Question about HP DeskJet 5740 InkJet Photo Printer
I just put both color and black cartridges in my hp 5740. It shows ink levels almost empty. what must I do to show correct levels?
  • 27 Answers
SOURCE: HP Photosmart 8450 Ink Level Indicator
replace the ink cartridges
Posted on May 31, 2008
Viriiguy
  • 77 Answers
SOURCE: estimated ink levels are incorrect
The simple solution is to buy the HP cartridges. Often times,.. MOST times, aftermarket ink cartridges and refill kits are an inferior product. The difference is not always noticeable right away, but almost always rears it's head in the end. This is usually due to the ink being of a different viscosity than the original ink. Which leads to sloppy prints, sensor errors, leaky or dead jets.
Personally I recommend everyone buy Laser printers. With prices where they are these days, there is no reason for anyone to buy an inkjet printer. Lasers will cost more up front, but are much cheaper per page and generally longer lasting.
Posted on Feb 15, 2009
jell587
  • 447 Answers
SOURCE: How can I tell if an ink cartridge is empty?
You didn't mention your operating system so I'll assume that it's Windows. If this is not the case please post additional info...
Many times the ink levels can be checked through the print driver properties and/or the maintenance tab within the printer properties.
Open the printer folder + right click on the printer icon + properties. See if there is a maintenance tab, this will contain the alignment and cleaning utilities also.
Posted on Feb 21, 2009
  • 6 Answers
SOURCE: reset ink level on hp 6310 #98 cartridge
if you are using a refilled catridge you would not get ink levels right.
if you want right ink level use genuine ink catridges.
you can try taking out the catridges turning off the printer and turning it back on and then reinstalling the catridges.it might not help so if possible buy hp ink catridges.
Posted on Aug 28, 2009
  • 107 Answers
SOURCE: My refilled ink cartridge still displays empty and will not print
The ink cartridge is most likely chipped & you would not be able to reset the ink level. Purchase an original or a good compatible cartridge. Refiling newer cartridges is not a good idea.
Posted on Oct 21, 2009
When I put a new Black ink in my Canon MX452 it shows my black as empty
Hi
if the black cartridge is genuine and new...take it back. It is faulty.
If the cartridge is refilled or compatible...hold the STOP button for 6+ seconds to disable ink monitoring. This should clear the 'empty' error and the printer should work again.
good luck!
May 17, 2014 | Canon PIXMA Office Equipment & Supplies
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Canon printer wont print colored how to reset chip
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On your printer this happen with push consistently buttons for black copy (for turn off level on black cartridge) and color copy (for turn off level in color cartridge). The printer
shows empty cartridges but it will printing.
Nov 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
My C6280 printer says the black is empty but it is
Dear Sir,
Printer doesn't identify the ink accurately all these are controlled by software only.So it is showing your black cartridge is empty but trace amount of ink actually remained,by this you are getting black and white prints correctly.After the consumption of that trace amount of ink it may print black text as a greenish-brown because printing taking place only by means of color cartridges.So if you observed blurred text or greenish-brown text, now you can replace your ink cartridges.
i think it helps
good luck
Aug 11, 2009 | HP Office Equipment & Supplies
Estimated ink levels are incorrect
Feb 15, 2009 | HP PhotoSmart C4280 Laser Printer
HP C6280 with new ink cartridges shows cartridges empty
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Feb 03, 2009 | HP C6280 All-in-One Printer
HP DeskJet 5740 InkJet Photo Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
