Question about RTO Ledex Low Voltage Solenoid Drive Switch
I am looking for a low voltage fuel solenoid N/Open that can be fitted in to a car fuel line
  • 855 Answers
Try going to a speed or performance shop in your area. They should have or be able to order what you need.
Posted on Sep 28, 2009
Got p0748 p0108 code on my 04 honda odyssey. Car sat for about one year. Replaced fuel pump yesterday and it started right up. Can I get info on locations of where sensors are?
PO 748
service the transmission .....check solenoids
- Dirty transmission fluid - Low transmission fluid level - Faulty line pressure solenoid valve 'A' - Line pressure solenoid valve 'A' harness is open or shorted - Line pressure solenoid valve 'A' circuit poor electrical connection
Read more: http://www.autocodes.com/p0748.html
P0108
is the code for a problem with the MAP electrical circuit sensor having too high voltage input to the Engine Control Unit (ECU). This means that the voltage input to the ECU is too high and that it is not in the correct range for proper engine operation to work with inputs from the Mass Air Flow Sensor (MAF) and Throttle Position Switch (TPS). P0108 OBD II Trouble Code Manifold Air Pressure MAP Barometric Pressure...
odyssey map sensor is on the throttle body
Map sensor
Nov 10, 2016 | Honda Cars & Trucks
2011 dodge grand caravan engine malfunction light keeps coming on. Dealer traced it to a bad battery, had a new one installed and codes disappeared. Now light is back on. Codes P0740/P0562 show up
P0740 torque converter malfunction
Possible causes
Low or dirty transmission fluid
Faulty torque converter clutch solenoid valve
Torque converter clutch solenoid valve harness is open or shorted
Torque converter clutch solenoid valve circuit poor electrical connection
P0562 charging system voltage low
Possible causes
Low battery charge
Defective battery
Faulty alternator
Problem with belt
Open or shorted system voltage circuit
Jul 04, 2016 | 2011 Dodge Grand Caravan
Diesel filter changed, when driving along it will splutter and chokes off as if not getting fuel. can you help please.
Make and model May have air in the system. Most have a bleed screw on top of filter housing. Let the filter fill, then close
May 21, 2015 | Diesel Garden
John deere pdf manuals
Low hydraulic fluid will not prevent starting. The fuel filter shouldn't necessarily be full of fuel but if its empty my indicate lack of fuel flow. Look for debris in the fuel tank. A long skinny screw driver with a dab of grease on the end can be used to retrieve debris from bottom of tank. Remove the fuel line from the tank side of the filter and check for fuel flow. Blow into the line back into the tank then check for fuel flow. If it starts flowing then you will likely find a piece of debris in the tank. Reconnect the fuel line to the filter and remove from carb and be sure fuel is getting to carb.
If unit wont turn over. Check battery voltage: 12.6 volts or better. Be sure pto is off, unit is in neutral, and brake pedal is depressed. Check the fuse. Then with a test light check for 12 volts on the yellow or white wire on the small post of the starter solenoid with key in start position. If you have voltage to the solenoid but not to the starter then either the solenoid has a bad ground or is faulty and should be replaced. If no voltage to solenoid then you have a bad wire or switch between the fuse and solenoid. Voltage travels from fuse to ignition switch to pto switch to brake switch (to seat switch if it has four wire plug) to starter solenoid. You can use a test light to chase down where voltage stops.
Aug 24, 2014 | John Deere Tractor Starter 285 345 2243...
