Question about Canon PIXMA MP130 All-In-One InkJet Printer
I have a pixma MP110. I replaced the black
I have a pixma MP110. I replaced the black cartridge and keep getting ''put in cartridge black ink low'' messege. What should I do?
SOURCE: Cannon Pixma 160 - How do I reset the ink level indicator
crapt the driver
Posted on Oct 21, 2008
worldvet
  • 859 Answers
SOURCE: mp470 pixma
Do you still need help with this problem?
Regards,
Worldvet
Posted on Nov 23, 2008
Bfsas1
  • 258 Answers
SOURCE: canon pixma mp110 says-check ink tank. ??
it is saying that your ink is getting low, or make sure the ink cartridges are clipped into printer properly, welcome
Posted on Jul 01, 2009
pineworks
  • 4041 Answers
SOURCE: Canon Pixma MP110 - Error 5100, cartridge jammed,
Hi You can Try
seen lots of this errors
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
pineworks
  • 4041 Answers
SOURCE: my canon pixma ip3000 will not print in black ink
Hi There
Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Posted on Apr 30, 2010
Printer mp110 ink problems!
it is your head!Its not reading that it is installed!
Apr 01, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error 5200
Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
Aug 13, 2009 | Canon Pixma MP480 All-In-One InkJet...
Canon pixma mp110 says-check ink tank. ??
Jul 01, 2009 | Canon PIXMA IP3500 Photo Inkjet Printer
Canon pixma MP110 waste ink absorber full
1 - Turn on the printer
2 - press MENù SCAN COPY SCAN (it will enter in service mode)
3 - select TEST MODE
4 - Select PRINTER TEST in TEST MODE
5 - Select EPROOM CLEAR
6 - Select INK COUNT
7 - Press OK
8 - Press the STOP/RESET key and then press the ON/OFF key
9 - Change the waste ink absorber in the printer
Oct 24, 2008 | Office Equipment & Supplies
Black Printer cartridge
It will tell you the colour is low, regardless of the format in which you are printing. I don't believe Canon provide a way for you to disable this for their printer range, so you'll need to put in the new colour cartridge to get rid of this error. (you should however, be able to print whilst receiving this message)
Jun 19, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon printer pixma mp110
how can i reset canon pixma mp 110 tahnk you please help me
Jun 02, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
How to Override Ink Level Gauge When Using Refilled Cartridges
This maybe in the manual under ink tank replacement, most cannons have this, but keep in mind that sometimes the ink feed tubes to the print head get clogged and then the printer will report no ink at all, these cansometimes be cleaned by soaking them in acholol
May 28, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
Mar 16, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Error 5200
my printer is not working. its showing error(5200).what can i do to solve this problem.
Dec 08, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
old marine
old marine
