Question about Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC-D363 won't charge battery
Camcorder battery will not charge. It will work plugged in, and will also work with an already-charged battery (bought a replacement battery today thinking it might be a problem with the battery itself). I have also replaced all other lithium batteries, just for kicks. There is no green flashing charge indicator, no notice of battery charge progress shown when "Display" button is pressed for 7 seconds - all of which worked before. Can you help us? Thanks.
    Problem Solver:
  • 5 Answers
Well , just make sure that the camera is set to the off position when charging , otherwise i dont think it will charge properly.
hope this helps
Posted on Jan 03, 2008
  • HELEN Nov 24, 2011
    Hi Khanser,
    I have the same problem with my Samsung VP-D371W, but I have the added problems of not being able to record or turn it off.
    It comes on fine when plugged in but seems to be stuck on the 'play mode' as everything plays fine...I get a blue screen when I stop the tape and cannot record or turn the player off. In play mode it won t charge properly and that seems to be the problem here.
    I ve tried buying new chargers and batteries...... I d also love some good advice on how to fix the charging problem we both appear to have (and many many others it seems), why it would be stuck on play mode and how to fix it.
    THANKS
    HELENXXX
My SC-D363 will not recognize the SD Memory Card.
The SC-D363 only can handle up to a 1 GB SD memory card, no larger, so if you are not using a 1 GB or smaller card, then that is your issue.
Jan 17, 2013 | Samsung SC-D363 Mini DV Digital Camcorder
D363 new battery new charger still does not work the small coin battery is old cr 2025 what you advise battery chargerlight will not come on.
I have this camera, and have had trouble with connecting the charger to the mains (in the UK, using an adapter to plug the two round pin charger into a UK square pin socket). I found I had to withdraw the plug from the mains adapter socket slightly to get it to connect. Once it is powered, the charger light on the camera should flash while charging, and go on steady when fully charged. It takes a few moments to start flashing. It does not flash when the battery is not present, or when the camera is turned on, in play or record modes.
If it isn't a problem with the connection, perhaps the battery has reached the end of its life. Discharging the battery completely can shorten its life. Or perhaps the battery itself isn't connecting because it isn't seated in its mount correctly.
CR2025 coin cells are not hard to obtain- I have seen them in a local thrift mart and on eBay. I don't think it needs this battery in order to charge the main one, but it is worth a try. This battery is just to back up the memory of the settings and keep the clock running.
Oct 25, 2010 | Samsung SC-D363 Mini DV Digital Camcorder
How do I get the drivers for my Samsung SC-D363 Mini DV Digital Camcorder
You can download drivers, other software and manuals for this camera from this page
Oct 16, 2010 | Samsung SC-D363 Mini DV Digital Camcorder
I charged battery for 1 day but my camcoder no power. if the battery is bad how do i know? please helps.
If the camcorder will power up with the charger plugged in, it is most likely the battery. Depending on use, rechargeable batteries can go out in as little as 6 months.
Feb 06, 2010 | Samsung SC-D363 Mini DV Digital Camcorder
I HAVE SAMSUNG SC D363 HOW CAN I DOWNLOAD THE SOFTWARE TO WORK WITH MY HP WINDOM VISTA.
I downloaded the 363 driver from Samsung but when camera is plugged into PC, Vista says no drivers were downloaded. Do I need an upgrade?
Jul 15, 2009 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung sc-D363
I had the same problem. The batteries do not last. When the battery becomes weak it can not run the tape so it tells you to eject it.
Buy a new bigger battery. I bought a 160 for ~$30.
Jan 17, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Wont hold charge, light comes on though
hey , well i think an hour might be normal , mine seems to only last as long , but it says in the manuel that when the camera is not in use to disconnect the battery because even with the power off it still discharges.
hope this helps
Dec 19, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC-D363 Mini DV Digital Camcorder Logo
288 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