My x type 3.0 has fault readingP1647 could you tell me what this means please
OBDII DTC
P1001 Key on engine running unable to complete; key on engine running aborted
P1100 Mass air flow sensor intermittent
P1101 Mass air flow sensor out of self test range
P1104 Mass Airflow (MAF) Sensor Ground Circuit Malfunction
P1107 Left MAP Sensor Circuit
P1108 Right MAP Sensor Circuit
P1112 IATS Circuit High Voltage
P1113 IATS Circuit Low Voltage
P1121 Pedal Position Sensor Circuit A Range/Performance
P1122 Pedal Position Sensor Circuit A Low Voltage
P1123 Pedal Position Sensor Circuit A High Voltage
P1137 No Rear HO2S Response
P1138 No Rear HO3S Response
P1157 No Rear HO2S Response
P1158 No Rear HO3S Response
P1171 All Cylinders Too Lean
P1172 All Cylinders Too Rich
P1176 Adaptive Fuel Metering Trim Too Lean
P1177 Adaptive Fuel Metering Trim Too Rich
P1178 Adaptive Fuel Metering Trim Too Lean
P1179 Adaptive Fuel Metering Trim Too Rich
P1187 Both Front HO2S Heater Circuits (High Resistance)
P1188 Both Front HO2S Heater Circuits (Open Short to Ground High Resistance)
P1190 Both Front HO2S Heater Circuits (High Battery Voltage Short to Voltage)
P1193 Both Front HO2S Heater Circuits (High Resistance MAF Sensor Fault)
P1194 Both Front HO2S Heater Circuits (Open Short to Ground High Resistance)
P1196 Both Front HO2S Heater Circuits (High Battery Voltage Short to Ground)
P1198 Fuel Level Sensor (High Voltage)
P1199 Fuel Level Sensor (Low Voltage)
P1201 No. 1 Fuel Injector
P1202 No. 2 Fuel Injector
P1203 No. 3 Fuel Injector
P1204 No. 4 Fuel Injector
P1205 No. 5 Fuel Injector
P1206 No. 6 Fuel Injector
P1221 Pedal Position Sensor Circuit B Range/Performance
P1222 Pedal Position Sensor Circuit B Low Voltage
P1223 Pedal Position Sensor Circuit B High Voltage
P1224 Electronic Throttle Control Position Error
P1226 Mechanical Guard Circuit Range Performance
P1227 Mechanical Guard Circuit Low Input
P1228 Mechanical Guard Circuit High Input
P1229 Throttle Control Circuit Malfunction
P1230 Fuel Pump Relay Malfunction
P1235 VSV 1 Circuit Range/Performance
P1236 VSV 1 Vacuum Circuit Failure
P1237 VSV 2 Atmosphere Circuit Failure
P1238 VSV 3 Release Circuit Failure
P1240 Throttle Position Sensor Voltage Malfunction//Sensor Reference Voltage Low (Throttle
Fuel Tank Pressure)
P1241 Throttle Position Sensor Voltage Low Input//Reference Voltage Low (Throttle Fuel
Tank Pressure)
P1242 Throttle Position Sensor Voltage High Input
P1243 Throttle Position Sensor Ground Malfunction
P1245 Crank Signal Low Input
P1246 Crank Signal High Input
P1313 Misfire Catalyst Damage Bank No. 1
P1314 Misfire Catalyst Damage Bank No. 2
P1315 Misfire Excess Emissions
P1316 Misfire Rate Above Limit
P1335 Crankshaft Position Sensor Circuit
P1336 Camshaft Position Sensor (CMP) Circuit Performance
P1361 Ignition Coil Primary Circuit (Cylinder No. 1)
P1362 Ignition Coil Primary Circuit (Cylinder No. 2)
P1363 Ignition Coil Primary Circuit (Cylinder No. 3)
P1364 Ignition Coil Primary Circuit (Cylinder No. 4)
P1365 Ignition Coil Primary Circuit (Cylinder No. 5)
P1366 Ignition Coil Primary Circuit (Cylinder No. 6)
P1367 Ignition Monitor (Bank A)//Ignition System Failure Group 1
P1368 Ignition Monitor (Bank B)//Ignition System Failure Group 2
P1371 Early Activation Ignition Coil (Cylinder No. 1)
P1372 Early Activation Ignition Coil (Cylinder No. 2)
