Question about HP Photosmart 7450 InkJet Printer
Paper Jam My printer keeps blinking red saying there is a paper jam when nothing is jammed...
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
SOURCE: Paper jam blinking
Try and push the blue button after clearing the jam.
Posted on Dec 21, 2007
SOURCE: Failure to print
Here's what we did: Lifted the lid and turned off printer. Then turned on again. Unplugged power cable from back of printer, moved the carriage toward the middle of the printer. Took out cartridges and closed the lid. Plugged the power cord back in. Reinstalled the cartridges. After the alignment page it worked fine. These instructions are paraphrased from HP website troubleshooting. I don't have any idea why any of it worked, but it did and I'm grateful.
J
Posted on Aug 30, 2008
yooperbud
  • 8637 Answers
SOURCE: Printer will not print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
  • 34 Answers
SOURCE: HP 4200 printer paper jam. No paper is jammed
check this out....when the printer reports the jam, open the paper tray very carefully and slowly.
Has the paper moved at all forward? Has it moved like 1/4 inch to 1/2 inch out of the tray?
If so, you probabaly need a torque limiter, no tools, $10 or so and a very very easy fix.
POBCM is very correct when he points out that the block/stop in the back of the tray moves when the tray is closed with too much force and this is the #1 cause most of the time.
You may see a "41.3" code displayed if the block is not up to the back of the paper and the paper is not all the way forward in the trays, and under the two metal clips at the front of the tray.
Posted on Mar 14, 2009
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Brother HL 20 printer paper jam light keeps blinking after jam removed
Please check paper sensor may e damage, need to relpace it on prior basis
Mar 30, 2013 | Brother HL-2040 Laser Printer
Keep getting an error that says paper jam. can
Dell P703w Printer
May 02, 2010 | Dell P703w Printer
Go to print and status say paper jam, checked rollers and inside, but no jam
i lost my cd of Hp Deskjet F380 and i want to install now to my cp, secondly it use to show me red light blinking saying paper jam while there is no paper jam inside the printer for now she is not working
Nov 23, 2009 | HP PSC 1210 All-In-One InkJet Printer
My printer keeps saying there is a paper jam. But
If the printer is sensing a paper jam, then there is either a small piece of paper jammed under a sensor, or the sensor is falsely reporting a jam.
If you cannot find the sliver of paper, I suggest that you contact Canon Technical Support or take the printer to an authorized repair shop.
Don
Oct 17, 2009 | Canon Office Equipment & Supplies
Middle light blinking message says paper
Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
Sep 22, 2009 | HP DeskJet 550c InkJet Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Paper Jam
Refer to www.kodak.com/go/itg and select all in one printers and then paper-jam . it will step by step show you on how to remove the paper-jam. if the printer does not work,after those steps Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost.
Jun 28, 2009 | Kodak ESP 5 Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
Pixma mp750
it seems the lever for the paper jam is having problem you have to open the printer and check for any broken or dislodge part.
Aug 18, 2008 | Canon PIXMA MP750 All-In-One InkJet...
HP Photosmart 7450 InkJet Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
