Question about Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by
When you flush, sometimes it flushes fine, and sometimes the pressure isn't there at all and you need to reflush
  • 38 Answers
Make sure the flapper is holding water in tank. if it is leaking, then when you go to flush there is not enough of water to flush. to check for leaking flapper,take a pack of kool-aid and dump it into tank of toilet. dont flush toilet. let set for 10-15 mins. if the flapper is leaking,the color of kool-aid will show up in bowl. hope this helps.
Posted on Oct 05, 2009
Oil light comes erratically on 92 accord
my guess is one of three things:
1. clogged inlet or worn out oil pump gears: change oil pump
2. Engine is tired and has leaky loose bearings and journals, hemorrhaging oil out all internally bleeding places. Engine flush unclogged the varnish that was holding oil pressure up. Rebuild engine or change when current engine blows.
3. Bad oil pressure sensor causing strange readings. Diagnose actual oil pressure and change sensor if needed.
These vintage honda engines are everywhere for cheap at junkyards. i wouldnt pay more than 350 for one.
Feb 17, 2015 | 1992 Honda Accord
The heater isn't putting out hot air
check to see if there is plenty of antifreeze in radiator , may have a air bubble in system .
Jan 28, 2013 | 2005 Chevrolet TrailBlazer
HEAT NOT WORKIN IN 1989 CADILLAC?
either the blower motor is bad or you need to flush out the heater core.due to the age of the vehicle its probably clogged up with deposits and needs to be flushed out with air pressure or you can try hooking up your garden hose to it and flushi9ng it out that way
Jan 25, 2013 | 1989 Cadillac Sedan DeVille
HEATER ISN'T BLOWING HOT AIR
Sounds like a restricted heater core. Remove the hoses and back-flush the heater core system with a water hose. You may want to do a complete cooling system flush while you're at it.
If you can't flush the heater core clean with a water hose, it may be time to replace.
Jan 06, 2013 | 2002 Ford Ranger Regular Cab
Front disc brake is very spongy, sometimes it grabs properly but mostly the brake is useless (pads are fairly new)
Try bleeding it first. If there isn't any air in the system, you have a brake hose collapsing internally. Replace the hose, flush the system, bleed the air out and you'll be fine. Good luck!
Jun 14, 2011 | Suzuki GZ 125 Marauder Motorcycles
I have an EcoQuantum dual flush toilet, all of a sudden it flushes sometimes & sometimes it won't flush at all. I push the handle down/up & nothing happens. Water pressure has not changed at my...
EcoQuantum B8100 is junk in my opinion. There is an obvious design flaw in the handle. The flush/no flush problem lies there. If you contact the company, you can get another handle from them, and problem will be solved. However, it WILL happen again in a year or so, and you will come full circle. Their number is 1-800-391-9821.
Nov 11, 2010 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
Continuous flushing
Check the flapper in the bottom of the tank to see that it is sealing good. Sometimes they need replaced.
Oct 01, 2009 | Home
No water at flush
sound like the water shut-off needs to be replaced.
if you turn on/off the shut-off, the tank get enough water to flush, then you get less water every time you use the toilet. that is the shut-off valve problem.
you may able to to just change the rubber seal.
I have not found change the seal will last as long as a new valve. better off, just change one.
Feb 11, 2009 | Eljer Aqua-Saver 12" Two-Piece...
No back flush pressure
increase the tank water level half inch at a time till you have the back flush pressure.
seems like the water in the bowl is too low to create any wirlpool.
Oct 30, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by Logo
295 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