P1373 Early Activation Ignition Coil (Cylinder No. 3)
P1374 Early Activation Ignition Coil (Cylinder No. 4)
P1375 Early Activation Ignition Coil (Cylinder No. 5)
P1376 Early Activation Ignition Coil (Cylinder No. 6)
P1392 Variable Valve Timing Solenoid A Low Input
P1393 Variable Valve Timing Solenoid A High Input
P1396 Variable Valve Timing Solenoid B Malfunction
P1397 Variable Valve Timing Solenoid B Low Input
P1398 Variable Valve Timing Solenoid B High Input
P1400 EGR Valve Position Circuit (Valve Sticking Open or Short)
P1401 EGR Valve Position Circuit (Open Short to Ground)
P1408 EGR Temperature Sensor Circuit
P1409 EGR Valve Circuit
P1440 EVAP Purge Valve Open
P1441 EVAP Valve Circuit
P1443 EVAP Valve Circuit
P1447 EVAP Valve Circuit
P1448 EVAP Valve Circuit
P1454 EVAP System
P1474 Charge Air Coolant Pump Relay
P1475 Radiator Fans Slow Malfunction
P1476 Radiator Fans Fast Parallel Circuit Malfunction
P1506 Idle Speed Control Circuit (Low RPM; Bank B)
P1507 Idle Speed Control Circuit (High RPM; Bank B)
P1508 Idle Speed Control Circuit
P1509 Idle Speed Control Circuit
P1512 Throttle Position Sensor Idle Switch Sense Circuit
P1513 Throttle Position Sensor Idle Switch Sense Circuit
P1514 Park/Neutral Position Switch High Load Neutral/Drive
P1516 Gear Change Park/Neutral Malfunction
P1517 Engine Cranking Park/Neutral Malfunction
P1607 MIL Output Circuit
P1608 Automatic Transmission
P1609 Internal ECM Error
P1641 Fuel Pump Relay No. 1
P1646 Fuel Pump Relay No. 2
P1739 Automatic Transmission
P1775 Transmission Control Module MIL Circuit
P1776 Torque Reduction Request Signal
P1777 Torque Reduction Circuit
P1780 Automatic Transmission
P1781 Automatic Transmission
P1782 Automatic Transmission
P1783 Automatic Transmission
P1785 Automatic Transmission
P1790 Automatic Transmission
P1791 Automatic Transmission
P1792 Automatic Transmission
P1794 Automatic Transmission
Mar 22, 2013 | Jaguar Cars & Trucks
2000 toyota camry 2.2L obd code p0441
P0441: Evaporative Emission Control System - Incorrect Purge Flow
This indicates that a part of the EVAP control system is no longer fuctioning correctly. The EVAP system consists of many parts, including (but not limited to) the gas cap, fuel lines, carbon canister, purge valve, and other hoses.
The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
Possible causes:
  • Bad vacuum switch
  • Broken or damaged EVAP line or canister
  • Open in PCM purge command circuit
  • Open or short in Voltage feed circuit to Purge Solenoid
  • Faulty purge solenoid
  • Restriction in EVAP solenoid, line or canister
  • Corrosion or resistance in purge connector
Possible solutions:
  • Replace Leak Detection Pump / LDP (if applicable to your vehicle)
  • Repair damaged EVAP lines or canister
  • Repair open or short in voltage feed circuit to Purge Solenoid
  • Repair open in PCM purge command circuit
  • Replace purge Solenoid
  • Replace vacuum switch
  • Repair restriction in Evap line or canister or soleniod
  • Repair resistance in purge connector
  • Check ALL the above until you correct the issue. NEVER replace PCM, unless you prove the PCM to be faulty (as a last resort).
    Cheers,
    Jun 08, 2011 | 2000 Toyota Camry
    Is there a list for computer codes for 1980-1990's Chrysler Le Baron
    Yes here is that list.
