Question about Cameras
Polaroid t1035, lense wont full retract or extend wont power up
SOURCE: Beeps repeatedly, lense won't retract...won't take pictures?
Hi Jeanice21, I just posted the same problem a few minutes ago with my SD400. I followed a few steps of the suggested solutions and here's what worked for me.
1) take apart the front and back by unscrewing the six screws holding the camera together
2) on the left of the flash, there are two little retangular holes with grooved dials in them
3) using a little flat head screwdriver, push up or down to turn the grooves while power up in the movie or capture mode
4) the lens retracted at this point and my camera started working again. Good luck!
Posted on Dec 30, 2008
t00nz
  • 4738 Answers
SOURCE: Lense is extended but will not retract combined
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Jul 23, 2009
  • 8 Answers
SOURCE: Hi, my Nikon Coolpix s210 displays a Lense Error
you should take it do the shop because somthing might be stuck or it could have a malfunction well i dont no exactly i jus say go check it out
Posted on Oct 11, 2009
  • 244 Answers
SOURCE: lens wont retract or extend when pushing the power
Can you turn the camera on by pressing the playback button? This should turn the camera on to view pictures on the card without opening the lens.
Check the tab on the battery door. it should activate a micro switch next to the card slot on the main board. If this is damaged then the camera will not power up.
If the lens is stuck then this will also prevent power up
Posted on Nov 15, 2009
SOURCE: I have a new Polaroid t1035 camera and got a
Try a new card.. I had the same problem. It turned out to be a defective card.
Posted on Jan 03, 2010
I have a Polaroid t1035. When turning the camera on and off the lens will not collapse and makes a clicking noise.
This is a common issue with retractable lenses. A grain of sand, accidentally pressing the On button when still in the bag etc.
In most cases the problem is of mechanical nature - meaning one of the gears is stuck. The small motor doesn't have enough power to push through it.
Depending on the model - there are sometimes tricks to get the lens going again. It involves manually helping the lens to come out. There's a risk of permanent mechanical damage.
Jun 30, 2011 | Cameras
I turn on my polaroid t1035 and it automatically shuts down right away
Oct 08, 2010 | Polaroid i1035 Digital Camera
Jammed lens
When you turn it off, does the lense go up and down. If yes good news. while turning the camera off press on the lense very softly (up and down motion) until the lense retracts 100% or almost 100%. you may have to try a few times. if almost 100% retracted, push the lense a little harder in, untill it retracts all the way in. Turn it back on, it should work now. If you do not keep your lense clean you get that problem. After you droped it, some mechanical part on the lense may have broken or dislocated. In this case you have to open the lense inspect the parts, clean them and puth them back together.
Jun 08, 2009 | Polaroid i830 Digital Camera
Dropped Sony Ciber-shot when lense was extended. Will not fully extend or retract now. How do I remove lense assembly to reset position.
sir,
open your camera,beside the cam part u can see the small gearbox, un screw this part and disconnect it from the base, then slowly turn the lense assy to both side carefully, dont give force. if the lense assy becom loose, fix the gear unit give a 3volt to the motor bring the cam to retracted position,then fix whole unit, it will work properly
thanx,
gulshanclt
Sep 03, 2008 | Cameras
The lense does not close in
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 03, 2007 | Samsung Digimax S500 Digital Camera
Lenses
Your camera's problem is with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 15, 2007 | Canon PowerShot SD850 IS Digital Camera
Unknown
Easy just grab it pull and twist and pull it to full out and power it on and off
Dec 04, 2006 | Fuji FinePix E550 Digital Camera
Cameras Logo
254 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
