Question about Brother HL-2070N Laser Printer
All lights are on - none flashing, won't print
We lost power for a a few minutes and the printer will not print. All lights remain on, even after being disconnected from the computer and power.
Any suggestions to reset the printer?
  • 2880 Dec 19, 2007
    Suggestion had already been tried, as mentioned in my problem statement posted.
  • Anonymous Mar 03, 2008
    all lights are on - none flashing, won't print
  • Brother Master
  • 1,113 Answers
See my other post no reset needs to be repaired
http://www.fixya.com/support/t310953-all_four_lights_blinking
Posted on Dec 24, 2007
    President:
  • 4,402 Answers
1. Turn power switch off and then on.
2. Leave the printer for 10 minutes with its power on.
3. Contact Authorized Service Center if condition does not change.
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000100/000070/faq000170_005.html?reg=eu&c=gb&lang=en&prod=hl2070n_all
Posted on Dec 18, 2007
It won't print and the light keeps flashing. I lost the instructions!
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Feb 13, 2012 | Lexmark X1240 All-In-One InkJet Printer
Printer trouble
Try following this steps:
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
Hope that helps........
Aug 09, 2008 | Office Equipment & Supplies
I've changed the ink cartidges but the black and color ink lights remain on and it won't print. I think the E2 error message is on.
This hapens when refilled cartridges are installed in the printer. To rectify the problem, look for the 'Resume button' normally black with a red circle around an arrow head pointing towards you. With the printer powered on, press and hold this button down for about 10 seconds. The error code will usually clear and the printer will print but the orange lights will still flash.
Sep 11, 2011 | Canon PIXMA MP160 All-In-One InkJet...
HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
None of the cartridges can be empty if you want to print.
Even if you only want to print black, just black you need to
replace the other three cartridges.
Yes color laser printing is expensive.
Jul 14, 2011 | HP Color LaserJet 2600n Printer
Printer prints out blank pages
Follow these steps:
1. Load a few sheets of plain paper in the sheet feeder.
Turn off your printer.
Hold down the paper button as you press the power button to turn the printer back on. Hold down both buttons until the power light begins to flash, then release the buttons.
The printer prints its test page, which includes a nozzle check. Does the paper print out without any gaps or with gaps? If there are do this:
2. Load a few sheets of plain paper in the sheet feeder.
Make sure the printer is on and the ink light is off.
Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Head Cleaning.
Follow the on-screen instructions to start the cleaning cycle, which lasts about 1 minute. The power light flashes throughout the cleaning cycle and stays on green when the cycle is finished.
Caution:
Never turn off the printer during a cleaning cycle or you may damage it.
When the power light stops flashing and remains on, you can check to see if the nozzles are clean. Click Print Nozzle Check Pattern and click Print. Check the printed nozzle check pattern to see if there are gaps in the lines.
If there are no gaps, click Finish.
If there are gaps or the pattern is faint, click Clean to clean the print head again.
You may need to clean the print head up to 4 times. You can also turn off the printer and wait at least 6 hours. Then try printing again.
If this doesn't work then double check that you have the toner cartridges in correctly. If you do then your print head is broken and/or burned out and it's best to just replace the printer. Fixing it would cost more than the printer itself
Jan 17, 2011 | Brother MFC 420CN All-In-One InkJet...
How do you load new printer cartriges
To replace an ink cartridge using the fonth.gif ink button, follow the steps below.
1. Make sure that the printer is on. The fontp.gif power light should be on, but not flashing.
2. Lower the output tray, then open the printer cover.
3. Press the fonth.gif ink button. The print head moves to the ink cartridge replacement position, the fontp.gif power light begins to flash, and the fonth.gif ink out light corresponding to the ink cartridge that needs to be replaced begins to flash or remains on.
4. Open the cartridge cover. Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it.
5.Remove the new ink cartridge from its protective bag. Place the ink cartridge vertically into the cartridge holder. Then, push the ink cartridge down until it clicks into place. Do not apply excessive force to the cartridge.
6. When you are finished replacing the cartridge, close the cartridge cover and the printer cover.
7. Press the fonth.gif ink button. The printer moves the print head and begins charging the ink delivery system. The fonth.gif ink lights start flashing. This process takes about one minute to complete. When the ink charging process is finished, the printer returns the print head to its home position. The fontp.gif power light will stop flashing and remain on, and the fonth.gif ink out light will turn off. The fontp.gif power light will continue to flash while the printer is charging ink. Never turn off the printer while this light is flashing.
Nov 19, 2010 | Epson Office Equipment & Supplies
Brother HL-2140 Error light is flashing
Try to unplug the power from the print, wait 1 minute then plug back in.
This may remove the error.
Sep 26, 2009 | Brother HL 2140 Laser Printer
Both paper feed and power lights flash after printing several pag
lean head-eject ink ruler & clean point of contact betwin cartridges and head-ink unit.
Aug 07, 2009 | HP DeskJet 970cxi InkJet Printer
ALL THE LIGHTS ARE KEEP FLASHING ON AND OFF
Unplug the printer from the power strip or wallk outlet for a few minutes.
Disconnect the printer from the computer see it it powers up normally, if so connect it to the computer.
If the lights are still lit, and the printer is brand new, and none of the suggestions helped, call the manufacturer as it is in warranty.
Good Luck
Feb 16, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printer trouble
Power cycle the printer. If problem remains, try a partial reset. You can do the partial reset as follows:
1. Unplug and replug the unit.
2. when lights flash on power up, hold down the ON/RESUME and PAGE SIZE buttons together.
3. When only the ON/RESUME button light flashes, you can release the buttons.
4. When the lights stop flashing, the reset is all done!
If problem remains, you are fully justified to ask HP to replace the unit for you (well, if you're still in warranty!). Good luck :)
Jan 18, 2008 | Office Equipment & Supplies
Brother HL-2070N Laser Printer Logo
106 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
