Question about Yamaha Electrical Supplies
Yamaha diesel generator 6500 EDY
Would like to know the specs for Yamaha diesel generator 6500 EDY and fuel consumption
4 Suggested Answers
FRANKSFIXIT
  • 72 Answers
SOURCE: conversion of Yamaha gasoline electricazl generator engine to natural gas
My answer:
Hello Bill:
Here are the site links you'll need to check and/or get info, or buy your adapter kit for your Yami YG4600D Genset conversion kit.
Most likely it's running an 8 or 10HP engine on it now? In any case it's most likely less then 12HP. Not sure what size engine you have, as you didn't say only for the model #? On older Gensets it's harder to track down the HP rated engine is all.
For your Yami YG4600D Genset there you most likely will have your choice of at least 4 adapter kits depending on if you are going to keep gasoline as an option. If you're definitely NOT going to be ever running gasoline again then there are 1 or 2 adapter kits to choose from.
Use the site links below, and then browse whichever area you want as there are many options there. The last link listed takes you through all the different engines by make & model #'s.
I would also shop around locally where you are in LA, as you might be able to get that adapter kit for a lot less then the $227 to $267 they are asking for there at that site.
If you don't see your exact model # (or kit) there call them on their 800 toll free # listed at their site.
Also - if this site doesn't meet your expectations customer service wise at least you will have a starting off point with the wealth of information supplied there!
http://www.propane-generators.com/what_kit_do_i_need.htm
"What Kit Do I Need?"
http://www.propane-generators.com/simple_explanation.htm
"Simple Explanation"
http://www.propane-generators.com/a-c_kit_list.htm
A and C Kit List
Please post me a reply as to this info helping you solve your adapter kit problem there by following my posting recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Posted on Sep 07, 2008
  • 583 Answers
SOURCE: conversion of yamaha gasoline generaor into natural gas...
i know YAMAHAwere doingsome work on converting outboard motors to run on LPG they may be able to get a bit of info from the STATE distributors might be worth a phone call
Posted on Aug 10, 2009
heatman101
  • 43501 Answers
SOURCE: i have a Yamaha 6500 generator gas when i start
Hi.
Usually when that happens it is because the diode(s) has gone out...
heatman101
Posted on Aug 18, 2010
Why woun't my 6500 ransond generator start its a diesel
See id it is actually pumping fuel and if so see if the glow plugs are getting hot.
Oct 07, 2014 | Cars & Trucks
Generator wont start up unless i spray starter fluid into it
This sounds like a dirty carbureator. Just bad enough that it won't start cold.
Mar 29, 2014 | Electrical Supplies
Looking for fuel filter for Onan HDKAK=1046 rv generator. Anyone have the product number
You didn't indicate a Spec number for your gen that would be required. Any RV place can get this part it is Cummins part # 149-2513 but a Spec number would help.
Oct 09, 2013 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
Need to know an average fuel consumption on a nissan xtrail 2010 in a petrol and diesel both are autometic
The Nissan X-Trail was distributed to Australia through Nissan Australia. The fuel consumption figures for the different engines are below.
Petrol: 9.1L/100km
Diesel: 7.4L/100km
Oct 02, 2013 | Cars & Trucks
Northstar 6500 generator oil pressure switch wiring
Need to look at what your talking about, too many possibilities.
Jan 18, 2013 | Northstar Generator 10 Hp, 6500 Watt,...
Need owners manual for Yamaha EDY 6500 generator
hi my name is mohammad from iran i want a service hand book for yamaha genarator edy 5000 .please send to imail mr.rabizadeh@gmail.com
Jul 04, 2011 | Yamaha Electrical Supplies
Hi, Fuel consumption on my bmw e34 diesel has
I know people complain only when fuel levels skyrocket(increase). You should be happy your fuel consumption has plummeted (reduced). However, for BMWs it is usually advisable you change the set. If a pully is bad, it usually affects other parts. Your BMW is rather old...these problems usually come with aging BMWs which usually have a lifespan.
Cheers.
Oct 13, 2009 | 1994 BMW 3 Series
Yamaha 6500 watt diesel runs but usually shuts
First thing to monitor is the fuel solenoid power. See if it is the thing that goess away to cause shutdown.
Tracing this back there is only a few things that control this: The battery, the low oil shutdown switch, and the run switch, and associated wiring.
If I were to ventture a guess, I would put money on the low oil shutdown switch.
Aug 24, 2009 | Taylor Skid Mount Diesel Generator Set 30...
Conversion of yamaha gasoline generaor into natural gas...
Jul 20, 2009 | Electrical Supplies
1000 watt Yamaha generator surges when on low setting
YOU PROBABLY HAVE LINKAGE PROBLEMS ON THE CARB IS IT AUTO THROTTLE IF SO YOU MAY ONLY NEED TO ADJUST THE SETTING SCREWS GIVE ME SOME DETAILS LIKE BRAND HORSE POWER CARB BRAND AND MODEL AND I MAY HAVE THE EXACT ANSWER FOR YOU I HAVE ALOT OF SMALL ENGINE RESOURCES FOR SPECS AND DIAGRAMS
Jun 23, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Electrical Supplies Logo
224 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Roland W VanLue
Roland W VanLue
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
