spray gun head and pump and let set for a couple of hours if this does not clean it up then I would suggest you by murat-ic acid from a pool shop and immerse the head in the murat-ic acid, when doing so do not breath the fumes and put it out in the open where there is no sparks. Let it stay in the murat-ic acid for a couple of ours this will eat away any organic material that has the gun plugged. wash throughly with fresh water before using.
Posted on Oct 02, 2009
Engine on 30"Craftsman 2009 snow thrower won't prime. Primer button and connecting tube look good. Primer button won't send gas to the carb.
the priming bubble can look totally perfect, but all it takes is a pin hole and right around the retaining ring is hard to spot a crack and you should also check fuel lines in tank
Jan 07, 2013 | managemylife.com
95 chevy pick up 5,7L . have spark, have fuel, won't start?
how much feul pressure, it must maintain a certain amount if injected, or throtle body, try priming it ,and see if it helps, ( poor a little into inlet ) and check it , if it starts you need to check pump, or maybe just filter
Nov 17, 2012 | 1995 Chevrolet Suburban
440i titan only pressure is between 0-200 psi no matter the setting
If an airless paint sprayer won't prime it's usually because one or both check balls are stuck. First try hitting the head where the pump is sharply with a hammer, hard enough to knock the balls loose but not so much that you do any damage to the pump. If that doesn't free them up you may have to take the pump apart and clean them and their seats.
If an airless paint sprayer won't develop pressure, it's usually because the packing rnigs are damaged or collapsed. The only way to check this is to totally disassemble the pump and check them. Also look for any damage to the piston and cylinder. They must be very smooth and shiney, if they are scored they will eat up any new packing rings you put in.
Jul 19, 2012 | Titan 440 Impact Airless Paint Sprayer...
My titan 330 airless paint spray will not shut off while primming
Airless paint sprayers should not turn off while in prime mode. As long as the prime valve is open the motor can pump paint but the system will not build any pressure. Once the prime valve is closed the pump should pump paint into the hose until it gets to the pressure level required to turn the motor off. If the pump does not turn off with the prime valve closed, it could be that the spring in the valve is weak and won't hold the valve closed under pressure. If the hose is up to pressure and the motor just keeps trying to pump paint, you may have a bad pressure sensor or it is disconnected from the circuit board.
Jul 10, 2012 | Air Tools & Compressors
My 2001 Chevy 2500 HD 6.6 L turbo diesel won't
fuel injection pump is failin or has issues--getta haynes manual for pro car maintenance
May 30, 2012 | 2001 Chevrolet Silverado 2500HD
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
289 ford motor showing no oil pressure. we have replased the oil pump, checked the bearings but can not find the problem. no oil for the top end, Help
You did "prime" the oil pump? If the oil pump isn't primed when you install it, the gears are "dry" and won't develop any suction to start pumping oil. Another issue cuold be the pick up screen. When you installed it, did you make sure the angle was correct, so that it sits just above the bottom of the oil pan?
Aug 14, 2011 | 1983 Ford Ranger
Wagoner Procoat Airless Sprayer without manual. Won't prime.
One cause for this is that one or both of the check balls in the piston are frozen in place. This can be caused by drying paint on the check balls or seats or, as is the case many times in our area, if you did clean the machine well with water without any airless conditioner in it, sometimes the water dries and leave behind minerals that 'lock' the check balls in the seats. Set the machine up in water and turn it on to prime. Using a hammer hit the pump head where the piston is working fairly hard. You are trying not to break anything but knock the check balls loose. If they come loose and water starts cycling through the system, let run a while to wash anything out before switching to paint. If this doesn't work, you may have to take the head apart to see why the check balls won't free up. It could be because of peices of dried paint that won't come loose by themselves.
Jun 16, 2011 | Garden
Air Tools & Compressors Logo
164 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
