Question about RCA RT2280 System
RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I have my dvd player (this player plays 5.1 surround sound dvds) hooked up, I am using an optical audio cable and I select "optical" on RCA RT2280. When I press the "SURR.MODE" button it only cycles through : Dolby Pro Logic ; Dolby 3 Stereo; Stereo. Dolby Digital is not one of the options available. It has worked before and now it won't.
  • rlamar23 Aug 18, 2008
    I have the same exact problem with my receiver. Dolby Digital Sound is not an option when I press the surround sound button.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Posted on Dec 28, 2008
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Hoooking up surround sounds with optical cable surround system is RT2280 AHHH please help my husband is driving me crazy to get it fixed and he cannot figure it out. Superbowl must be in surround sou
Make sure the digital setting (optical/coaxialor analog)is correct.
If youre connection is differet from default setting
1.select the source
2.press function
3.rotate multi jog to toggle among optical/coaxil/analog to match
yuor connection.
your selection will be stored automatically.
every time you press the source button the input setting(dvd/opti)
will be show on display.
heres a link to the manual go tto page 21 advanced settings.
http://www.google.co.uk/url?sa=t&rct=j&q=surround+sound+RT2280+AHHH&source=web&cd=4&cad=rja&ved=0CEMQFjAD&url=http%3A%2F%2Fsupport.radioshack.com%2Fsupport_audio%2Fdoc66%2F66651.pdf&ei=G2QMUbKqMOOY0QWJlYBw&usg=AFQjCNG2gc-bExNRynH2JEV22sR-L_ggDg&bvm=bv.41867550,d.d2k
Feb 02, 2013 | RCA RT2280 System
I have a new rca receiver and have it hooked up to my dvd player which works fine. I have it hooked into my tv and Im not getting sesurround through my tv how can I connect to the tv to make it work my tv...
Take a clue from the 10-year old vintage of the TV and the two analog audio cables. It's Dolby Pro Logic Surround at best, not Dolby Surround in the modern, digital, multi-channel sense.
TV's are not the source nor the end of a multi-channel audio chain. Feed this thing a 2-channel source from a Cable Box (into the "TV" jacks), DVD, Video Tape or CD with proper Dolby Surround encoding and will seem to open up the sound field a bit and kick in a little surround effect. It can also simulate a Hall effect and Dolby 3 stereo.
http://en.wikipedia.org/wiki/Dolby_Pro_Logic
Jan 27, 2010 | RCA RT2400R Receiver
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
Right now my reciever will only play with two speakers (L and R). How do I get the 5.1 DTS back?
Are you using single digital coaxial or optical digital or the stereo RCA cable.
You might have that buttons on the remote for surround,2channel,3channel or 5.1 channel. orGo to the DVD's setup menu and click on "Audio Setup" or on "Languages" if there is no Audio Setup option and choose "Dolby Digital 5.1." (If you have a5.1, 6.1 or 7.1 system select "Dolby Digital EX" if it is an available option.) Depending on the age of the disc, the "Audio Setup" on the DVD menu may give you several choices: "5.1 Channel Surround Sound" or "Stereo Playback." If it's an old DVD, it might even say Dolby AC-3 (the professional designation for Dolby Digital 5.1). New DVDs may offer "Dolby Digital 5.1" and "Dolby Digital 2.0," the latter being stereo. Some of the disc menus offer only "Surround Sound" or "Stereo" options.
Aug 14, 2009 | Yamaha RX-V463 Receiver
No dolby digical in DVD mode.
PCM mode will not output dobly digital, use the digital cable connection, not RCA cables, set DVD audio output menu to Dolby digital or DTS. On DVD software menu setup select audio then Dolby Digital 5.1 or Dolby Surround.
Jan 25, 2009 | Yamaha HTR-5960 Receiver
Optical input from Sony PS3 Playstation.
Have you tried setting the PS3 on linear PCM output instead of bitstream? The DVR 50 may not say Dolby Digital since the optical cable goes directly from the PS3 to it but you may get the surround channel output you're looking for.
Mar 13, 2017 | Jamo DVR-50 System
I can hear cds and see video on my hp dvd 1040i multiformat dvd writer but I can not hear audio to the movie/dvds i have rented.
Sounds like you might have a setting that is incorrect for DVDs in the setup menu.
Grab your DVD player remote and press the SETUP button. Navigate to the audio menu. Make sure Spdif is turned off (unless you're using an optical cable for your sound), that the audio stream is set to PCM (standard for CDs) or RAW, and turn off any Dolby/Digital Dolby/Surround Sound/etc. Now play a disc.
There's also another way if your remote has an AUDIO button. While the DVD is playing, press the AUDIO button and you should see a small windo that pops up that will tell you what the audio is set to. Press the button and wait a couple of seconds between presses to see if the audio starts playing.
May 12, 2008 | Televison & Video
Surround cuts out???
Are you useing a digital audio cable when its cutting on & off? How long between the on & off? I have the same problem when I use a digital audio cable or a coaxial audio cable from my DVD player. To use the surround (6 CH) feature you need to use the 6 channel RCA jacks and if what ever your hooking up dosent have the RCA outputs your out of luck. My DVD player does have the 6 channel outputs and they work but the digital cables won't work. What are you connecting to it? I think something is wrong with the digital circuit board in mine, I would like to replace it and see. Reading your manual will help understand the 6 channel RCA and fiber optic digital cables. I hope any of this helped.
Mar 05, 2007 | RCA RT2280 System
RCA RT2280 System Logo
1,009 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
