Question about Midland 77-092 40-Channels Base CB Radio
I want to install a car cb in my house, what do i need to convert it so i can use it indoors? can this be done? i read to use a 12 volt inverter, but the cb has only wires that have been cut, no cigarette plug only cut wires. help please. thanks Teresa
  • 439 Answers
Ok, these are hard wire for installing in a vehicle. There are a few ways, of the easiest would be the 12v converter. You can do this by purchasing a cigarette plug and wiring it in. Red to red and black to black. If you do not want to go this way, you can use a battery charger for a vehicle to power your cb then everything else is just like a car.
Posted on Sep 28, 2009
Testimonial: "Thanks!that was exactly what I needed. I am going to go to the "shack" tomorrow and get a cig plug and a 12v inverter so I can get it working.Thanks!!"
  • 1 more comment
  • Radiojunkie Sep 02, 2010
    If you decide to use a battery charger be prepared to hear complaints of a "humming noise" when you transmit. You may want to find a filtered power supply. You can also use a 12v Battery if you mount it outside for safety reasons.
    JTRadiojunkie
  • richey009 Nov 20, 2010
    hi i got a problem with my radio
    i got this midland 77-092 CB radio
    it first happened when i putted the antenna with has magnet base on the radio, the radio has metal casing, and it began to make a weird noise, after that got quite but smoke started to come out, so i got it off, then opened it to check it, and seems to be a 3 pinned transistor that is also welded to the casing(guess is the ground terminal or transistor)that got fried, so i don't know if was the magnet of the antenna that cause it.
    radio still powers up but like for 30 seconds it will start to smoke again from that piece.
    i will like to know if this piece can be found somewhere so i can replace it, and will appreciate, link or at least pics so i can look for it in local market.
    thanks
  • lee68 May 29, 2011
    putting your antenna directly on the case caused you to have a bad standing wave ratio. Frying the final transistors is the norm for keying the radio with a bad match.
Can these be battery operated? If so can this be done.
Yes, you go through a converter.Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DC AC Power Inverters 12 Volt DC to AC Inverter
12 Volt DC To 110 Volt AC Power Inverter for Auto RV and Boat compatible...
Mar 12, 2016 | Mediasonic HomeWorX HW-150PVR ATSC Digital...
Need to convert to 12 volt dc
It can not be done.
Battery terminals are not isolated from the mains it is very dangerous to draw out the connections out of the box!
Buy another inverter simply ...
Jun 17, 2014 | HP (APC2R120) UPS System
Diagram setting up cb radio in house
That depends on your power source and what type of antennae you're using. Can you tell us if your antennae is a mobile antennae or a home/base station antennae? What is your power source, a car battery or a 120 volt AC to 12 volt DC converter? More info is good.
Mar 02, 2014 | Cobra Dynascan 21 21a 23-ch 23-channel Am...
Cb is buzzing when i hooked it up in the house
If a cobra 29 as indicated here what are you using for power for it? If a base radio as indicated it also has a 12 volt connection--if no problem via the 12 volt connection the fault is in the built in power supply the radio has.
All "Base" radios have 12 volt connection and their own internal power supply to operate off wall voltage.
Apr 23, 2012 | Cobra 29 WX NW ST 40-Channels Base CB...
Got given a CB radio.. from a trucker... im in the [UK] wanting to put it in my car.. accept the voltage difference... a truck's voltage is about 24-volt's.. compared to a car.. only being 12...
I don't think there is a in accessories. The 24 volt truck systems are Cranking and Lighting. Either way you have no risk at trying the lower 12 volt car electrical. The problem is when you reverse polarity.
Aug 21, 2011 | Radio Communications
Input of 120 volts to fit an inverter
An inverter turns 12 volts into 120 volts. A converter turns 120 volts into 12 volts.
Mar 05, 2011 | Computers & Internet
I want to install my playstation 3 in my car but im not sure about the hookup
get a power inverter..it converts 12 volts dc (car voltage) into 110 volts ac (house outlet voltage). i would go with at least a 400watt. the playstation 3 consumes approximately 380 watts. also get an fm modulator to send the playsation's audio into the car radio via the fm tuner. unless the radio has aux inputs, if so connect the ps3 audio into that. there are plenty of video monitors out there that run on twelve volts too.
Mar 10, 2010 | Car Audio & Video
Just do not understand it at all! can you help with model ar-ry7?
An inverter uses 12 volt DC current and inverts it to 110 volt AC current.
Basically, it will take 12 volts from a car battery, and change it to 110 volt current , same as in your house. What part are you having problems with?
Jan 03, 2010 | Fujitsu Electronics - Others
Install cb in house
you will need a 12 volt converter for this
Sep 01, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
I just bought a 1977 Dodge Monaco Motorhome and just replaced the house battery with a brand new marine battery. Now I'm finding that it runs all the lights and everything except the 110 outlets. I need to...
It is called an inverter, and it may not be hooked up, u will have to trace the source power for the outlets and at the source add an inverter to change 12 volts DC to 110 volts AC.
Dec 13, 2008 | Dodge Pickup Cars & Trucks
Midland 77-092 40-Channels Base CB Radio Logo
570 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
