Question about Olympus Camedia Stylus 300 Digital Camera
My Olympus Stylus 300 lens won't come out. The lens cover is lose and can be taken off. The battery is charged and I can still view pictures, but I just can't take any.
Olympus Stylus 840 - lens won't open
you need to take it or send it for repair. There is nothing you can do yourself.
Olympus Stylus 840 Repair - Google Search
Mar 23, 2017 | Olympus Stylus 840 Digital Camera
Won't take pictures.
The problem you are describing is a problem with a sensor that is behind the lens cover door on the front of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 22, 2009 | Olympus Camedia Stylus 300 Digital Camera
Camera doesnt remain on
Based on the age of the camera, it's most likely due to the battery just losing its ability to hold a charge. After several years, the battery will just cease to accept a good charge, no matter how long you leave it charging. I'd suggest a replacement battery from one of the "aftermarket" battery makers (only because they are about half the price of the original Olympus battery).
Apr 04, 2009 | Olympus Camedia Stylus 300 Digital Camera
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
My screen is balck so I can;t take pics because I can;t see what I'm shooting. I also can't view any previously taken pictures.
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced.
Olympus will charge a flat rate repair fee for this product if it is beyond the one year factory warranty. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Mar 24, 2009 | Olympus Camedia Stylus 300 Digital Camera
Lens won't deploy
The problem you are describing is a problem with the sensor behind the lens cover door. It seems to have failed and needs to be replaced.
Olympus will charge a flat rate repair fee for this product. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Dec 26, 2008 | Olympus Stylus 410 / ? 410 Digital Camera
Broken camera
It is likely that your lens assembly was knocked out of alignment when you dropped the camera. When things do not line up inside the lens the whole unit cannot move in and out. This malfunction requires disassembly to fix, so you will have to get it to a professional for repair. There are providers online who can repair your camera, and also check with your manufacturer to see if they can service the camera at a reasonable rate. David Millier Advance Camera Repair
Mar 05, 2007 | Olympus Camedia Stylus 300 Digital Camera
Lens will not come out of camera
There is a workaround for this problem, when the lens cover is open press down on the area of the lens cover on the "s" of Olympus. This can operate the switch that opens the lens etc. The long term fix is to remove the lens cover by removing the 2 screws at the base of the lens cover, take the lens cover off and gently clean around the switch which is behind the "s" of Olympus when the cover is on. I found that the grease/oil Olympus had used on the switch attracted dust etc and by cleaning this off the camera began working. Be careful when taking the lens cover off, there is also a very small metal plate that separates from the lens cover - don't lose it.
Nov 12, 2006 | Olympus MJU 300 Digital Camera
Can view memory card but wont power up to take pics
Try using brand new fully charged rechargeable batteries like NiMH or NiCd. Also try viewing though the computer via USB.
Sep 17, 2006 | Olympus Camedia Stylus 300 Digital Camera
Open Questions:
Olympus Camedia Stylus 300 Digital Camera Logo
421 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