    Chrysler products COMMON CODES OBD1 (vehicles made before 1995)
    Part 1: Chrysler Domestic vehicles
    CODES/Meaning
    88 display used for start or test
    11 camshaft signal or ignition signal, no reference signal during cranking
    12 memory to controller has been cleared within 50-100 engine starts
    13 map sensor not detecting any change during test
    14 map voltage too high or too low
    15 vehicle speed sensor, no signal detected
    16 knock sensor circuit. open or short detected
    17 low engine temperature, possible thermostat fault
    21 oxygen sensor signal, neither rich or lean detected
    22 coolant sensor voltage low
    23 air charge voltage high/low detected
    24 throttle positioner sensor voltage high/low
    25 automatic idle speed motor driver circuit, short or open detected
    26 injectors 1,2,3 peak current not reached
    27 injector control circuit does not respond to control signal
    31 purge solenoid circuit, open or short detected
    32 egr solenoid circuit, open or short detected
    33 a/c clutch relay circuit, open or short detected
    34 speed control servo solenoid, open or short detected
    35 radiator fan control relay circuit, open or short detected
    36 wastegate solenoid, open or short detected
    37 part throttle unlock(PTU) circuit, open or short detected
    41 charging system circuit not responding to control signal
    42 fuel pump or auto shutdown (ASD) relay voltage sensed at controller
    43 ignition control circuit not responding
    44 battery temperature voltage circuit problem
    45 turbo boost limit exceeded-map sensor detects overboost
    46 battery voltage too high
    47 battery voltage too low
    51 air/fuel at limit
    52 logic module fault
    53 internal controller failure
    54 camshaft reference circuit not detected
    55 end of message
    61 baro read solenoid, open or short detected
    62 emr mileage not stored
    63 eeprom write denied
    64 flex fuel sensor signal out of range
    65 manifold tuning valve, open or short detected
    66 no ccd messages
    76 ballast bypass relay, open or short detected
    77 speed control relay, open or short detected
    May 31, 2011 | Chrysler LeBaron Cars & Trucks
    What is evaporation control system malfuction mean? The code is P0440
    Hi, the computer has sensed through the fuel tank pressure sensor that the vapor cannister is not evacuating properly. I have pasted details on the EVAP system below. Check the purge valve on top of the engine as shown below (#1 in picture). Make sure the electrical connector is on the valve, that the wires are not damaged, and check the hose for kinks. If all looks good, I recommend you replace the valve. A new valve is $23 at autozone. Please let me know if you have more questions and thanks for using FixYa.
    Description & Operation
    EVAP Canister
    The canister is filled with carbon pellets used to absorb and store fuel vapors. Fuel vapor is stored in the canister until the control module determines that the vapor can be consumed in the normal combustion process.
    EVAP Control System
    The evaporative emission (EVAP) control system limits fuel vapors from escaping into the atmosphere. Fuel tank vapors are allowed to move from the fuel tank, due to pressure in the tank, through the vapor pipe, into the EVAP canister. Carbon in the canister absorbs and stores the fuel vapors. Excess pressure is vented through the vent line and EVAP vent solenoid to atmosphere.
    The EVAP canister stores the fuel vapors until the engine is able to use them. At an appropriate time, the control module will command the EVAP purge solenoid ON, open, allowing engine vacuum to be applied to the EVAP canister. With the EVAP vent solenoid OFF, open, fresh air will be drawn through the solenoid and vent line to the EVAP canister. Fresh air is drawn through the canister, pulling fuel vapors from the carbon.
    The air/fuel vapor mixture continues through the EVAP purge pipe and EVAP purge solenoid into the intake manifold to be consumed during normal combustion. The control module uses several tests to determine if the EVAP system is leaking.
    The EVAP system consists of the following components:
    EVAP Purge Solenoid
    The EVAP purge solenoid controls the flow of vapors from the EVAP system to the intake manifold. This normally closed solenoid is pulse width modulated (PWM) by the control module to precisely control the flow of fuel vapor to the engine. The solenoid will also be opened during some portions of the EVAP testing, allowing engine vacuum to enter the EVAP system.
    EVAP Service Port
    The EVAP service port is located in the EVAP purge pipe between the EVAP purge solenoid and the EVAP canister. The service port is identified by a green colored cap.
    EVAP Vent Solenoid
    The EVAP vent solenoid controls fresh airflow into the EVAP canister. The solenoid is normally open. The control module will command the solenoid closed during some EVAP tests, allowing the system to be tested for leaks.
    Fuel Tank Pressure Sensor
    The FTP sensor measures the difference between the pressure or vacuum in the fuel tank and outside air pressure. The control module provides a 5-volt reference and a ground to the FTP sensor. The FTP sensor provides a signal voltage back to the control module that can vary between 0.1-4.9 volts. As FTP increases, FTP sensor voltage decreases, high pressure = low voltage. As FTP decreases, FTP voltage increases, low pressure or vacuum = high voltage.
