Question about World Marketing of America DH2304 DuraHeat 23,000 Btu Kerosene Heater - Refurbished
How do you replace a wick for a DURA HEATER DH2304
4 Suggested Answers
SOURCE: i need to replace a wick in a kerosene heater by
How to replace a 10,000 BTU kerosene heater wick
Posted on Jan 22, 2010
SOURCE: I need help with my
batteries are used to light the wick
Posted on Dec 14, 2010
SOURCE: Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Posted on Jan 14, 2011
How do replace the wick in a turco kerosene heater
This a very odd question about cell phones, isn't it? There are two videos on you tube to help you do this.
Kerosene Heater Wick Replace - YouTube
How To Replace a Kerosene Heater Wick Tutorial - YouTube
Jan 26, 2014 | Lands Phones
How do you replace just the top part of the wick on a comfort glow GR9B kerosene heater?
    • Remove the base plate from your Comfort Glow heater and expose the fuel tank. Lift the fuel tank out of the heater and set it to one side, well away from the heater. Note that the fuel tank is not connected to anything and will slide out easily.
    • 2 Run the heater until all the fuel in the lines is used, a process called "dry burnicon1.png," which usually only takes a few minutes. The fire will go out when the lines are empty. Turn the heater switch off and allow it to cool.
    • 3 Take the batteries out of the battery compartment on the back of the heater. This is an important safetyicon1.png step that keeps the heater from accidentally coming on while you are working on it.
    • 4 Lift the wick ring up and off, then remove the two nuts that secure the wick. The wick ring fits around the wick and the draft pipe -- the hollow tube that holds the wick -- and serves to hold the wick firmly in place.
    • 5 Slide the wick up as far as possible to reveal the positioning pin -- the small metal pin near the bottom of the wick. This pin is part of the wick and helpsicon1.png to ensure it is installed correctly. Push it out through the positioning hole in the draft pipe and lift the wick out of the heater.
    • 6 Fit the new wick onto the draft pipe and engage the positioning pin in the hole by pushing it in until it clicks into place. Move the wick down into the heater and replace the two nuts to secure it.
    • 7 Measure the distance between the wick and the draft pipe with the clearance gauge. The distance between the wick and the draft pipe should be the same all the way around, to ensure an even burn. Adjust the set screws as necessary to create even spacing. These are the small screws spaced evenly around the draft pipe that, when turned, move the pipe slightly so you can correct the spacing between the draft pipe and the wick.
    • 8 Replace the wick ring over the wick. Return the batteries to the battery compartment and the fuel tank to its compartment. The fuel tank will slide securely into its compartment in only one way. Replace the fuel compartment cover to complete the project.
Tips & Warnings
  • Keep the heater set on medium to medium-high for best results. Setting it too low or too high may cause soot to accumulate on the wick.
  • When operating a kerosene heater indoors, always have a working carbon monoxide alarm and a smoke alarm. These heaters are generally safe when in use, but an alarm will provide a safety backup in case the heater malfunctions
Oct 14, 2013 | Northern Tool 10,600 BTU Radiant Kerosene...
I need a manual for a RMC 95-C2
Below is a link to a site with manuals for the Dura Heat DH2300 series heaters. DH2300/2303 and DH2304. I believe the DH2300 series is the same as the RMC 95 series heaters. Just be sure to check both the 2300 and the 2304 manual for a match. I hope this helps.
http://www.yourheater.com/owners_manuals.htm
Oct 24, 2009 | Dyna-Glo Heating & Cooling
RMC-95C6 wick replacement
REPLACEMENT WICK NUMBER: Kero-World 32225, Dura Heat DH-145, Glowick 30856.
Sep 07, 2009 | Dyna-Glo RMC-8001SS Heater
Change wick corona dkc22
u need to start at top . remove cage from top. there should be a few screws on the side of the upper case (the round upper part of the heater) once that is removed u will see the shaft the wick is attached to,the heater control are mounted here too. there should be some screws or wing nuts remove them. now lift the shaft out the wick will come with it (carefull wick wiill be wet with kerosene) remove old wick. when replacing new wick make sure to allign the top of the colored band with the top of the wick holder(the piece with the pins that adjusts the wick up & down) lower shaft & wick back onto heater and reasemble heater .be sure all controls and shut off work smoothly and correctly.
Jan 10, 2009 | Corona 23-DK Compact Heater
Wickes
I went to a site that has questions and answers about a kerosun heater. from what I gathered, instructions on how to replace the wick are included with the replacement wick.
Dec 04, 2007 | Northern Tool 10,600 BTU Radiant Kerosene...
Heating & Cooling Logo
1,546 people viewed this question
Top World Marketing of America Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a World Marketing of America Heating and Cooling Expert? Answer questions, earn points and help others
