Question about Rode NT-2000 Professional Microphone
This mic likely has a built in preamp. BEFORE you open the mic, verify that your pahntom power from your preamp is clean.
If you are unfamiliar with phantom power for mics, google it to find a treatise.
Noisy or failing phantom power could be your problem. Also the preamp in the mic could have a problem rather than the diaphram. Dust would NOT normally cause what you are describing.
Posted on Sep 30, 2009
Testimonial: "See comments above."
It was likely the foam thing toching the diaphram rather than the dust unless the dust was in clumps, given your description of the sound. I would be very careful using crazy glue as the glue is brittle and slightly water soluble. A fairly safe pliable glue that can be removed when needed I have found is the 3m weatherstrip adhesive used for automotive purposes..
Apr 01, 2014 | Rode NT1A Professional Microphone
Aug 31, 2011 | Rode NT1A Professional Microphone
Jan 30, 2011 | Rode NT1A Professional Microphone
Dec 20, 2010 | Samson CO2 Professional Microphone
Apr 21, 2010 | Whirlpool GD5SHAX Side by Side...
Nov 09, 2009 | Rode NT1A Professional Microphone
Jun 22, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Jun 04, 2009 | Rode NT-2000 Professional Microphone
Nov 12, 2008 | Rode NT-2000 Professional Microphone
Jun 02, 2008 | Rode NTK Professional Microphone
195 people viewed this question
I appreciate the comment, here's what I did to fix it.
- Opened up the body and head of the microphone.
- Very carefully used compressed air to remove dust on both large diaphragms (you could easily tear the diaphragms, be very very careful).
- Reseated the grounding screws along the pc board.
- I also repaired the top foam piece which connects to the top of the diaphragm assembly and presses against the grille assembly when fitted together. This was torn (still soft and usable), this alone could have been the cause of the issues by transferring unwanted vibrations directly to the diaphragm frame. Using crazy glue worked like a charm. While inside I felt comfortable enough doing some basic cleaning which could only help.
Before opening the microphone, I of course checked all of the obvious troubleshooting techniques and everything pointed directly to the microphone itself. I have three of these microphones, all of the same age, and only one exhibited these sorts of issues.
If the above did not work I would highly suspect the polar pattern potentiometer as there has been known issues. This would normally cause a different noise than I was hearing though. Since while moving the potentiometers while listening I did not hear any variants in the fluttering noises I was experiencing, this solidified concerns of grounding, dust, or even a loose part inside.
In conclusion, maybe I got lucky, but I was comfortable in my ability to troubleshoot and come to a reasonable solution that ended up working. Anything beyond the above I would have sent it in for dealer repair. I'm an audio engineer, not a microphone repair guru, it all worked out in the end. :)
Here's some pictures during the repair: http://gallery.mac.com/briankross#100570