    Feb 10, 2011 | 2002 Chevrolet TrailBlazer
    What is the 1987 pontiac fiero gt v6 check engine light code list?
    CODE 12- NO DISTRIBUTOR REFERENCE PULSES ECM. CODE 13- OXYGEN CIRCUIT. CODE 14- COOLANT SENSOR HIGH TEMP CODE 15- COOLANT SENSOR LOW TEMP. CODE 21 - THROTTLE POSITION SENSOR VOLTAGE HIGH.CODE 22 - THROTTLE POSITION SENSOR VOLTAGE LOW.CODE - 23 MIXTURE CONTROL SOLENOID.FOR CARBURETOR ENGINE. CODE 24 -VECHICLE SPEED SENSOR. CODE 32 - BARO CIRCUIT LOW.CODE 32 - FUEL INJECTED EGR VALVE VACUUM SWITCH SHORTED TO GROUND.OR EGR VALVE SOLENOID CIRCUIT OPEN. CODE 33 - MAP SENSOR.CODE 34 - VACUUM SENSOR OR MAP SENSOR.CODE 35 - IDLE SPEED CONTROL. CODE 41 - EST CIRCUIT. CODE 42 - ELECTRONIC SPARK TIMING.CODE 43 - ELECTRONIC SPARK CONTROL UNIT. CODE 44 - LEAN EXHAUST.CODE 45 - RICH EXHAUST. CODE 51 - PROM OR MEM CAL.CODE 52 - CALPAK. CODE 53 -EGR VALVE CARBURETED ENGINE THE EGR VALVE VACUUM SENSOR HAS RECEIVED IMPROPER EGR VACUUM. CODE 54 - M C SOLENOID CARBURETED ENGINE MIXTURE CONTROL SOLENOID SHORTED OR FAULTY ECM.CODE 54- FUEL INJECTED ENGINE FUEL PUMP VOLTAGE IS LOW.CODE 55 - ECM MAKE SURE PCM GROUND CONNECTIONS ARE TIGHT.IF OKAY.REPLACE THE ECM.
    Mar 27, 2010 | 1987 Pontiac Fiero
    I would like to check the presure on 2007 F350 6.0 heui pump. how can i go about it. l'll be using a presure gauge, but i don't know where to install it, also where is the heui pump located? i would also...
    glow plug relay should be on the front are rear of intake.you have a mechanical low pressure pump on the passenger side low near the front. or a electric low pressure pump on the starter side. your truck should have the low pressure electric pump. to check fuel pressure you disconnect the out let line to do a out put test.on the electric low pressure pump.put out let line in a container.crank engine for 20 to 30 sec.you should have a good flow of fuel no dribbles.if dribble replace low pressure electric pump.the mechanical low pressure pump out put test you disconnect fuel line from the fuel filter inlet line.disconnect wire at fuel injection pump electric shut off solenoid .place the fuel line in a container. crank engine for 20 sec. fuel flow looks good.pump is good .if dribbles.replace mechanical low pressure pump.to check glow plug relay you need a .diesel repair ford manual to show you where to put a test light to check the relay.WEAR SAFETY GLASSES WHEN WORKING ON DIESEL ENGINES.DONT DISCONNECT THE INJECTION PUMP LINES WHILE ENGINES IS RUNNING.THE FUEL PRESSURE IS SO HIGH SPRAY IN YOUR EYE CAN CAUSE BLINDNESS.GET IN SKIN OR SORE CAUSE BLOOD POISON. CAN ALSO CAUSE A FIRE BE VERY CAREFUL.
    Apr 16, 2009 | 2003 Ford F350 Super Duty DRW SuperCab
    RTO Ledex Low Voltage Solenoid Drive Switch Logo
    51 people viewed this question
    Top RTO Electrical Supplies Experts
    Ottoniel
    Steve
    Tom Chichester
    Are you a RTO Electrical Supply Expert? Answer questions, earn points and help others
